Sony SMP-N200 - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 142 Old 08-12-2012, 07:21 PM
Guyen Gankhuyag's Avatar
chase smp-n200 but I cant enable closed captioning in nerflix. Is there some kind of trick? thx
Guyen Gankhuyag is offline
post #122 of 142 Old 08-12-2012, 07:22 PM
I purchasde smp-n200 but I cant enable closed captioning in nerflix. Is there some kind of trick? thx
post #123 of 142 Old 08-12-2012, 07:57 PM
michaeltscott's Avatar
Quoted: 2844 Post(s)
Liked: 1516
Netflix is not showing closed caption/subtitle support in its list of features for the SMP-N200 (and a bunch of other Sony products). It is supported in the player on the 2012 BD players but Netflix doesn't have a feature page for them.
As an example of a device which does have caption support, you can see it listed as a feature of the TiVo Premiere's player here.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #124 of 142 Old 09-19-2012, 07:07 PM
Logan 5's Avatar
I really like the You Tube implementation on this unit. I wish all of them worked the same.
Logan 5 is offline
post #125 of 142 Old 10-24-2012, 01:52 PM
baidun's Avatar
I have my SMP-N200 installed and working primarily by streaming photos, music, and video from my PC using DLNA. The PC is running Homestream as the DLNA Server and it sees the SMP-N200 client. Almost everything seems to work well. Music and video is no problem. Some of myu older photos are displayed properly. However, all my newer photos, taken with a Sony NEX-7 camera in JPEG format, will not display. The wierd part is that I can see thumbnails of the images, but when I select an image I get a blank screen for the full size image after about 3-4 seconds of the circle hourglass. I have searched the internet (Google, Bing, etc.) and haven't seen anyone have this issue. I've tried my SMP-N200 as well as my friends, and both exhibit the exact same symptom. I've played around with the screen settings in the settings menu of the SMP-N200, but nothing makes any difference. Any ideas?
Regards
baidun is offline
post #126 of 142 Old 11-02-2012, 04:30 PM
wthomas69's Avatar
Quoted: 12 Post(s)
I bought the n200 because I needed component out for use on an older tv, all the other streamers are hdmi only, so far ok
wthomas69 is offline
post #127 of 142 Old 12-20-2012, 01:20 PM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
I recently went through my house and tested all my electronic equipment for power consumption using a Kill-a-watt meter. For anyone interested the SMP uses about 6 watts while on. I found it interesting that the SMP uses 4 watts in standby. Turning the "Quickstart" feature off allowed the device to fully turn off which will save about $3.50 annually biggrin.gif.
By comparison, my Roku 2 XS only uses 1 watt.
teeitup is offline
post #128 of 142 Old 12-27-2012, 05:06 PM
thedust's Avatar
After installing an old Samsung 160 (3.5") into SATA to USB shell, I thought I could have all my old movies ready to go for this neat little Sony media player.
As it turned out, external HDD enclosures are not set up quite like USB flash drives. For instance, even though their USB device class is still Mass Storage, their interface mode permits bulk data transfer only.
Perhaps it is for this and other similar reasons, Sony SMP-N200 will not do business with devices like my external disk drive.
I'm not too upset, because this drive is as noisy as a ceiling fan.
thedust is offline
post #129 of 142 Old 02-09-2013, 05:46 PM
ClemsonKev's Avatar
HELP!? It plays all my stuff fine EXCEPT for my 1080p MKV files. Instead of allowing the black bars at the top and bottom of the screen, it forces the picture to stretch TALL. Argh! Can't fix in the settings or with aspect ratio of the TV. Anyone have a clue?
ClemsonKev is offline
post #130 of 142 Old 03-06-2013, 05:44 PM
dfran1's Avatar
Quoted: 68 Post(s)
Liked: 40
I just learned to live with it, I can't find a solution either.
Samsung UN60HU8500FXZA With SEK-3500
dfran1 is offline
post #131 of 142 Old 03-07-2013, 04:58 AM
ClemsonKev's Avatar
yea, I gave up too....... I use my WDTV to watch 1080p movies on the projector and the Sony is only used on the other TV for the kids to watch their 720p movies that play fine. thanks!
post #132 of 142 Old 05-31-2013, 06:48 PM
dmwj2's Avatar
MAN!! Thanks for the link to serviio! Damn!! All I had to do is install, point it to my folder, and run the service... SWEET! This program and the Sony Media Streamer works well together. Thanks again!
dmwj2
dmwj2 is offline
post #133 of 142 Old 09-28-2013, 07:32 AM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
Can anyone can confirm whether the SMP-N200 will stream Netflix Super HD?
Sent from my SPH-L900 using Tapatalk 4
teeitup is offline
post #134 of 142 Old 09-28-2013, 08:01 AM
Liked: 1516
According to Netflix the SMP-N200 is 720p-only, no subtitles, alternative audio or digital 5.1 sound support. Given that, there's no Super HD, which consists of two higher bit rate 1080p video encodes. Several times in this thread people have wished for 1080p support in its Netflix player and I don't believe it ever got it.
Is it even adaptive bit rate? If you play "Example Short 23.976" do you see burned-in bit-rate/resolution information (like the big yellow text in this pic)?
post #135 of 142 Old 09-28-2013, 08:28 AM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
Ok thanks for the clarification. I was thinking it was 1080p but I forgot the Netflix isn't on the N200. I tried the example clip and it doesn't show the burned-in bitrate like my Roku does.
teeitup is offline
post #136 of 142 Old 04-15-2014, 05:17 PM
LouV68's Avatar
I'm receiving an update notification, but when I go to Sony's support site, it shows that I have the most recent firmware???
LouV68 is online now
post #137 of 142 Old 04-15-2014, 07:36 PM
LouV68's Avatar
Update: I did an online chat with someone at Sony who wasn't able to find what updates are included. She said to check their website again in a day or two. This is a firmware update going from M10.R.0624 to M10.R.0629
Edit 4/16/14
The SMP-N200/NX20 Network Media player firmware version M10.R.0629 is available and provides improved BRAVIA® Internet Video connectivity.
http://esupport.sony.com/US/p/model-home.pl?mdl=SMPN200&template_id=1&region_id=1&tab=download#/downloadTab
post #138 of 142 Old 01-01-2015, 10:36 AM
LouV68's Avatar
I'm getting a notification thru the box that there is a new firmware update: M10.R.0631 Sony's website has not been updated to show the new firmware.
Has anyone updated their unit? Any improvements such as subtitles added to Netflix, additions/removal of apps, cinavia added, etc.? Thanks.
post #139 of 142 Old 01-02-2015, 03:25 PM
Bill C.'s Avatar
After skimming the entire thread...am I correct in assuming that this is actually a fairly decent local/network file player (of course the Boxee Box and WD TV Live are at the top of the heap, but still)? I've been debating trying to snag one since it actually has physical component video output for older sets...
...and I need your sweet love, Latina T-Mobile girl!
Bill C. is offline
post #140 of 142 Old 01-04-2015, 12:49 PM
LouV68's Avatar
It's decent but it does have its limitations. ie. won't play ISO files, DVD Folder Structure (plays each VOB as a separate video, pauses then continues with next), fast forward & rewind on certain file types (encodes) doesn't work well (starts video over), does not remember where a file left off it unit is turned off, no Netflix subtitles, and I believe max Netflix output is 720p
I use mine all the time regardless of these limitations. I would rate it a 2.5/4
A big plus for me, is that it works well with the free version of Serviio (DLNA software) to view videos, music and pictures off my PC. It also plays files off of USB. It also has a decent app selection.
SMP-N200 Manuals & Specs
post #141 of 142 Old 03-13-2015, 07:43 AM
dc_pilgrim's Avatar
Does any one know if Netflix has plugged the analog hole? I run one of my N200's in the gym, hooked up via component cables to an old HD CRT and my wife said the last time two times she tried to use it she got a licensing error message. I haven't gotten down there to mess with it (or, ah, use the gym) but it sounds to me like Netflix may be requiring HDMI for some of its content. She was trying to watch tv shows (Parenthood and Breaking Bad).
I searched in the forums and didn't see anything, so I dragged this thread forward.
I have tivo mini with component cables that I haven't hooked up (need to fish wires, first attempt went horribly awry), and if that works or if the N200 just needs a software update then I'll keep the beast around. Otherwise it will be time for the gym to enter the HDCP age.
EDIT - False alarm. Component seems to be working fine now.
dc_pilgrim is offline
post #142 of 142 Old 06-01-2015, 06:22 PM
john79605's Avatar
I found 72 3D movies for rent in the Video Unlimited ap. I don't yet have bandwidth for HD, much less 3D, so I can't test this. I have a 3D tv and I've managed 3D photos with the n200. Has anyone streamed 3D on an n200 and will Video Unlimited actually stream 3D to it? The same 3D section shows up on my s370 which isn't 3D capable, so having them listed isn't proof they will work.
john79605 is offline
