*Official* Roku 2 Media Streamer Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #901 of 1163 Old 03-02-2013, 11:25 AM
elphillips's Avatar
Quoted: 271 Post(s)
Liked: 189
Originally Posted by Gary J View Post
Don't know what a OPPO BD105 is but buffering means a weak network signal not a Roku defect.
Originally Posted by michaeltscott View Post
What connection on the Roku is connected to what connection on the OPPO? What Roku model do you have?
Sorry, should have mentioned this was on VUDU. The OPPO is a blu-ray player. The ROKU looks like a large thumb drive that plugs into one of the three HDMI ports on the player. I will try one of the other HDMI ports and see if that makes a difference. Thanks for your concern.
LG OLED 65 E6P, OPPO UDP-203, Yamaha CX-A5100 AVP
elphillips is offline
post #902 of 1163 Old 03-02-2013, 11:29 AM
wkearney99's Avatar
Quoted: 342 Post(s)
Liked: 131
Originally Posted by elphillips View Post
First post here. I'm using a ROKU plugged into a OPPO BD105. Tried to watch Life Of PI last night. The movie was interrupted several times saying it was "buffering". Then said it could not support HDX and move down to HD to continue the movie, which I did. Then more buffering notices. Then, 10 minutes from the conclusion of the movie it stopped and said "network error, try again later" and that was the end of the movie for me. As the Vudu FAQs instructed for buffering I pulled the RUKO drive for several minutes and reinserted it and that did no good. Very poor experience. I will continue to buy my movies on discs.
Did you try it just plugged straight into your TV, not looped through the Oppo? Do that first to rule out the Oppo as a possible problem.
But it's more likely an issue with the speed and throughput of your home network internet connection, not the Roku. What does using a website like speedtest.net have to say about your internet speeds? Not just what your ISP says you get, test it. If you don't have a fast enough link then just about any player is going to have problems, not just a Roku. Some might hide this better for you by defaulting to a lower resolution or silently dropping back.
That and did you have other big transfers going on at the same time? Like something else downloading or streaming? Those would also affect streaming performance.
So I doubt it's the Roku as the problem there...
wkearney99 is offline
post #903 of 1163 Old 03-02-2013, 11:36 AM
elphillips's Avatar
Quoted: 271 Post(s)
Liked: 189
Thank you, I'll check the network speed out. This ROKU device is sold by OPPO specifically for their players. http://www.oppodigital.com/proddetail.asp?prod=RokuSSB
post #904 of 1163 Old 03-02-2013, 11:58 AM
michaeltscott's Avatar
Quoted: 2844 Post(s)
Liked: 1516
That's a product called the "Roku Streaming Stick"; anyone can buy it and use it with any device with an MHL input.
You can test available network bandwidth in your VUDU player, under the My VUDU tab "Info & Settings" section. It'll tell you the best quality level you can currently handle. I think that have to sustain a minimum of 6 Mbps for HDX, and 9 Mbps for the highest quality.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #905 of 1163 Old 03-02-2013, 12:31 PM
elphillips's Avatar
Quoted: 271 Post(s)
Liked: 189
I moved the Roku stick from the front of the OPPO player to the rear, giving it a little better line-of-sight to the router. This got the Vudu signal up to 4.5 which Vudu says I can use HDX. That must be barely the minimum. I'll will contact my provider, Cox, and see if I can upgrade my download speed. Speedtest.net shows 34.01 currently. I appreciate your help very much. Learned a good deal about Roku this morning.
My provider is increasing my internet speed from 50 Mbps to 150Mbps. That should do it.
post #906 of 1163 Old 03-02-2013, 12:46 PM
undecided's Avatar
Quoted: 123 Post(s)
Liked: 80
If the 34.01 is Mbps that's more than sufficient for Vudu HDX. What device did you measure the 34.01 on and how was it connected to the router - Wired or Wireless?
It sounds like the issue is your Wireless connection speed to the Roku.
What kind of router and at what distance is the Roku from the router?
undecided is offline
post #907 of 1163 Old 03-02-2013, 12:55 PM
Liked: 1516
I don't know that the speed increase is going to get you better wireless speed. Let us know if it does.
4.5 Mbps is the bare minimum for HDX, "1 bar"; 3 bar HDX is noticeably sharper.
post #908 of 1163 Old 03-02-2013, 01:06 PM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
It will be like the Phoenix Suns winning their next game by 40 points instead of 10.
30 points they didn't need.
Gary J is offline
post #909 of 1163 Old 03-02-2013, 01:32 PM
elphillips's Avatar
Quoted: 271 Post(s)
Liked: 189
The 34.1 is from speedtest.net, wired from the modem to the router if that is what you are asking. The router is a Netgear and is about 20 feet from the Roku stick. I have ordered a Male to Female HDMI cord which will allow the Roku to be about 15 feet from the router and full line-of-sight.
post #910 of 1163 Old 03-02-2013, 02:03 PM
RichardCarver's Avatar
My DL speed is 11mg and using wireless, I am trouble free on NF 99% of the time. There may be more to your situation than DL speed.
LR: Vizio E701i-A3, Vizio VSB207 sound bar, Sony BD390 BR, Roku 3.
BR: Vizio E601i-A3, Sharp (disc.) sound bar, Sony BD390 BR, Roku 3
RichardCarver is offline
post #911 of 1163 Old 03-02-2013, 02:24 PM
undecided's Avatar
Quoted: 123 Post(s)
Liked: 80
Yes you have plenty of download speed - so it is likely to be the connection between the router and Roku.
Do you know the model number of the Netgear router? How old is it? What wireless standards does it support?
At 20 ft you really shouldn't have problems router unless there is a lot of interference or some other major obstruction between the router and Roku.
You may want to look at this as well.
http://support.roku.com/entries/420570-how-do-i-improve-my-roku-player-connection-to-content-servers
post #912 of 1163 Old 03-02-2013, 02:42 PM
wkearney99's Avatar
Quoted: 342 Post(s)
Liked: 131
This is correct. It does not that much to deliver a single stream, provided the link isn't also swamped by other traffic at the same time.
I'd wonder how well your wireless network is functioning. Whether you've got interference or other factors that might be slowing it down. One test would be to use a PC connected wirelessly and do the speedtest again. Doing it with a wired connection only tells you the wired speed, not the wireless. That and what netgear router are you using, and how is it's wifi speed configured. Could be it's not a very fast router or it's not configured to use a faster speed.
So figure that stuff out first before dumping on the Roku gear...
post #913 of 1163 Old 03-02-2013, 03:16 PM
elphillips's Avatar
Quoted: 271 Post(s)
Liked: 189
Sorry I dumped on the Roku gear. Trying different things, I rebooted the router and now have 9+ on the vudu scale. Mr Kearney is correct. the problem was with the router.
post #914 of 1163 Old 03-02-2013, 03:21 PM
Aero 1's Avatar
Quoted: 337 Post(s)
Liked: 169
Go search in the roku forums. There apparently is an issue with the vudu channel. I believe it's still not fixed, but I might be wrong.
Cord Cutter | OTA - NYC DMA - 6 TB TiVo Roamio - 3 TiVo Mini's | Plex Pass | Netflix | Hulu | Amazon Prime | MLB.tv & MLS Live with No Blackouts!
Aero 1 is offline
post #915 of 1163 Old 03-02-2013, 03:26 PM
rdgcss's Avatar
Quoted: 90 Post(s)
Liked: 38
My son had a 3 year old Linksys router and was having all kinds of streaming problems. Being an Apple fanboy he bought an Apple Airport Extreme router and all his problems disappeared. I personally think there is nothing like a hard wired connection, of course that is not an option with the Roku Stick. My 2XS is connected via Cat6 to a gigabit network to a gigabit router connected to a 50/5 Internet connection, needless to say I don't have streaming problems.
rdgcss is offline
post #916 of 1163 Old 03-02-2013, 03:38 PM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
Yes, we know.
Gary J is offline
post #917 of 1163 Old 03-02-2013, 11:34 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
He has a very high end blu-ray/streamer (Oppo 105) Assume he's using a Roku stick to USB. I'm disappointed to hear this as I was considering the same setup.
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
post #918 of 1163 Old 03-03-2013, 06:17 AM
wkearney99's Avatar
Quoted: 342 Post(s)
Liked: 131
Glad to help. Given all the layers of stuff that's involved it's important to make sure they're all configured right and running properly. Hard to do sometimes, especially when it's only something new that 'seems' to have problems. Lots of times there's been something else going wrong for 'a while' and the new stuff just happens to make it obvious.
There's a lot of crappy routers out there. That and wifi for bulk traffic is just really never a great idea. Combine the two and, well, you've seen what it's like. Me, I favor using a wired connection whenever possible and to keep the wireless network as lightly loaded as possible.
post #919 of 1163 Old 03-03-2013, 08:58 AM
rdgcss's Avatar
Quoted: 90 Post(s)
Liked: 38
+1
rdgcss is offline
post #920 of 1163 Old 03-03-2013, 09:41 AM
Anyone have a link for info on the new Roku?
post #921 of 1163 Old 03-03-2013, 10:23 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Go to roku dot com / streamingstick
scirica is offline
post #922 of 1163 Old 03-03-2013, 10:40 AM
Oh, I thought there was a new box or something. Not too many sets 'stick ready' at this point. I'm pleased its the stick, I just bought a new 2.eek.gif
post #923 of 1163 Old 03-03-2013, 10:56 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
I have to 2 xs myself. Works great.
scirica is offline
post #924 of 1163 Old 03-03-2013, 12:12 PM
rdgcss's Avatar
Quoted: 90 Post(s)
Liked: 38
Do a Goggle search for "Roku 3"
rdgcss is offline
post #925 of 1163 Old 03-03-2013, 02:36 PM
Dammit, good thing these are relatively inexpensive, I seem to be buying one a year. Of course, my relatives love the hand me downs.
post #926 of 1163 Old 03-03-2013, 08:55 PM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
March 8th.
apw2607 is offline
post #927 of 1163 Old 03-03-2013, 09:22 PM
UHD Addict
aaronwt's Avatar
Quoted: 5949 Post(s)
Liked: 3651
It's March 8th now? I thought people said it was March 6th at first? The same day as the TiVo Mini gets released.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #928 of 1163 Old 03-03-2013, 10:50 PM
Buckeye911's Avatar
Here it is. http://www.zatznotfunny.com/2013-03/roku-3-remote-sports-a-headphone-jack/
The measure of a man's character is what he would do if he knew he never would be found out.
Buckeye911 is offline
post #929 of 1163 Old 03-04-2013, 06:28 PM
subavision212's Avatar
Quoted: 62 Post(s)
Liked: 38
"Sorry, should have mentioned this was on VUDU. The OPPO is a blu-ray player. The ROKU looks like a large thumb drive that plugs into one of the three HDMI ports on the player. I will try one of the other HDMI ports and see if that makes a difference. Thanks for your concern."
Pretty sure you can only plug the Roku stick into the front HDMI port. It's the only one that is MHL.
subavision212 is offline
post #930 of 1163 Old 03-04-2013, 07:17 PM
Bob58's Avatar
I rarely use Vudu but had never had a problem until 3 days ago. I rented Argo and was immediately confronted with the dreaded constant (every 45 seconds to 2 minutes) rebuffering on all quality levels. It was simply unwatchable.
So I gave up on Vudu for the night and immediately started streaming Amazon and Netflix HD with absolutely no issues. The problem was clearly Vudu.
The next morning, I tried again. Same thing. After reading up on the Roku forums, I found that I was not the only one to experience such issues with the Roku Vudu channel over the last month or two. First I followed the advice to try and run the speed test from within Vudu. I could NOT even run the test because of a network error. So I followed the next recommendations to delete the Vudu channel, reboot the Roku and reinstall the channel.
That worked perfectly. I then ran the speed test and easily maxed it out. I played Argo without a single hiccup or glitch.
Speculation on some forums is that there is some conflict between Netflix and Vudu Roku channels that Vudu needs to fix since their's is the only one that seems to "break" after using other services.
I don't know. But I do know that I am NOT going to go through that nut roll everytime I want to use Vudu. If it keeps working for me, great. If not, I'll stick with Amazon and Netflix.
Vudu is great for rentals of the newest titles available at the highest streaming resolutions available at a higher cost. But it isn't worth it if it stays buggy.
Bob58 is offline
