*Official* WD TV Live Streaming Media Player Thread - Page 166 - AVS Forum | Home Theater Discussions And Reviews
 85Likes
post #4951 of 6208 Old 06-18-2014, 08:23 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
Originally Posted by zaphod7501 View Post
I'm guessing a memory leak from something in the software, an app, or firmware. When navigation slows to a crawl, I'm ready for a power cycle.
Memory leak -- that is the term I was looking for. As I noted above, I see issues every 2-3 weeks from sitting in standby that are corrected with a cold boot. I think I would prefer to shut it down completely after use but I use a Harmony remote and that can only send the power-off toggle which sends the unit into standby.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #4952 of 6208 Old 06-18-2014, 08:47 AM
Kelson's Avatar
Liked: 1147
Static IP addresses
On another note -- the networking complexity of Win-7 really aggravates me. When my Media-PC was running Win-XP, setting up SMB shares and accessing them from my WD Lives was simple and dependable. Now, unfortunately, it runs under Win-7 Pro. Win-7 has added a layer of networking complexity that my WD Lives take issue with on a random basis. One day a particular Live would be able to access the SMB shares on the Media-PC without issue while another Live would be denied access. The next day it could be the previously good Live that is now denied access. In the past this has been little more than an irritating distraction because my Media-PC is primarily a DLNA server running Mezzmo and the DLNA clients -- including the WD Lives -- never have an issue connecting to Mezzmo. However lately I've been wanting to put content on the Media-PC that would be accessed by SMB shares and so the issue has reared it's ugly head.
I can't remember where I read it but a while ago someone posted that assigning static IP addresses to the WD Lives and the server(s) they are accessing clears up a lot of network related problems. So a couple weeks ago I got around to configuring my router to reserve a static IP block and assigned all the Lives and the Win-7 Media-PC with static IP addresses. This seems to have cleared up the Win-7 SMB shares access problems I was having with the WD Lives. All the Lives now consistently connect to the SMB shares and have not been denied access as before.
So, if you are having problems accessing WIN-7 SMB shares with your WD Lives, you might want to consider converting to static IP addresses.
- kelson h
Kelson is offline
post #4953 of 6208 Old 06-18-2014, 01:07 PM
lahatte's Avatar
Originally Posted by mr266 View Post
Don't know if it's the exact same problem as you're having, but anytime I switch between movies off of the attached HDD's and Youtube, I have to reboot or I won't get any volume at all. I've just gotten used to doing that, since it's pretty quick and works great after that.
It seems like my unit had been able to get audio again for the Youtube videos after I set it back to Stereo for the audio. Lately it seems that won't do it, and it has to be rebooted. It's flaky for sure.
lahatte is offline
post #4954 of 6208 Old 06-19-2014, 02:11 PM
pg_rider's Avatar
Quoted: 75 Post(s)
Liked: 33
I recently upgraded from the original WDTV Live to the WDTV Live Streaming and the reception of my remote control has become horrible. I use a Logitech 650 remote and my WDTV sits in a cabinet with a speaker-cloth face on it. The original Live could pick up the remote signal no problem but the Streaming can barely pick it up (only if I point straight at it from 8' away or closer).
Is there a known configuration change with the Streaming hardware that may have caused this behavior?
LSA One Monitors, LSA LCR Center, LSA On Wall surrounds, dual Hsu VTF-3 subs, Denon AVR-X4000, Adcom GFA-6000 amp, UTurn Orbit turntable, Samsung UN75HU8550
pg_rider is offline
post #4955 of 6208 Old 06-19-2014, 06:43 PM
ausdavep's Avatar
Quoted: 26 Post(s)
No real issues with mine (certainly not better or worse than other devices) - you dont still have the protective plastic film over the IR receiver?
ausdavep is offline
post #4956 of 6208 Old 06-20-2014, 07:07 AM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
The supplied remote controller has two problems. Low power and the internal LEDs are not aimed straight ahead, but at about 30 degrees off center. It will actually work better if you aim it to the sides.
I took mine apart and resoldered the LEDs to point straight ahead. I also loaded an upgrade to my JP1 remote that works better. I even bounce mine off a wall.
I'm surprised your Logitech doesn't work better but it could be off frequency or use the wrong wavelength LED.
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is offline
post #4957 of 6208 Old 06-20-2014, 03:33 PM
andyross63's Avatar
Quoted: 228 Post(s)
Liked: 71
Which JP1 remote do you have? I currently use an RCA RCRP05B w/ extender.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is offline
post #4958 of 6208 Old 06-20-2014, 03:56 PM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
While I have one of those RCAs, I have bunch (6+) of the old URC6131 OneForAll remotes that I use. (with extender)
Some other alternatives for pg_rider are the apps for smartphones (if you have a wireless router) and web browsers that don't rely on IR signals.
post #4959 of 6208 Old 06-20-2014, 04:29 PM
ngabriel's Avatar
Anyone have issues with iso playback on WDTV where it will jump seemingly randomly between chapters? I've had this issue when creating mkv's from bluerays with discs containing multiple playlists but I was hoping playing back directly from the iso would avoid the issue.
ngabriel is offline
post #4960 of 6208 Old 06-20-2014, 04:55 PM
ngabriel's Avatar
Found this somewhere else, I guess its the same issue as I have when making mkv's:
> This is a WDTV problem, it picks the largest m2ts file from inside the ISO, this will be incorrect for movies with multiple m2ts files making up the main movie.
> I would recommend ripping the main movie only to MKV or similar so the WDTV can handle it properly.
> Try something like MakeMKV or wait for Slysoft's upcoming program Slyce.
ngabriel is offline
post #4961 of 6208 Old 06-20-2014, 06:58 PM
Kelson's Avatar
Liked: 1147
That was addressed in the latest firmware. If you rip the main title to iso, the WD will go to the playlist in the iso and play the segments in the order of the playlist. If you are experiencing random chapter repeats or chapters in the wrong order then you picked the wrong playlist when you ripped the BD. If you ripped the whole disk to an iso and it has playlist obfuscation, the WD can't possibly know which one to pick. You need to do the work to feed it the right playlist.
- kelson h
Kelson is offline
post #4962 of 6208 Old 06-21-2014, 01:47 PM
Dragineez's Avatar
Liked: 0
Hey, new to this forum so I'm not sure if this is the place to ask. But...
I have 3 of these. I've tried lots of others but have found the WD devices to be the best so far. Not perfect, but not the multiple issues I've had with other devices. I'm running Plex on Ubuntu and all of the devices have no problem streaming content from it.
What I'd like to try next is dumping my cable set top boxes. I'd like to get a cablecard device and use that through the WD devices. Most DCA compliant multi-streaming devices I've researched so far require Windows Media Server in order to get the guide and using your computer as a DVR. Not a problem, I have an always on Win 7 machine that could handle that chore. Cable provider is Verizon FIOS.
Does anyone know if this will work? Any suggestions on a cable card device? I don't want to throw a couple hundred bucks at something only to find out it won't work.
Thanks in advance for any advice.
Motorcycle roadracing - as a matter of fact it IS rocket science.
Dragineez is offline
post #4963 of 6208 Old 06-21-2014, 03:27 PM
Toys7505's Avatar
Quoted: 69 Post(s)
Liked: 26
I know you can put a Hauppauge WinTV (USB adapter) on the WD SMP for getting OTA reception HD channels but not sure if a "cablecard" device will work in tandem with the SMP. Cablecard devices to use with Win7 & WMC are HD Homerun and Ceton InifiTV - either gives you 4 or 6 tuners to work with. You would also need to convert the WTV file to something the SMP can play too......
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
post #4964 of 6208 Old 06-21-2014, 04:14 PM
Dragineez's Avatar
Liked: 0
Toys
Thanks for the quick response! I've decided to experiment with the HD HomeRun, though with only 3 channels I don't think that will be my long term solution. I want to gain some experience with this so I can forever ditch the Verizon set top boxes. Watched an interesting YouTube video where the guy said you can add a Windows Media Server as a channel in Plex and still get the channel guide and encrypted channels. A sort of media server to media server hand off. I'm curious to see if this will work. Also interested to see if I can DVR files to the Ubuntu SMB RAID shares. I figure if I can lop $35 a month off my cable bill the pay back time frame should be pretty short.
post #4965 of 6208 Old 06-23-2014, 02:01 AM
bobniborg's Avatar
I have cut the cord and I am interested in your success. Please update after you try it out. Thanks
bobniborg is offline
post #4966 of 6208 Old 06-23-2014, 08:40 AM
Kelson's Avatar
Liked: 1147
You can install multiple HD HomeRuns -- i.e. two for 6 tuners. WMC will use all the tuners without issue. The only bad part is that Verizon FIOS really rips you off charging $5/cable card/month. I don't think anybody is higher than that.
- kelson h
Kelson is offline
post #4967 of 6208 Old 06-23-2014, 08:01 PM
Dragineez's Avatar
Liked: 0
The HD HomeRun won't be delivered until early July, so I'm sure I'll have a ton of questions when it arrives. Thanks for all the help!
post #4968 of 6208 Old 06-24-2014, 09:37 PM
totalkonfuzion's Avatar
Hey guys, anyone have issues with 2 channel DTS audio not working right? I have a series that's in 2 channel DTS (In The Flesh) and it's definitely being detected by the WDTV Live as DTS and it should be DTS 2 channel (not surround), but my Denon 591 is pumping it out in Pro Logic II. I'm thinking maybe 2 channel whatever always gets converted to PLII by my Denon? Regular DTS 5.1 seems to work great. Sooo confused, lol.
totalkonfuzion is offline
post #4969 of 6208 Old 06-25-2014, 06:13 AM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 168
There is definitely a setting in the Denon that always turns stereo into simulated 5.1. Look for a "surround mode" button and press that while a stereo track is playing and see if it cycles around to a stereo option.
Nickff is offline
post #4970 of 6208 Old 06-25-2014, 07:27 AM
Kelson's Avatar
Liked: 1147
Does anybody have any experience using the Live-SMP DLNA client with Plex Media server?
I use Mezzmo as my DLNA server for the Live-SMP's running on a Win-7 Pro Media-PC. Plex has recently gotten my attention for two reasons:
  1. I'm getting into Linux and setting up an Ubuntu box as a media server. Plex has a Linux build and Mezzmo does not.
  2. The Plex website trumpets DLNA support
Originally Posted by Plex web site
World class DLNA support built
right in
Plex makes your media beautiful on thousands of DLNA certified devices like the PS3, Xbox 360, and WDTV Live devices without the need to install dedicated apps. Harness the power of the most sophisticated DLNA server available to effortlessly stream nearly any format to your device, right out of the box.
I would appreciate hearing from anybody who has or is using Plex to serve the Live-SMP DLNA client. If need be we can start a new thread.
- kelson h
Kelson is offline
post #4971 of 6208 Old 06-25-2014, 08:22 AM
ZmHD69PigQ's Avatar
I have the WDTV live hub and have been getting double subtitles on netflix (only for subtitled foreign language parts). Does anybody know how to correct this? I'm not even sure if it is a netflix problem or a WDTV problem. One set of subtitles is white and the other is yellow and a different font, and is right on top of the white subtitles.
This is while watching Orange is the new Black. Attached picture isn't mine but is the same thing I am seeing.
ZmHD69PigQ is offline
post #4972 of 6208 Old 06-25-2014, 08:03 PM
DeadEd's Avatar
Quoted: 85 Post(s)
Liked: 166
I suspect this is because of hard-coded subs on the program being brodcast. If you turn off subtitles you will probably only get one set.
Dyslexics are teople poo.
DeadEd is offline
post #4973 of 6208 Old 06-26-2014, 10:13 PM
Figured it out! Thanks man! I wasn't looking hard enough for the little DTS icon on the top left, lol.
Is anyone else as of late having issues with their WDTV Live SMP just hard locking and stop responding to the remote? This mostly happens when I have a programmed paused and I try to replay it. This happened when I had a windows share on a desktop PC and is now happening from my NAS via a samba share as well.
I haven't tried playing anything off a USB drive, but this has been happening more frequently as of late. Firmware is up to date and files being played are usually MKV. I'm almost wondering if I shouldn't let Twonky do the work and stream that way. I know i'd loose out on some quality more than likely, but it might be less problematic than streaming off a samba share, if that's even the issue.
post #4974 of 6208 Old 06-26-2014, 11:31 PM
lahatte's Avatar
Mine has crashed a couple of times in just a few uses. Only solution is to unplug it.
lahatte is offline
post #4975 of 6208 Old 06-27-2014, 09:59 AM
cc_in_oh's Avatar
Quoted: 917 Post(s)
Liked: 523
Plex app
Not sure if this is relevant to SMP users but Amazon's "free app of the day" today includes Plex, normally $5 I think...
CC
CC
Who knew "flammable" and "inflammable" mean the same thing???
cc_in_oh is offline
post #4976 of 6208 Old 06-27-2014, 12:40 PM
johnBlanker's Avatar
Quoted: 410 Post(s)
Liked: 68
Kelson, don't you have tv dvd rips that you need the menu support for? Plex is dlna no?
johnBlanker is offline
post #4977 of 6208 Old 06-27-2014, 02:17 PM
cc_in_oh's Avatar
Quoted: 917 Post(s)
Liked: 523
File management
My files are spread out over 3 network shares, a USB drive on the SMP and some other "archival" USB drives. It's become a big mess, especially since I had to return my Seagate GoFlex for replacement, so I've been looking for a utility to help get things back under control. I found Ashisoft Duplicate File Finder and it actually looks pretty decent. I was wondering if anyone else has used it, or can recommend another good (hopefully free) utility to help manage several disks of content?
(I know I need something like a Synology NAS but the bucks for that just aren't there right now)
CC
CC
cc_in_oh is offline
post #4978 of 6208 Old 06-27-2014, 02:55 PM
Kelson's Avatar
Liked: 1147
John, I'm always looking to complicate my life.
- kelson h
Kelson is offline
post #4979 of 6208 Old 06-27-2014, 08:54 PM
lahatte's Avatar
Stereo with Digital Passthru
Can someone verify if stereo audio works properly if the WD Live TV audio is set to digital passthru?
Clay
lahatte is offline
post #4980 of 6208 Old 06-28-2014, 04:01 AM
ausdavep's Avatar
Quoted: 26 Post(s)
Clay
I've played plenty if videos with stereo output bitstreamed. What issues are you having? Is it an issue if whatever device the audio is being bitstreamed to not being able to decode the stream?
ausdavep is offline
Western Digital Wd Tv Live Streaming Media Player Wifi , Western Digital Wd Tv Live Streaming Media Player
