*Official* WD TV Live Streaming Media Player Thread - Page 173 - AVS Forum | Home Theater Discussions And Reviews
 71Likes
post #5161 of 6136 Old 08-23-2014, 12:51 PM
mmiicc's Avatar
Originally Posted by cc_in_oh View Post
Why wouldn't it be connected to the internet?
I don't know many people with the WD and those that have it don't have internet and don't even upgrade their firmware.
mmiicc is offline
post #5162 of 6136 Old 08-23-2014, 01:36 PM
cc_in_oh's Avatar
Quoted: 748 Post(s)
Liked: 378
Maybe so - I don't stream directly from the internet myself (I use PlayLater to record and VideoReDo to edit internet content before watching as a local file). I think most posters here are heavily oriented to local file content, but even so they typically might use Youtube occasionally...
CC
Who knew "flammable" and "inflammable" mean the same thing???
cc_in_oh is offline
post #5163 of 6136 Old 08-24-2014, 12:31 PM
fmedrano1977's Avatar
Quoted: 232 Post(s)
Liked: 65
Ok, so I'm trying to add tv shows, but I get no meta data found error. Folders are structured as ShowName/Season #/ 01 EpisodeName. Mkv
My structure wrong? If so, what's the proper structure?
Sent from my HTC One_M8
fmedrano1977 is offline
post #5164 of 6136 Old 08-24-2014, 12:52 PM
cc_in_oh's Avatar
Quoted: 748 Post(s)
Liked: 378
Episode titles don't matter - they just need to start like "NCIS S01E01 "...
CC
cc_in_oh is offline
post #5165 of 6136 Old 08-24-2014, 01:32 PM
Quoted: 232 Post(s)
Liked: 65
ShowName /Season# /S01E01.mkv
That sound about right?
post #5166 of 6136 Old 08-24-2014, 04:21 PM
cc_in_oh's Avatar
Quoted: 748 Post(s)
Liked: 378
The filename can include the title, so
NCIS S01E01 Pilot
and
NCIS S01E01 Yankee White
will both work, and I think lower case s01e01 works OK.
All that matters is the correct series name + SnnEnn - the XML filename will match the MKV or MP4 or whatever filename, but the title IN the XML may be different from the filename. If the XML file is present, the title contained in it is what the SMP will display. Just try a few and you'll see how it works...
Edit> But note that the XML title might not be as well-formed as your filenames, and the list may not be ordered neatly. You can edit the XML manually or with a program (I used an Excel macro) to get clean titles, but personally I found the whole process to be far more trouble than it was worth for TV episodes...
CC
cc_in_oh is offline
post #5167 of 6136 Old 08-24-2014, 06:54 PM
WDFan1970's Avatar
Quoted: 157 Post(s)
Liked: 50
..or use a third party tool like The XML Fetcher, it doesn't care what your naming scheme is.
WDFan1970 is offline
post #5168 of 6136 Old 08-25-2014, 05:39 PM
Quoted: 232 Post(s)
Liked: 65
Thanks a bunch! Couldn't have been much easier.
post #5169 of 6136 Old 09-02-2014, 02:41 PM
andyross63's Avatar
Quoted: 131 Post(s)
Liked: 49
Anyone notice that the WDTV Live SMP's Netflix streaming seems to be limited to 720HD now? If you try the El Fuente or sample video, it stops at the 3000k bitrate. It is NOT a congestion issue, as others with WDTV's and many other devices seem to have suddenly been hit with this. On mine, I have a 25/5 connection, and a visible Ethernet switch to watch the activity. Once the buffer fills (only takes about 10-15 seconds), it then stops and buffers as normally. If anything, the buffer refills are now much further apart due to the lower bitrate.
I have NOT updated to the latest firmware, but still have the previous one. This has been reported by some with the new firmware, too.
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is offline
post #5170 of 6136 Old 09-03-2014, 07:15 AM
jkasanic's Avatar
Quoted: 296 Post(s)
Liked: 112
I'm still getting 1080HD and I also haven't upgraded to the new firmware. I've got a 50/5 wired connection to the SMP. My ISP is TWC if that matters.
jkasanic is offline
post #5171 of 6136 Old 09-04-2014, 03:48 PM
runcliffyrun's Avatar
I am having a little problem at the moment. I have a 1 month old WD TV Live that I am using attached to a 3TB WD external hard drive (has less than 2TB on it) .
Its been working fine, but then today after I added some new mkv files the player was not able to see the hard drive. I always eject before removing the hard drive, and the laptop still reads the hard drive OK. Changing from front to back usb did nothing. I tried a reset and a restart - nothing from that either.
Any ideas?
Behringer B212XL (x3), Axiom QS8 (x2), SVS PC12 NSD, PB1000 (x2) . Onkyo TX-NR818. Mini DSP 2x4. Sony BDP-S3200. Samsung PS50B650 . Epson 8350 Projector, Grandview pulldown 92" screen, Aura Bass Shakers (x3).
runcliffyrun is offline
post #5172 of 6136 Old 09-04-2014, 05:24 PM
Quoted: 232 Post(s)
Liked: 65
You are correct, it also gets summary, imdb ratings, etc..
post #5173 of 6136 Old 09-04-2014, 06:15 PM
Lee Smith's Avatar
Any ideas?
I had this happen a couple of times and I had to delete the .wdtv folder. It should be a lop level folder.
The symptom that this might be a potential problem is the WD TV Live continues blinking but the hard drive has stopped blinking.
Hope this helps.
Lee Smith is offline
post #5174 of 6136 Old 09-04-2014, 08:46 PM
Thanks but that didn't work.
I tried another drive and that worked fine.
I attach the 3TB and it says "connecting to the USB storage" and for around 3 seconds the WDTV blinks and the hard drive blinks and then they both go steady blue light.
Then when I try to Select Content Source: Local Content the player says "No storage present"
any more thoughts?
thanks
post #5175 of 6136 Old 09-04-2014, 09:27 PM
techflaws's Avatar
Quoted: 125 Post(s)
Liked: 65
I experienced this only once so far and checking the disk for errors in Windows helped.
Tech Flaws
Things can only get better
techflaws is offline
post #5176 of 6136 Old 09-04-2014, 09:38 PM
Disk checked - no errors found. Still no good.
Anyone else?
post #5177 of 6136 Old 09-04-2014, 10:43 PM
Well, I just plugged into the bluray player and played the start of a mkv file. Then when I plugged the hard drive back into the WDTV it now sees all!
thanks for the help.
post #5178 of 6136 Old 09-08-2014, 06:57 AM
Kyrt's Avatar
It would be an interesting test though...if you let it scrape about 3 episodes via any lookup results and then try to navigate past them in the list. I don't know anyone with a WD that has it hooked up to the internet.
Mine is also very slow navigating TV episodes after the update. Only TV shows, movies are fine.
Kyrt is offline
post #5179 of 6136 Old 09-08-2014, 09:35 AM
mmiicc's Avatar
Wink
I followed the instructions to manually roll back the firmware and the problem went away. If locally stored TV shows are important to you leave firmware update checking to manual and pretend none of this..ever happened. These aren't the updates we are looking for.
mmiicc is offline
post #5180 of 6136 Old 09-18-2014, 10:47 AM
JRock3x8's Avatar
Quoted: 572 Post(s)
Liked: 132
I'm noticing that every once in a while that my WDTV starts to get ever so slightly "framey" where it looks to me like it's dropping a frame here or there. Just not as buttery smooth as I would like. I suppose it's entirely possible that it's the content that I'm watching.
Planet Earth's opening "sizzle reel" has a few spots that are a bit rough, especially some of the helicopter fly-overs of the waterfalls.
And then we were watching Fellowship of the Ring (theatrical) last weekend and the very beginning battle had a couple "framey" sequences. Not SUPER noticeable but just didn't feel 100% right to me. The only way to check is to drag my Blu-Ray player down to the basement and hook it up but that would be a giant pain in the ass
JRock3x8 is offline
post #5181 of 6136 Old 09-18-2014, 10:47 AM
JRock3x8's Avatar
Quoted: 572 Post(s)
Liked: 132
oh the other one is the beginning of Transformers 3 - that one just looks bad with the ship cutting in and out of the ruins of Cybertron.
JRock3x8 is offline
post #5182 of 6136 Old 09-18-2014, 10:51 AM
3db
3db's Avatar
Quoted: 146 Post(s)
Liked: 37
I want to use another search engine on my WD TV Live so that I can look up album information. I tried looking up album info on the White Stripe's "Get Behind Me Satan" and current lookup engine couldn't find anything. How do I go about getting this and how do I install it?
3db is offline
post #5183 of 6136 Old 09-18-2014, 05:24 PM
crbaldwin's Avatar
Quoted: 60 Post(s)
I notice this occasionally with VC-1 video which I'm pretty sure the Fellowship of the Ring is but I'm not sure about your other material. It seems kind of random for me (not always in the same spot) and fortunately not so frequent as to totally ruin the experience (probably 3-4 brief times in a movie). I'm not sure if you have MKVs but when I asked on the WD forum someone suggested that a remux to M2TS might avoid the issue.
crbaldwin is offline
post #5184 of 6136 Old 09-18-2014, 05:32 PM
JRock3x8's Avatar
Quoted: 572 Post(s)
Liked: 132
I might try to re-rip if I can see the bluray is unaffected. I think Planet Earth is just framey in spots.
JRock3x8 is offline
post #5185 of 6136 Old 09-19-2014, 12:21 AM
Does anyone know how to use the Miracast feature in the new firmware? There is nothing in the 'services' or settings menu that I can find...
pashtun is offline
post #5186 of 6136 Old 09-19-2014, 02:04 PM
jweinel's Avatar
I guess complete setup is kind of determined by the device that you intend to "mirror" to the WDTV SMP and it's ability to "Miracast", but first of all, there are options in the WDTV Settings that you should check:
I use the "Grid" format, so clicking on the gear icon (Setup) in the upper right, I navigate Setup > Network Settings > Wireless Display (Miracast). Now I have options that I have set to:
Wireless Display (Miracast) = On
Device Pairing in Push Button Mode = Auto Accept
Previously Connected Devices = (a list of just that - my tablet is currently the only device in the list)
I typically use my Samsung Galaxy Note 10.1 tablet (Android v.4.1.2) as the device to mirror to the WDTV. It has a Samsung app called AllShare Cast. It seems to be built into the OS. When I click it on my home screen, it takes me to the tablet's Settings page "Wireless & Networks", subcategory "AllShare Cast." Up to this point AllShare Cast has been "off" but on this screen it is now turned on, and if one of my active SMP's is turned-on, it will be listed as an available device. I "Click to Connect" the device and if the moon, stars, and sun are aligned properly, the SMP screen says something like "connecting to Android abcd" where abcd is a partial MAC address as I recall. In a few seconds, the tablet is mirrored full screen on my 50". It works great.
I don't think that the moon, etc., actually play a part in the connection, but something else sometimes does. Like today when I tried it, after about 30 seconds, I got a message on the tablet saying that it could not connect to the device (WDTV). It usually connects right away, but sometimes I have to play with it. Today, I had to reboot the WDTV box and then all was ok. There have been some other times where I had to mess with wireless connections. Hopefully, this will get you started!
jweinel is offline
post #5187 of 6136 Old 09-19-2014, 02:22 PM
Thanks for the info, but for some reason, my WDTV Live SMP running firmware 2.02.32 doesn't have the ' Wireless Display (Miracast)' submenu in the 'Network Settings' menu. I only get the following options:
pashtun is offline
post #5188 of 6136 Old 09-19-2014, 03:10 PM
jweinel's Avatar
Adding the screen photos was helpful! Apparently, you need to have Auto Detect WiFi Direct Setup set to "On" in order to get the Miracast option presented as the next line. If I turn it off, no Miracast option for me either.
Jim
jweinel is offline
post #5189 of 6136 Old 09-20-2014, 01:39 AM
That did the trick - thanks! WD's documentation for these new firmware features is almost non-existent, which is why I couldn't figure out how to enable it.
Sent from my XT890 using Tapatalk
pashtun is offline
post #5190 of 6136 Old 09-20-2014, 02:30 AM
pashtun is offline
Western Digital Wd Tv Live Streaming Media Player Wifi , Western Digital Wd Tv Live Streaming Media Player
taboola here
