LG ST600 Owner's Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
Old 08-15-2012, 06:25 AM
marioval's Avatar
Or is it ST600 (Ver:ST.8.79.207.F/Date:2012.04.23)? Whats the difference?
marioval is offline
Old 08-31-2012, 09:52 AM
calstudios's Avatar
Video TS folder support?  Fry's is blowing these out for $29, and if it plays DVD back ups/rips, it would be a great buy.
calstudios is offline
Old 09-01-2012, 04:53 PM
Zandman's Avatar
I went down to Fry's this morning and was disappointed to find the SP520 offered at $29.99 not the ST600. I asked the sales guys to check their inventory sys since the picture in the newspaper ad was clearly a ST600. The SKU # in the ad came up as a ST600 with 1 in stock. I asked if I could buy that one and he said it was a display item that was taken off the shelf and then offered me the SP520 again. Bait and switch if you ask me.
Zandman is offline
Old 09-15-2012, 11:08 AM
Imwatchinu's Avatar
Just noticed that their lowing these things out again at 29 bucks. I was doing some research and found that the Canadian version decoded DTS H MA based from their pecs on the canadian website. Isthis true?
Smart TV Upgrader with Web BrowsingST600DOWNLOAD PDF
CONVENIENCE Time BarCinema ZoomFirmware UpdateDLNAWireless LANYesYesYesYesYes, Built-in
VIDEO FORMAT DivX®/DivX HDMPEG2MPEG4 AVC (H.264)SMPTE VC1 (VC-9)MKVTS TPM4VWMVYesYesYesYesYesYesYesYes
AUDIO CAPABILITIES DTS™DTS-HD Master Audio™Dolby® TrueHDLPCMDolby® DigitalDolby® Digital PlusMPEG 1/2 L2MP3WMAAACYesYesYesYesYesYesYes, PCM onlyYes, PCM onlyYes, PCM onlyYes
BROADBAND Web BrowsingContentYesNetflix 2.1, MLB, Facebook, Google Map and many more
VIDEO FEATURES NTSC (Pal Conversions)Deep ColourxvYCCYesYesYes
CONVENIENCE Smart TV UpgradersYes
INPUTS/OUTPUTS HDMI™ OutDigital Audio OutEthernet (RJ-45)USB 2.0 InYesOpticalYesYes
INCLUDED ACCESSORIES Power CableRemote ControlBatteriesYesYesYes
POWER Power RequirementsPower Consumption110~240V 50/60Hz only17W
DIMENSIONS & WEIGHT Set (WXHXD) (mm)Weight Net (Kg)110*110*290.8 kg
WARRANTY Limited Warranty1 Year Parts & Labour
Expand All SpecsCollapse All Specs Back to Top
Imwatchinu is offline
Old 11-02-2012, 04:50 PM
volpo's Avatar
Hi I just bought an ST600 (refurb). Works well but when it hits an MP4 that it cannot play it just sits on the circle thingie. Any way besides unplug to get it back to the menu. I am not using any of the server programs just playing right off of my net.
V
volpo is offline
Old 11-20-2012, 02:37 PM
rodrigocb27's Avatar
Hi guys,
I can't connect my device with ANY android app... It's driving me crazy! I upgraded the last edition and the same thing happen. Any clue? Btw, I tried all LG android app (LG TV remote , LG smart remote) and tried Smart TV wifi remote...
rodrigocb27 is offline
Old 02-26-2014, 06:35 PM
DougReim's Avatar
Liked: 24
Hi,
I have 2 ST 600's, one connects wirelessly and the other is hard wired. One is about a year old and the other is 6 months old and they've both worked fine until recently. At the roughly the same time they both stopped connecting to my computer. They both still get to Netflix and Vudu but as soon as i get into the Smart Share window, the unit goes dead, completely powers down. I can't think of anything in my system that changed and I've tried all the settings and did a factory reset on the 600. It gets a solid connection to my PC but it just dies when I try the Smart Share to access my MP3's. All my other devices can still connect to my PC without issue. I also have a LG DVD player with the same interface as the 600 and the DVD player still connects with no problems.
Any one have any idea what might be causing this?
Thankssssssssssss
Doug
TV Room Upgrade Completed
DougReim is offline
Old 03-05-2014, 01:01 PM
littlerichie2's Avatar
I have the exact same issue on the 2 that i own.  I tried to downgrade firmware with no success.  The only thing I can think of is LG somehow knows it is playing downloaded content and forces it to crash.  it crashes as soon as i select movies on the smart share as well
littlerichie2 is offline
Old 03-05-2014, 01:46 PM
DougReim's Avatar
Liked: 24
That's really strange.
Like I said I have 2 of them and they both worked fine until a couple of weeks ago. It really sucks for me because LG seems the be the only media player that gives you a Windows like view. My MP3's are not tagged correctly so all the other players are worthless to me. I have thousands of music files so I have to find something that views files just like Windows does.
If you find the cause or a solution , please post up and I'll do the same.
Doug
DougReim is offline
Old 03-12-2014, 01:03 PM
kaoslife's Avatar
OK, I'm having the same Issue, so I wonder what the hell is going on.  Will work sometime, not others.
kaoslife is offline
Old 03-12-2014, 10:05 PM
kaoslife's Avatar
Did some more testing. If plex is running on my network, when I try to see movies under smartshare, the box will turn off. I can select media link and see the plex server, but when I select a show, get an error, can't play file. When I turn plex off,I can pick movies under smart share and see my nero mediahome server and play shows from there fine. Confused on what is wrong with plex. I just updated tip the latest version.no change in behavior.
DougReim likes this.
kaoslife is offline
Old 03-13-2014, 05:18 AM
DougReim's Avatar
Liked: 24
I have Plex installed but don't use it. I'll uninstall it when I get home and see if that's the cause. Kaoslife.......Thanks for the tip, I hope this works.
Doug
DougReim is offline
Old 03-13-2014, 10:21 AM
DougReim's Avatar
Liked: 24
Kaoslife,
You be da man!
I closed Plex and problem solved.
Thanks for figuring that out.
Doug
DougReim is offline
Old 05-05-2014, 06:08 PM
kenzie818's Avatar
Is there a app or something for the LG st600 smart tv updater? My dog ate my remote and I can't do anything with it now frown.gif
kenzie818 is offline
Old 09-16-2015, 09:32 PM
Liked: 0
Hi can anyone provide a working link for the beta firmware? Cant seem to find it anywhere at all and the links previously used are dead.
rhett83 is offline
Old 10-23-2015, 08:02 PM
Liked: 0
ditto I've searched everywhere for this file anyone got a copy of it? thanks
rcorkum is offline
Lg St600 Smart Tv Upgrader With Digital Streaming And Internet Services
