Review of Netgear WNDR3800 Wireless N600 Router - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 09-08-2011, 08:40 AM
Norm's Avatar
Amazon UK hasn't even heard of the WNDR3800. I am tempted to order from Amazon.de as the price with shipping will still be less than the UK price.
Regards
Norm
Norm is offline
Old 09-08-2011, 09:22 AM
sudhakary's Avatar
I got my wndr3800 from buy.com yesterday. Waiting for this router since Mar'11. I did setup lastnight, so far everything is great. I replaced my linksys router. this one is little bulky in size compare to linksys.
I setup my network for 2.4 and 5 Ghz, and guest network for the same and a video network for 5Ghz.. I can see 2.4 network in all my devices, but 5Ghz in only Roku not in my PC at all. And i can see 5 Ghz on and off in my touchpad.
What needs to be done to see the 5Ghz on my pc. My PC will definetly supports 5 Ghz. this is latest HP laptop support b/g/n network.
I will do somemore tests tonight.
In one word this router is great working so far.
sudhakary is offline
Old 09-08-2011, 09:40 AM
cburbs's Avatar
Quoted: 94 Post(s)
Looks like my local Frys has this in stock. I may check it out and see if it is better than my Dlink Dir655.
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
Old 09-08-2011, 11:26 AM
dpeagle's Avatar
you might try going into your device mgr opening network adapters, going to advanced settings and see if you need to turn on the 5ghz band. if you dont have the option your adapter does not support it and you would need to use a dual band usb adapter. just because your computer is new and supports b/g/n does not mean it supports dual band n.
dpeagle is offline
Old 09-08-2011, 03:03 PM
robholding's Avatar
I'm looking to buy a WNDR3800 as soon as they are available.
The question I have is; Does anyone one know the difference between these two model numbers?
WNDR3800-100UKS
WNDR3800-100PES
I have found both part numbers on different website:
broadbandbuyer.co.uk
£136.55 including vat
cbccomputers.com
£128.74 including vat
Thank you all
robholding is offline
Old 09-08-2011, 03:46 PM
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
Can someone please explain how I set the router to broadcast only in N? I think I change something from 20 to 40, but I'm not sure where to do it at?
Gronnie is offline
Old 09-08-2011, 05:28 PM
dpeagle's Avatar
WNDR3800-100UKS
WNDR3800-100PES
cbccomputers.com
Thank you all
only a guess but the first one might be a UK model. i dont know what country the PE would be.
dpeagle is offline
Old 09-08-2011, 10:49 PM
StratmanX's Avatar
Quoted: 32 Post(s)
WNDR3800-100UKS
WNDR3800-100PES
cbccomputers.com
Thank you all
See this from an earlier post on this thread.
StratmanX is offline
Old 09-09-2011, 10:44 AM
cburbs's Avatar
Quoted: 94 Post(s)
Ok so I got the 3800 yesterday from Frys - Giving it a whirl against my old trusty Dlink DIR 655 that I have owned for a while now.
In the small pamphlet there is talk about "Video Mode". The interesting thing is it mentions to use "Guest" wireless for your streaming devices. Correct me if I am wrong here but Guest is for Internet only so that defeats the purpose of streaming etc unless they mean for Internet streaming only?
In my mind media streaming devices are for streaming netflix/youtube etc plus your own video files so this then would defeat the purpose of this "Video Mode".
cburbs is offline
Old 09-09-2011, 10:48 AM
cburbs's Avatar
Quoted: 94 Post(s)
This looks like it is setup differently than my Dlink so I can see the confusion.
In the mode option you have the default 130. The other options are 54 and 300.
If you have newer N devices I would suggest selecting 300.
Also this helped out as well though based on an older Netgear it still gives you the general info -
http://documentation.netgear.com/dg8...eless.4.3.html
cburbs is offline
Old 09-09-2011, 11:48 AM
dpeagle's Avatar
just did the 1st firmware update. one click and its all done. no complicated process. i like this thing more and more each day. does anyone have a link to the release notes for this update. v1.0.0.18
dpeagle is offline
Old 09-09-2011, 12:17 PM
carsc9999's Avatar
Fry's in Arlington, TX now has the 3800. Interesting though, they also have the newest of the new Netgear WNDR4500. It is not on their website but I held one today. Ended up going with the 3800. Listed at 149.99 vs the 4500 at 179.99. 4500 may be a bit faster and has 2 USB ports. Also billed as having greater range. However, there is no mention of the Ready Share Cloud or Clear Channel. I find it a bit strange that the 4500, as of today, isn't on Netgear's website and there is very little info the web about it.
carsc9999 is offline
Old 09-09-2011, 12:26 PM
cstmstyle's Avatar
Quoted: 14 Post(s)
I got the update as well. I left my HTC Incredible connected during the upgrade and something I never seen happen before started. Once the firmware was installed and I confirmed internet access on the computer was working I tried to browse to a website from the phone and every page I tried said I needed a username and password. It was weird because the pages loaded as if I needed a login for those sites but it was the router asking for the authorization. As I never seen that happen before I figured I would share. Once I rebooted the phone everything loaded as normal.
Xbox Live- DragonsLee
"I'm not in this world to live up to your expectations and you're not in this world to live up to mine." - Bruce Lee
cstmstyle is offline
Old 09-09-2011, 01:11 PM
cburbs's Avatar
Quoted: 94 Post(s)
Yeah I forgot about that. The guy goes there is this new model. I didn't even look at it since it was priced at 179.
Saw the update this morning and did that as well.. The odd thing is with mine I lost my settings I had changed.
cburbs is offline
Old 09-09-2011, 02:12 PM
dpeagle's Avatar
i did the same thing. forgot to back up my settings and lost them all. cost me about an hour.
dpeagle is offline
Old 09-09-2011, 02:28 PM
plaver's Avatar
Did you manage to get hold a 3800 from Amazon.de
Best Regards
PioneerPDP-506XDE, Pioneer DV-989AVI-S, Denon AVR-4306, Humax 9200T, Sony Freeview VTX D800U, Pioneer DV-565A,6x Keff Eggs, Sony PSP (Black & White) XBOX 360
plaver is offline
Old 09-09-2011, 03:15 PM
cburbs's Avatar
Quoted: 94 Post(s)
WNDR3800 Firmware Version 1.0.0.18
Note: Do not upgrade the firmware using a wireless connection. Please perform firmware upgrade with “wired” or Ethernet connection only.
New Features and Enhancements:
For Non-journal system, support Time Machine backup size up to 1 TB.
For Journal system, support Time Machine backup size up to 500 GB.
Known Issues:
Time Machine function limitation: Only support “GUID Partition Table” and “Master Boot Record” in partition table format. We don’t support “Apple Partition Map” this format.
Workaround: When you choose the partition scheme of your USB disk, please don’t select “Apple Partition Map” this format.
Traffic meter - Traffic volume control is not accurate due to sampling rate. It may exceed the limit.
Workaround: Set a proper number in “Mbytes before the monthly limit is reached” in the traffic control.
cburbs is offline
Old 09-09-2011, 06:04 PM
tietack's Avatar
Got the router yesterday. While I appreciate the ease of installation, I purchased the router with two things in mind:
1) Security
2) Time Machine support
When I run nmap on the router, I get a number of odd open ports, including 548, 3333, 5555, 8200, 20005. Seems like a big security hole to me.
I've updated the router to firmware version 1.0.0.18, which is supposed to enable Time Machine support of 500GB or 1TB, depending on the format.
Been on chat with Netgear support for over an hour. And all they did was tell me to contact Apple w/r/t why OSX 10.6 doesn't see the shared USB drive, and gave me faulty instructions on how to disable the noted ports (all security holes IMO). Netgear support just dropped me, after not wanting to verify the existence of Bob Silver (as a Netgear consultant).
Netgear chat stopped after just over an hour.. Looks like they've hung up on me.
tietack is offline
Old 09-09-2011, 06:20 PM
Joewalls123's Avatar
I have to say I am now getting somewhat irritated. I have been waiting for the WNDR3800 here in the UK for months now. Previously, I was told 23 August. Then I see it is now available Stateside. Last week Netgear UK told my reseller they would have it within 5 working days so I thought that was great news. Just checked with my reseller again and guess what Netgear UK have told them - yes, 5 working days! So it looks like they are just making up stories because they have no idea what is going on.
I hope Bob can find out some accurate information as this is really getting ridiculous!
Yep I hear what your saying.
I found 5+ uk resellers which had it listed on their website as out of stock, contacted them all and they all pretty much said they have no idea when they'll get them from Netgear.
I contacted Netgear and they told me the uk won't get them until next quarter... This is a joke!
Joewalls123 is offline
Old 09-09-2011, 10:39 PM
N_Da_Game's Avatar
1) Security
Technical support and customer service teams would not know any consultants by name or how many exist. Consultants and VARs (Value Added Resellers) have a separate support structure that gives them direct access to the engineers.
N_Da_Game is offline
Old 09-09-2011, 11:21 PM
tietack's Avatar
Dear N_da_game,
while what you say would not surprise me, it still seems illogical, as any customer who tries to get up to speed based on available Internet resources would first read what consultants and VARs say.
In any case, some regular customer on the Netgear forum suggested http://support.netgear.com/app/answe...ail/a_id/19136 , which makes a heck of a lot of sense, will try it shortly. All the Netgear tech needed to do was point me in that direction, instead of running around for an hour before (virtually) hanging up on me.
tietack is offline
Old 09-09-2011, 11:25 PM
Norm's Avatar
I didn't confirm an order yet. I went through the process just to check there would be no problem shipping to the UK but I thought I would wait a little longer as they also are not in stock yet. If stock is available there first, I will definitely place my order there.
Regards
Norm
Norm is offline
Old 09-10-2011, 01:07 AM
seattlegeek2's Avatar
Originally Posted by BigCTM View Post
...I am so sick and tired of the Belkin N750 requiring restarting all the time.
I was having the same problem with the Belkin N750. The wireless connection on my iPhone and iPad would get about 10% slower per hour until I rebooted. After several hours it would crawl. I turned off UPnP on the router and it doesn't slow down anymore, however I still plan on returning it to Costco.
I have a new WNDR3800 sitting on my table but want to know more about the WNDR4500 before opening it up. Also wish SmallNetBuilder.com would do an in-depth review of the WNDR3800.
seattlegeek2 is offline
Old 09-10-2011, 04:54 AM
solaris72's Avatar
Is it worth to buy wndr3800 as i already own wndr3700?
I'm not using usb port at all. All i need is wired/wireless performance. Performance wise will it make any big difference?
solaris72 is offline
Old 09-10-2011, 03:18 PM
cburbs's Avatar
Quoted: 94 Post(s)
This is all I came across for on the 4500 - http://www.wikidevi.com/wiki/Netgear_WNDR4500 How can they sell it if there is no link for it -
cburbs is offline
Old 09-10-2011, 05:49 PM
Bob I've been (im)patiently waiting for the 3800 to appear in the UK.
My current Netgear WNR854T is giving up on me, it seems to drop if I have more than 2 devices connected to it, so I've been looking for a replacement and I thought the 3800 sounded perfect for me, however I've just spotted the WNDRMAC on Netgear's website, now I'm confused.
I have:
  • iPhone 4 - wireless
  • Macbook Pro - mainly wireless (n150)
  • PS3 - wired
  • Laptop - wireless (n300)
  • Laptop - wireless (g)
  • HP wireless printer (always connected)
  • Airport express (for music streaming)
  • And 2/3 android phones which are sometimes connected wireless.
  • It's a fairly big house, (not huge), I also use the devices across 2 floors, and sometimes the garden.
  • The iPhone is always connected and the mac usually is, but sometime ALL devices are connected the my router.
  • I sometimes stream films to the PS3 from the mac
  • I do plan on connecting a hard drive to the router either USB or Ethernet and plan on streaming films from there to ps3, I also plan on using the hard drive for time machine back-ups from the mac.
  • The 3800's ready share cloud looks interesting but not a need for me.
  • I also have alot of network interference (I can see approx 10 wireless networks if I do a scan)
Do you have any advice on which one is right for me?
Also any news on the 3800's time machine support? Was it fixed in the latest update?
Thanks in advance!
Joe.
Old 09-10-2011, 09:09 PM
trillix's Avatar
Hello. I purchased the WNDR from Buy.com and it arrived today, six days later.
The specs previously indicated the router would work with Mac OS 10.4.11 and now the Netgear website states "Mac OS" instead.
The install process has not gone smoothly, and the "beta NetGenie software" for Mac does not even stay open after launching -- thus only the web browser version of the admin software works. No cool network maps or diagnostics for me apparently.
Instead of auto-logging in upon the router configuring itself, I got a username/password prompt instead -- then dumbly input the SSID and Password because there was no other information about what to do in such a situation. Did this compromise my security from the start, and is it necessary to generate a new SSID and password because it was sent to an unencrypted page at routerlogin.net?
The process so far seems half-baked in terms of a Mac install, perhaps intentionally made this way?
Further, trying to set-up only the 2.4 wifi for the near-term then requires turning off the radio signal for the 5GHz band, which is done by clicking an 'apply' button for making the changes. Strangely, this does not permanently configure the wifi and the 5GHz band continues to show up after moving around other menus. It seems to have its own idea of how it wants to work and I have not yet figured out what is required to keep the 5GHz band turned off.
I read that people here were updating to the new firmware version and had not saved/stored their Router config settings, which the admin software allows. Thus, I saved my router settings, and then sought to restore them after the firmware update and it said "FAILURE" as a result -- the settings were not restored, they were invalid. Is a firmware update beyond the scope of saved router settings - what are they used for then?
My reason for writing was to find out if anyone knows how to 'name' devices that show up in the web version of the admin interface (routerlogin.net) -- i.e. specifically in the Attached Devices category where devices connected to the network are listed. I have several that I would rather have names for, and there seems to be no way to edit these, though I am to guess the NetGenie software for Mac perhaps could do this.
I tried to name a device using the "Wireless Card Access List" (under Advanced Setup > Wireless Settings ) and yet the device name does not show up in Attached Devices, though its MAC Address does and the name is linked to the MAC Address. I have another wired device that is and there is seemingly no way of naming it. No graphical network maps or speed dials for internet speed or anything, either. Not what I was expecting given the screenshots in reviews or the high praise of others experiences.
There are a significant amount of problems that were surprising to encounter and it seems almost as if my computer is unofficially unsupported, unless of course the NetGenie software for Mac will start to work on 10.4.11 very quickly here. If it stays this way, the router becomes more of a hassle to manage a network with than a time-saving management tool - and at the very least if it is not going to be supported for 10.4.11 customers should be told this in advance so as not to invest in a router that will only be a letdown in terms of using it as described.
If rating it just on an install experience and simply keeping its settings straight and an out-of-the-box 'this should work with my computer' via specs, I would give it 2 out of 5 stars. It has been quite horrible actually, in that the great experience did not materialize here on some older equipment and yet there was no mention of this being an issue. Netgear? Any ideas?
That said, the router does work and it does have a clean and well organized interface. The main reason the Netgear routers (3700 & 3800 now) were of interest is their ability to turn the WiFi signal on and off via push button. This and other functionality will make it a useful and valuable tool for a home network. Though lacking a more refined software solution is disappointing, and it will be difficult to look beyond this because the limits will be the main interface to the device, likely requiring a new PC to regain lost software functionality.
trillix is offline
Old 09-11-2011, 03:26 AM
savagepagan's Avatar
How many simultaneous connections will this handle?
Now available at newegg for $150.
savagepagan is offline
Old 09-11-2011, 06:53 AM
cstmstyle's Avatar
Quoted: 14 Post(s)
Ok due to my lack of networking skills I can't seem to figure out why my Unraid server isn't seen on the network with the new wndr3800 router. Everything worked perfect with the Asus router I was using. It seems the Netgear is blocking the connection for some reason. Anyone have this issue and what did you do to solve the problem.
Edit: oops appeared to have been a bad cable all is well
Old 09-11-2011, 10:54 AM
mjf_uk's Avatar
I am also in the UK and have been waiting for the 3800.
What I would like to know is what difference is there that usually warrants a dedicated model for the UK and why is there not going to be a UKS model of the 3800?
mjf_uk is offline
