MOCA Networking and Comcast - AVS Forum | Home Theater Discussions And Reviews
post #1 of 34 Old 06-24-2011, 10:35 AM - Thread Starter
Irishdoom's Avatar
Quoted: 18 Post(s)
I switched fairly recently from Uverse to Comcast. Overall, the switch has been alright, but my networking has taken a hit as a result. I rent and am unable to run coax through the house. (When I buy sometime next year, this will change!!) With Uverse, their STBs had a hot RJ-46 port I was able to use to get a fairly solid network going out the living room with minimal fuss.
With Comcast, though they have a similar port, it is not "hot". They did provided the free wireless N router, but it's just not as solid as my old Uverse network was. I'm seeing buffering occasionally even on higher bit-rate DVD rips. I shudder to think how it would hold up should I try anything high def.
So I've looked at a few options. I could conceivably get a high end, dual-band N router, and this MIGHT improve the situation. My living room is very close to where the Comcast modem/router are, so it COULD work.
Another option I'm looking at is a MOCA network. I can get the Netgear kit right now for right around $100, which includes 2 MOCA boxes, which is all I would really need. I've been trying to do my Google diligence and see if and how it would work with my Comcast modem, but I'm having a hard time finding any solid info on how well it works.
Is anyone here using a MOCA network with Comcast? Is it reliable? How easy is it to set up? Do I also need some special splitters or something to that effect?
Irishdoom is offline
post #2 of 34 Old 06-25-2011, 09:16 AM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
I use Moca with Comcast, it works awesome. I get the full 100mbps between the two adapters. Streams full BD rips with no issues.
There is no setup with Moca. Just plug them in and your done.
almostinsane is offline
post #3 of 34 Old 06-25-2011, 07:10 PM - Thread Starter
Irishdoom's Avatar
Quoted: 18 Post(s)
Wow, sounds nice. Can you explain how it hooks up on the cable modem end? My cable modem is in my office, and right now is hooked to the wireless router. Did you have to put in some kind of splitter or something?
post #4 of 34 Old 06-26-2011, 03:32 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
I also use Moca with Comcast (San Francisco). You need to split the cable and one goes to the modem and one to the Moca router. Then Ethernet goes from the modem to the Wan port on your primary router (which might be the Moca router). If you use a separate primary router (as I do) then you run another Ethernet cable from a LAN port on the primary router to a LAN port on the Moca router.
ScottJ is offline
post #5 of 34 Old 06-27-2011, 10:49 AM
Quoted: 47 Post(s)
Liked: 42
No splitter needed. Just plug the cox from the wall into the Moca adapter then from the Moca adapter to the cable modem. The Moca adapter has a cox in and cox output.
post #6 of 34 Old 06-27-2011, 12:03 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
True, if your Moca adapter has both in and out coax then no splitter is needed. I was thinking of my MI424WR which has only in.
ScottJ is offline
post #7 of 34 Old 06-27-2011, 12:06 PM
ocZZZZ's Avatar
I use moca with comcast. I had issues afterupgrading one of my hd boxes and now need to use diplexers. I was getting dropouts on HD video after the upgrade.
ocZZZZ is offline
post #8 of 34 Old 06-27-2011, 08:32 PM
Quoted: 47 Post(s)
Liked: 42
oh, ok. I have the Netgear kit which has coax input and output.
post #9 of 34 Old 07-05-2011, 08:16 AM
mars76's Avatar
Hi ScottJ,
Could you please post the steps you used for setting MI424WR as your primary router.
I followed the thread http://www.avsforum.com/avs-vb/showt...hlight=mi424wr and it mentioned disbaling the coax port.
It didn't work for me. Also i didn't use a Splitter or diplexer to connect to the Actiontec coax as that is disabled.
thanks
mars
mars76 is offline
post #10 of 34 Old 07-05-2011, 09:16 AM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
Originally Posted by mars76
Hi ScottJ,
thanks
mars
I don't use the Actiontec as my primary router. I followed that same thread. It does not say to disable the coax -- that makes no sense as the entire purpose of that thread is to explain how to use the Actiontec for Moca which uses coax.
ScottJ is offline
post #11 of 34 Old 07-05-2011, 10:00 PM
mars76's Avatar
Hi,
I am able to connect to Internet using a LAN Port from Actiontec connected to my laptop.
How ever when i try the 192.168.1.x then it doesn't show up the Admin Screen !!
I want to enable the wireless on Actiontec and now i cannot enable that settings..
Thanks..
mars
mars76 is offline
post #12 of 34 Old 05-14-2013, 02:18 PM
Mike Wolf's Avatar
I'm using MoCA with Comcast as we speak without any problems. It's all good here. I'm using several Actiontec ECB2500 adapters connecting a PS3, the rest of my network, several TiVo Premiere's and MoCA enabled TiVo Premiere 4 and am not having not one ounce of trouble with heavy duty 1080p uncompressed and 4K uncompressed streaming. What I did was disconnect the coax cable going into my cable modem and attach it to the coax in on one of the adapters then connect a coax cable from the coax out on the same adapter to the coax in on the cable modem. Connected an Ethernet cable to the same adapter and into the router and applied power. I've used the standard Antronix CMC3004H and CMC3002H 5Mhz-1002Mhz splitters Comcast uses without a problem, and I've used the standard Extreme Broadband Engineering BDS104H and BDS102H 5Mhz-1002Mhz splitters Comcast uses and also have not had any problems. cool.gif No need for diplexers, no problems with set top box upgrades no dropouts, everything works perfectly well together.
Opinions expressed are my own and do not necessarily represent those of my employer or its associated companies.
Mike Wolf is offline
post #13 of 34 Old 05-14-2013, 02:33 PM - Thread Starter
Irishdoom's Avatar
Quoted: 18 Post(s)
Wow, old thread! smile.gif I did use MOCA with Comcast for a time and it worked out well. I did buy a house last year, however, and now have a hard wired Gigabit network. smile.gif
post #14 of 34 Old 04-09-2014, 08:14 AM
taomaster99's Avatar
Any help would be appreciated, I have the following setup.  2 ECB2500 actiontec adapters, one in my bedroom where my cable modem is and one in the living room where I'm hoping one day to have my Roku 3 and/or Xbox One connected.  Here is my setup, in the bedroom I have the coax coming from the wall into the moca adapter (coax in).  Then I have another coax (coax out) from the adapter to the the cable modem (Comcast) and a ethernet cable from the modem into the moca adapter.  I can get internet on the PC in my bedroom BUT when I look at the MOCA adapter all lights are on but the coax light.
  The other adapter I have hooked up in the living room, I have the coax from the wall coming into the coax in of the adapter then I have tried the following:  ethernet from the adapter into my Roku 3.  I get all lights on except the coax on the adapter and when I try to setup the Roku 3 through wired connection it's supposed to go through 3 checks (wired network, local network and internet).  It sees the wired network but then does not see the local network and just errors out saying it can't find a connection.  I then tried to put the ethernet into my Xbox One and I'm able to log into my account, browse the game/app store, download games and/or apps, browse the Internet (there is a Internet Explorer) BUT I can't play any multiplayer games.  I tried 3 different games and they all say I don't have a network connection when I try to go into the multiplayer section.  I'm really at a loss on what is going on.
taomaster99 is offline
post #15 of 34 Old 04-10-2014, 04:22 PM
b curry's Avatar
Quoted: 317 Post(s)
Liked: 159
How are you feeding the PC in the bedroom?  It should look like this:
  • Coax cable from Comcast into MoCA adapter.
  • Coax cable from MoCA adapter to cable modem.
  • Ethernet cable from cable modem to router input.
  • Ethernet out from router to MoCA adapter.
  • Ethernet out from router to PC.
From your description, you're missing the router.  Without the router, you don't have a network.
In your living room:
  • Coax cable to MoCA adapter.
  • Ethernet from MoCA adapter to device.
  • Coax out from MoCA adapter can feed a TV, DVR, set-top box, etc.
If you want to run or hook up more than one device from the living room MoCA adapter, plug the Ethernet cable from the MoCA adapter into a switch.
Don't forget to use a MoCA POE filter from the Comcast entry point otherwise your data stream is going to feed your neighborhood.
taomaster99 likes this.
b curry is offline
post #16 of 34 Old 04-10-2014, 06:36 PM
That's how I have it hooked up but the only difference is the router and modem are one in the same (one box).  So there is no dedicated Ethernet port, they are just numbered 1-4 (I did try all the ports individually just now but same result).  I did just notice that the Ethernet cable going from the MoCA adapter into the cable modem/router has a amber light, the Ethernet cable going from the router/modem into my PC has a green light though.  Thanks for the help!
post #17 of 34 Old 04-10-2014, 07:18 PM
b curry's Avatar
Quoted: 317 Post(s)
Liked: 159
Maybe check the Ethernet cable from the modem to the MoCA adapter; maybe swap it with the one you're using for the PC connection as you know that cable is good.  It's possible you have a bad cable.  You could also trade out the MoCA adapter for the one in the living room to possibily rule out a bad MoCA adapter or connection on the adaptor.
You could also try this:
Disconnect all the cables from the MoCA adapter including power.  You can leave the power on the modem.
  • First Connect the Ethernet cable between the modem and the MoCA adapter.
  • Connect the coax out from the MoCA adapter to the input on modem.
  • Connect the input coax to the MoCA adapter.
  • Connect the power to the MoCA adapter and power on.
The point here is to power up the MoCA adapter last to make a hand shake between the modem]router and the adapter.
b curry is offline
post #18 of 34 Old 04-10-2014, 08:50 PM
Ok, tried changing the cable and switching the adapters and that didn't work.  Also tried the disconnecting the adapter at my modem and following your steps and still nothing BUT I just realized something when I was doing that.  I stated before that at my cable modem/router I had the coax from the wall going into the coax in into the MoCA modem, that was incorrect.  I actually have the coax from the wall going into the coax out of the MoCA adapter and then the coax cable from the modem/router going into the coax in of the MoCA adapter which is the opposite of the instructions it comes with (and the setup instructions I've seen online on this and other forums).  I did try it the normal way (coax from wall into the coax in of the adapter then coax out from the adapter into the modem/router) but I don't get an internet connection when I have it setup that way.  The US/DS option on my modem/router just flashes and I don't get a connection.  NOW I'm really confused!!!
I had emailed Actiontec support and they just got back to me and said to make sure the splitter for the internet is rated for 2ghz, I'm assuming this is outside at the box.  Does that sound right?  I'm not using any splitters inside.
post #19 of 34 Old 04-11-2014, 07:26 AM
b curry's Avatar
Quoted: 317 Post(s)
Liked: 159
Yes, for sure you have to have the coax cable coming from you cable company going to the input of the MoCA adapter.  The output of the MoCA coax then goes to the cable input of the modem.  And then the Ethernet from your modem/router back to the MoCA adapter.
Coax from provider --> MoCA adapter cable input --> coax from MoCA adapter output to cable modem; you should be able to get internet to your PC now by connecting an Ethernet cable from the modem/router to the PC.  Does this work?
Next, Ethernet from cable modem/router --> to MoCA adapter.  This connection would supply the internet connection to down stream MoCA adapters.
Regarding splitters, yes, that would probably be the next place to look.  If a splitter is installed that doesn't support the bandwidth you will block the signal.  Also you can't have any amplifier in the path between MoCA devices as it will block the signal.  You should check at your cable entry point to see if you have splitters.  The supported bandwidth should be printed on the splitter.
b curry is offline
post #20 of 34 Old 08-15-2015, 07:19 AM
Quoted: 14 Post(s)
Liked: 1
Greetings MoCA guru's - apologies in advance if I've missed this answer in forum and feel free to direct me to a prior answer...
I've purchased the Actiontec MoCA kit and cannot seem to set up, based on instructions, in a Comcast/Xfinity system.
Service is 'triple play' (cable/internet/phone) with cable feed to set top box and a dual band WIFI 802.11ac XB3 router/modem bringing in internet and phone service. Ethernet cable attached between Actiontec device and modem/router; coax cable from wall into Actiontec device; power on - power, ethernet light on Actiontec, but no light on coax. Checking service - inet and phone do not work...
What am I doing wrong...? I've not tried downstairs/cable box 2nd device, but as I understand it, this system starts with getting connection at router/moden right first, correct...?
Thank you in advance for ideas...
KPowell is offline
post #21 of 34 Old 08-16-2015, 03:48 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
Cable from wall needs to be split, one to Comcast-provided modem and one to the Actiontec.
ScottJ is offline
post #22 of 34 Old 08-17-2015, 05:19 AM
Quoted: 14 Post(s)
Liked: 1
Thank you for reply - splitting was a success, however when I woke up next morning no internet service until I restored cable from wall directly to comcast modem/router. I did not try powering on/off Actiontec and otherwise leaving device set up - need for inet was to great at moment...
From what I've read I shouldn't need a 'filter' - and I'm installing an Actiontec wireless extender (Actiontec Single Dual-Band Wireless Network Extender and Ethernet Over Coax Adapter (WCB3000N01)) - so I'm 'all in' attempting to install MoCA as a solution to my networking issues.
Happy to check out other links/resources if folks can guide and many thanks in advance for ideas/trouble shooting...
KPowell is offline
post #23 of 34 Old 08-17-2015, 08:37 AM
fcsmith's Avatar
Quoted: 26 Post(s)
I would install a POE filter since the splitter in front of the cable modem provides a path out of your house for the network traffic that runs over your coax cables. Also, make sure the splitter is rated up to at least 1.5 GHz.
fcsmith is offline
post #24 of 34 Old 08-17-2015, 08:45 AM
Quoted: 14 Post(s)
Liked: 1
Originally Posted by fcsmith View Post
I would install a POE filter...
Thanks - and installation of the filter goes between Cable out of wall and splitter or between one of two splitter outs going to modem/router in...?
I'm using the splitter that came in the Actiontec kit (two unit bundle) - is there another I should be looking for...? Also on the POE filter, is there a spec that I should consider before buying...?
Thank you greatly for advice - hope to return the favor one day...
KPowell is offline
post #25 of 34 Old 08-17-2015, 09:12 AM
fcsmith's Avatar
Quoted: 26 Post(s)
The splitter that came with the Actiontec will be fine. A POE (point of entry) filter like this would work:
http://www.amazon.com/Filter-MoCA-Ca...rds=POE+filter
You just need one that indicates that it's for MOCA networking. You want to attach it to the cable that comes out of the wall (the point of entry for your service) and then attach the other (male) end to the splitter in.
fcsmith is offline
post #26 of 34 Old 08-17-2015, 09:53 AM
Quoted: 14 Post(s)
Liked: 1
Ok - two more quick questions/clarifications...
In my setup, the Comcast service for my internet comes in at one location (upstairs office), and then CATV/cable TV comes in on a coax downstairs...
This POE (Filter, MoCA "POE" Filter for Cable TV Coaxial Networking ONLY) is marked for Cable TV, when in fact it is my internet line - I should use the same POE, right...?
And downstairs, where I plan to install Actiontec Single Dual-Band Wireless Network Extender and Ethernet Over Coax Adapter (WCB3000N01) - do I need a POE there as well between line in to Wireless extender (line out back to Comcast set-top box, and Ethernet cable to AVR)...
(edit): actually - do I need both a splitter and a POE down at CATV/set-top box in...?
Thank you in advance for your patience...
KPowell is offline
post #27 of 34 Old 08-17-2015, 10:37 AM
fcsmith's Avatar
Quoted: 26 Post(s)
Okay, so the place where your cable modem is hooked up is not actually the point of entry. Do you know where the main cable comes into your house? If you have a basement it's likely there. It sounds as though there's a splitter there, and that's where you'll want to put the POE filter (attach the cable to the female side of the filter, and the male side of the filter to the splitter input). Putting it there prevents any MOCA network traffic from going outside your home, but still allows it to travel on your internal coax network. Again make sure the splitter is rated to at least 1.5 GHz, and if not, replace it with one that came with the Actiontecs. Since there's a splitter where the main cable comes in, you shouldn't need one between the wall cable and the modem/router. The purpose of that splitter was to "close the loop" on your internal coax network so that the Actiontecs can talk to each other, but the splitter that's at the place where the cable enters your house will serve that purpose.
fcsmith is offline
post #28 of 34 Old 08-17-2015, 10:55 AM
Quoted: 14 Post(s)
Liked: 1
Thanks - I'll check how cable comes into house; I've always thought upstairs cable in at modem/router was main, but I might be wrong; may actually be split outside house as I can't see where it would be split internally and thing 2 lines come into house...
Will first try POC at cable modem/router in, as well; buy an extra and a splitter to be ready when installing Wireless Extender...
Thanks, again for ideas...!
KPowell is offline
post #29 of 34 Old 08-17-2015, 01:17 PM
fcsmith's Avatar
Quoted: 26 Post(s)
Unless Comcast does things very differently than my carrier (TWC), I'd be very surprised if there wasn't a single cable coming into your home that then goes through a splitter to feed the locations where you have cable jacks. You only want one POE filter, and it needs to be placed on the main cable that feeds your house. If you place another filter somewhere else in your house, you'll be placing it on your internal coax network and it will prevent proper communication between the Actiontec MOCA adapters. If you determine that there are actually two cables coming into your house, then you probably just want to skip the POE filter. If Comcast somehow split the feed outside the house, then hopefully they would have installed a POE filter before the splitter. Again, I'd be surprised if here wasn't a single feed into the house, but that's based on what I've seen in this area. I'm certainly not an expert on cable system installation.
fcsmith is offline
post #30 of 34 Old 08-17-2015, 08:53 PM
DUSlider's Avatar
Enable MoCa on Comcast Wireless Modem/Gateway.
Just happened upon this thread doing research for my own MoCa setup.
Now, I don't plan on using this feature as I don't really care for the Wireless Gateways Comcast gives out, however, I deal with them almost daily for my clients.
I have noticed that most of these Comcast Wireless Gateways have a setting in their configuration page for MoCa which is disabled by default. I haven't had the opportunity to test this, but suspect if you enabled MoCa, you would just need to get 1 other MoCa adapter to locate where you need to connect your devices, eliminating the need to use a MoCa adapter at your router (Which seems like where some of you in this thread are running into problems).
To access the web gui for the Comcast wireless gateway, open your favorite browser and type in the gateways IP address (should be 10.0.0.1). The default username/password should be admin/password unless you changed it. You should see a MoCa setting on the left to click on then can enable it.
DUSlider is offline
