*Official* WD TV Live Streaming Media Player Thread - Page 175 - AVS Forum | Home Theater Discussions And Reviews
 85Likes
post #5221 of 6208 Old 09-29-2014, 03:00 PM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
Originally Posted by DavidMP View Post
Can you aim a portable fan at it for testing?
yah I can try that next weekend - I barely use that room during the week.
JRock3x8 is offline
post #5222 of 6208 Old 09-29-2014, 03:08 PM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
JRock3x8 is offline
post #5223 of 6208 Old 09-29-2014, 10:54 PM
Matt L's Avatar
Quoted: 297 Post(s)
Liked: 265
I got a mint conditions refurb a few weeks ago for $49, hard to beat. Actually dumped one of my Rokus - I much prefer the Wd unit.
Anyway, got a question. I picked up a Slingbox last week too, the Solo version got it for $15 delivered - not bad. I streamed to my WD but the picture was not full screen any ideas why? I am feeding it from an SD Dtivo in one of my bedrooms, not sure if the SD feed is the issue or if it's a settings problem or if it's just the way it displays.
Matt L is offline
post #5224 of 6208 Old 09-30-2014, 11:50 AM
donaldsonjune's Avatar
Quoted: 41 Post(s)
Hello All,
I didn't know WD dropped Neflix on the new units. So I had to get a Roku 3 just for Netflix. R3 will not play DTS HD MA or Dolby TrueHD sound! So now I use the WD for the better audio and R3 for Netflix! Is there one unit taht does everything?
June
"IF YOU FAIL TO PLAN, YOU PLAN TO FAIL"
donaldsonjune is offline
post #5225 of 6208 Old 09-30-2014, 12:43 PM
Otter0911's Avatar
Quoted: 69 Post(s)
Originally Posted by donaldsonjune View Post
Hello All,
Yes the WD Live SMP 3rd Gen. It has Netflix and does HD Audio.
Otter0911 is offline
post #5226 of 6208 Old 09-30-2014, 01:44 PM
Quoted: 41 Post(s)
the 4th generation doesn't have nitflix
https://gigaom.com/2014/05/27/wd-tv-personal-edition/
June
post #5227 of 6208 Old 09-30-2014, 02:11 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
The 4th generation is actually still the 3rd generation hardware-wise and the latest Live-SMP update makes the UI the same as the the new WDTV-MP.
The only difference between the models is reflected in the spat between WD and Netflix that resulted in it's removal from the current product. So get the Live-SMP while it is still available at normal prices and you will get all the features plus Netflix.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #5228 of 6208 Old 09-30-2014, 05:39 PM
johnBlanker's Avatar
Quoted: 410 Post(s)
Liked: 68
Having a problem deleting a title. I deleted it via the wdtv live smp. And the folder keeps coming back. Just now, I deleted it from the wdtv. Then unplugged it. Went to my computer where the shares are and didn't see the movie. Then all of the sudden it reappeared. But the only files inside were there:
wdtv.cas2
wdtv.cas2_no_check_content_0090a9677d42
What's the deal? thanks guys.
johnBlanker is offline
post #5229 of 6208 Old 10-01-2014, 04:05 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
Originally Posted by Brian Hampton View Post
Have you checked the problem file on some other device?... like a computer?... Seems a good place to start.
I have a bad rip of a store bought disc... and it's bad on the WDLive and it's exactly the same played back from a PC using VLC.
checked the 30 minute mark on my PC this morning, no issue.
given that the issue happened every 30 minutes (almost exactly) I'm inclined to think the issue is heat related. I suppose I could hook up a laptop fan to the USB port. Weird that I never had this issue before.
JRock3x8 is offline
post #5230 of 6208 Old 10-01-2014, 04:29 AM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
You don't sit the WDlive on the top of the AVR do you?
Brian Hampton is offline
post #5231 of 6208 Old 10-01-2014, 07:24 AM
Kelson's Avatar
Liked: 1147
My Live-SMP's sit by themselves and are just mildy warm to the touch when running. If yours is actually hot -- assuming they are not on top of a heat source -- then I would suspect something is wrong with the box.
- kelson h
Kelson is offline
post #5232 of 6208 Old 10-01-2014, 07:50 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
It felt warmer than I would have expected but it wasn't like I couldn't hold it in my hand.
JRock3x8 is offline
post #5233 of 6208 Old 10-01-2014, 07:51 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
no it's in an entertainment center with an inch of clearance on either side.
JRock3x8 is offline
post #5234 of 6208 Old 10-01-2014, 12:15 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
Not all changes made to the media library are immediately visible. Such is the case with file deletes.
After you delete files, you need to RESCAN the parent folder.
christoofar likes this.
WDFan1970 is offline
post #5235 of 6208 Old 10-01-2014, 01:15 PM
Quoted: 572 Post(s)
Liked: 302
What I thought was a bad rip turned out to be a bad encoding job of the blu ray itself. Reviewers noticed the problem at the same time stamp.
Disc in question is 2 headed shark attack so ... not a big deal really... ha ha..
Kind of glad it was a actual disc problem not a problem with my process.
JRock3x8 likes this.
post #5236 of 6208 Old 10-02-2014, 09:33 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
lol
JRock3x8 is offline
post #5237 of 6208 Old 10-02-2014, 10:28 AM
Kelson's Avatar
Liked: 1147
Well at least it wasn't Sharknado -- that would have been a real travesty.
Lavalantula is the new one coming out. It has the Police Academy gang fighting giant lava-spitting spiders coming out of a volcano. I know, not nearly as believable as Sharknado.
- kelson h
Kelson is offline
post #5238 of 6208 Old 10-02-2014, 10:35 AM
Quoted: 572 Post(s)
Liked: 302
No problems with my sharknado rip.
Is sharknado 2 out yet ... I'm off to go check.
Arrgg ... 5 more days.... Waitin..... waiting...
post #5239 of 6208 Old 10-02-2014, 10:38 AM
Kelson's Avatar
Liked: 1147
And on BluRay, no less.
Darn, RedBox isn't going to stock it.
- kelson h
Kelson is offline
post #5240 of 6208 Old 10-02-2014, 11:48 PM
DeadEd's Avatar
Quoted: 85 Post(s)
Liked: 166
Sharknado 2 was not nearly as good. They didn't have that badass chick with the shotgun. She was the best part of the movie.
Brian Hampton likes this.
Dyslexics are teople poo.
DeadEd is offline
post #5241 of 6208 Old 10-03-2014, 05:36 AM
Quoted: 572 Post(s)
Liked: 302
She certainly was. They need to get her for Sharknado 0 the prequel and have the details of how she got that scar.
post #5242 of 6208 Old 10-03-2014, 06:21 AM
Kelson's Avatar
Liked: 1147
Scientific study has shown that shotguns are not nearly as effective against flying shark attack as is a good chain saw. This is especially true in situations where you are swallowed by a dive-bombing Great White.
Brian Hampton and DeadEd like this.
- kelson h
Kelson is offline
post #5243 of 6208 Old 10-03-2014, 09:29 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
What the hell is going on in this thread? Are we honestly discussing the merits of Sharknado 1 vs 2?!? (Bangs head against wall violently!!)
j/k lol
JRock3x8 is offline
post #5244 of 6208 Old 10-03-2014, 10:38 AM
Kelson's Avatar
Liked: 1147
j/k lol
The context has always been ripping the disk to storage and playing it with the Live-SMP.
- kelson h
Kelson is offline
post #5245 of 6208 Old 10-05-2014, 08:45 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
Follow Up - I watched Frozen with a laptop fan under the WDTV - no stops, no freezes. Will try Capt America 2 again to see if the movie freezes 30 min in like last time.
JRock3x8 is offline
post #5246 of 6208 Old 10-05-2014, 10:25 AM
christoofar's Avatar
Quoted: 233 Post(s)
Liked: 134
I got a set of those rubber adhesive backed feet & stuck them on the underside of mine, seems to help with a bit more airflow under it, haven't seen any heat issues.
christoofar is offline
post #5247 of 6208 Old 10-05-2014, 10:36 AM
Quoted: 572 Post(s)
Liked: 302
You can't test for overheating with Frozen and Winter Solder... Watch Sunshine or Heat or something like that.
DeadEd, DavidMP and JRock3x8 like this.
post #5248 of 6208 Old 10-05-2014, 11:07 AM
smitbret's Avatar
Quoted: 314 Post(s)
Liked: 95
Originally Posted by brian hampton View Post
you can't test for overheating with frozen and winter solder... Watch sunshine or heat or something like that.
lol
smitbret is offline
post #5249 of 6208 Old 10-06-2014, 04:26 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
Winter Soldier froze (ugh, puns) again but in a later spot. Put my hand on the box - not warm at all - not sure what's going on now. Maybe just need to re-rip.
Also, Frozen has some absolutely AWFUL artifacting during the climax scene. Now I will grant you there was a lot going on screen with tons of detailed blowing snow and motion and all that but these are supposed to be uncompressed blu ray rips. Guess I need to watch the disc to be sure.
JRock3x8 is offline
post #5250 of 6208 Old 10-06-2014, 05:06 AM
Toys7505's Avatar
Quoted: 69 Post(s)
Liked: 26
I have had some of the same issues with movies freezing - all random spots. One movie in particular was T2 - Judgement Day. I was able to finally get the movie to play without freezing by removing any and all subtitles from the movie rip. I know Cap 2 does have some subtitles and depending on which format you are using, see if you can remove any other ripped subs you don't need (ie - director commentary).
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
Western Digital Wd Tv Live Streaming Media Player Wifi , Western Digital Wd Tv Live Streaming Media Player
