*Official* WD TV Live Streaming Media Player Thread - Page 193 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #5761 of 6211 Old 05-01-2015, 04:36 PM
steveting99's Avatar
Quoted: 1840 Post(s)
Liked: 640
Originally Posted by WDFan1970 View Post
It's not clear if you did what was suggested far above -- Stop using the RIPPING module. That transcodes the files to one degree or another.
Stop trying to COPY/play ISOs or BDMV folders.
Just find the M2TS file that you want from the copy, copy ONLY THAT over, and play it.
If it doesn't play, your WDTV is hosed for some reason.
I have dozens and dozens of BDs and not a one of them has given me playback problems of any sort whatsoever.
Hi WDFan1970,
Not sure if you're familiar with DVDFab. I've got the latest version (9.1.9.9 dated 28/4/2015) and followed the steps outlined in the youtube video by johnBlanker.
Within DVDFab there are a number of main tabs. These are Copy/Ripper/Converter/Creator.
Under the copy tab:
(1) the copy mode is selected as Main Movie.
(2) Under save to, it is ISO.
(3) When I dropped the source disc, it asks to select a region. I choose region A.
(4) Under output it is at BD50. It says compression ratio is 100% with same file size as source. I.e. 24.092GB ---> 24.092GB.
(5) It then gives a main playlist that says 800 that has a length of 2 hours, 11 minutes and 21 seconds. It also has other playlists of various shorter time periods. No other playlist is selected other than 800.
(6) A check of the audio shows the default to be DTS-HD MA 5.1, so didn't change anything.
(7) Another check of the subtitle shows English as the default.
(8) When making the iso file, the entire process time was quick indicating there was no transcode.
(9) With the same settings as above, I also made a BDMV folder.
To make a M2TS file, I have to go into the ripper tab and select the M2TS profile.
(a) Under output, I choose M2TS.Default. Video Codec says COPY. Audio Codec says COPY. Resolution says 1920x1080.
(b) Checking the advance settings, copy video is ticked. Codec is 'same as source'. Encoding method is 'same as source'. Frame rate is 'same as source'.
(c) Staying in the advance settings, copy audio is ticked. Codec is 'same as source'. Channels is 'same as source'. Sample rate is 'same as source'. Bit rate is 'same as source'.
(d) Still in the advanced settings, the subtitle is remux into file.
(e) It then gives a main playlist that says 800 that has a length of 2 hours, 11 minutes and 21 seconds. It also has other playlists of various shorter time periods. No other playlist is selected other than 800.
(f) A check of the audio shows the default to be DTS-HD MA 5.1, so didn't change anything. (g) Another check of the subtitle shows English as the default.
(h) When making the M2TS file, the entire process time was quick indicating there was no transcode.
(i) With the same settings as above, I also made a MKV file using the MKV profile.
So now I have 5 files.
A full backup ISO file of the original blu-ray disc.
A main movie ISO file via the playlist 800.
A main movie BDMV folder via playlist 800.
A main movie M2TS file via playlist 800.
A main movie MKV file via playlist 800.
I then played each of these files on the PC using the software MPC-HCx64 video player. They all played on the PC.
I then placed each of these files on the 64GB Scandisk USB thumb drive and tried to play on the Oppo BDP-93 as well as the WDTV Live SMP. The results are that the Oppo BDP-93 played every file expect the MKV. WDTV Live SMP failed to play a single file.
Let me know if what I'm doing is wrong.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #5762 of 6211 Old 05-02-2015, 06:02 AM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 51
@steveting99 , I don't know what's not working. All I can say is I just finished ripping four new BDs yesterday and this morning (Alex Cross, Friday Night Lights, The Lincoln Lawyer and One for the Money [Wal-Mart Multi-packs, $10 for all four]) and all four play perfectly...
The only suggestion I'd have at this point is for you to try playing them via the network instead of USB, or use another USB device. Maybe there's something funky about your Sandisk the WDTV isn't happy with.
WDFan1970 is offline
post #5763 of 6211 Old 05-02-2015, 02:53 PM
JRock3x8's Avatar
Quoted: 754 Post(s)
Liked: 197
is there anyway to prove the authenticity of his WDTV? I'm concerned it's a knockoff or different version of hardware.
JRock3x8 is offline
post #5764 of 6211 Old 05-03-2015, 12:12 PM
JRock3x8's Avatar
Quoted: 754 Post(s)
Liked: 197
had yet another just awful experience with my WDTV last night - the common denominator? Captain America - The Winter Soldier. Audio went to static 30 minutes in, rebooted the receiver, then the movie froze every 30 minutes the rest of the way, had to reboot each time.
Not sure what it is about that movie or that rip but my WDTV does NOT like it.
JRock3x8 is offline
post #5765 of 6211 Old 05-03-2015, 11:25 PM
Liked: 640
Do you know if anyone making WDTV Live SMP "knockoffs"? Is the "knockoff" question relevant considering the low price of the units?
Not sure why anyone would gain in purchasing a "knockoff" as it would not be possible to update the firmware from WD. FYI, the unit was able to update the firmware a number of times.
Maybe the correct question to ask is the model number and current firmware?
post #5766 of 6211 Old 05-04-2015, 02:49 AM
JRock3x8's Avatar
Quoted: 754 Post(s)
Liked: 197
Just trying to come up with plausible explanations
JRock3x8 is offline
post #5767 of 6211 Old 05-04-2015, 03:58 AM
Nickff's Avatar
Quoted: 348 Post(s)
Liked: 221
Any reason to still avoid the latest firmware?
Nickff is offline
post #5768 of 6211 Old 05-04-2015, 05:47 AM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 51
Only upgrade if you don't need reliable MP4 / M4V playback...
post #5769 of 6211 Old 05-04-2015, 05:50 AM
Nickff's Avatar
Quoted: 348 Post(s)
Liked: 221
I ask because I tried to watch a YouTube clip the other day and the sound kept cutting out and was wondering if a firmware update would remedy the situation...but remembered that the last time I knew an update came out it borked some things.
Nickff is offline
post #5770 of 6211 Old 05-04-2015, 01:15 PM
Wendell R. Breland's Avatar
Quoted: 309 Post(s)
Liked: 171
For anyone that has the WD TV model (current) and the Android app:
1 - If you play video files from a share or DLNA server can you see the file names on on the Android device (tablet, phone, etc.)?
2 - Same for music files? Will music play list show in the Android app?
3 - When playing FLAC files to your audio device via HDMI will the WD TV cause your audio device to mute between selections?
4 - For those with Pandora, can you see the Pandora stations, what’s playing, etc. on the Android app?
Wendell R. Breland is offline
post #5771 of 6211 Old 05-04-2015, 02:52 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 51
The only App I know of for the WD TV is the remote control app.
If that's the app you're talking about then the answers to 1, 2 and 4 are NO.
3 is unrelated, but the answer is still "No." The WD won't MUTE any downstream device.
Now if you're actually asking if the WD TV supports Gapless Playback, the answer is still No.
post #5772 of 6211 Old 05-05-2015, 03:39 AM
Kyrt's Avatar
@steveting99 , ...
I agree, something is definitely not right. The WDTV should have no problems playing MKV and M2TS Blu Ray rips (assuming they are decrypted of course). I have ripped over a hundred and they all play. Either your WDTV is faulty, or it doesn't like your USB stick. If you don't have another brand you could try the network. You will of course need a fast network to stream bit-for-bit Blu Ray rips.
Kyrt is offline
post #5773 of 6211 Old 05-05-2015, 03:59 AM
Liked: 640
Looks like I'm hosed with the WDTV Live SMP.
Tried the main movie ISO file, BDMV folder, M2T2 and MKV files via the NAS. The WDTV Live SMP can see the files via network share. None of the files can play. The network is direct wired connection between the WDTV Live SMP, router and NAS.
Then tried the DVD (SD) version of the movie in ISO and it played okay.
So for some reason the WDTV Live SMP I've got doesn't do blu-ray backup/rips. Maybe WD sells a different version in this part of the world compared to what you guys have in the states. I'm through wasting time and trying to shoe horn something to make the WDTV Live SMP to work. Will be looking at alternatives.
Thanks to all who tried to help.
post #5774 of 6211 Old 05-05-2015, 05:26 AM
Quoted: 309 Post(s)
Liked: 171
Thanks for your answers.
I have a Onkyo PR-SC5508P audio processor, it is a DLNA client device and can play FLAC files from my audio server (Synology NAS). The 5508 mutes between each track which causes the internal relays to click (very annoying). Same thing happens when using a Netgear NeoTV (via HDMI). My Panasonic DMP-BDT220 Blu-ray player (via HDMI) does not cause the 5508 to mute between tracks.
post #5775 of 6211 Old 05-22-2015, 07:18 AM
cc_in_oh's Avatar
Quoted: 1001 Post(s)
Liked: 590
WD is selling another batch of $60 recertified SMPs - not sure if they're the non-Netflix version...
CC
Who knew "flammable" and "inflammable" mean the same thing???
cc_in_oh is online now
post #5776 of 6211 Old 05-22-2015, 10:22 AM
mr266's Avatar
Quoted: 122 Post(s)
Liked: 733
Yes, those are the non-Netflix versions. Great price regardless.
WDTV Live SMP with WD EX4100 NAS
Polk RTI8 Front, Polk CSI5 Center, Polk RTI4 Surround
MTX SW2 12” SUB, Sharp AQUOS LC-70C6400U
URC-WR7 Universal Remote
Motorola QIP7232 (P2) FIOS DVR, Sony BDP-S590 Blu Ray Player
Marantz SR5010 AVR,Technics SL-B20 Turntable
mr266 is offline
post #5777 of 6211 Old 05-22-2015, 12:52 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 51
Gotta be careful with the name. If they're non-NetFlix, they're not SMP's. They're just "WD TV"'s.
post #5778 of 6211 Old 05-22-2015, 01:34 PM
cc_in_oh's Avatar
Liked: 590
No more "PE"? I thought since the FW upgrade they were identical except for Netflix app?
CC
post #5779 of 6211 Old 05-22-2015, 04:32 PM
Kelson's Avatar
Quoted: 2010 Post(s)
Liked: 1201
That's correct they are the same except for Netflix.
The current one is called the WDTV Media Player.
They haven't released a firmware update since 12/14 and only 2 have been issued since the device was released. Their support for the Live-SMP was much better. I'm wondering if they have lost interest in the media streamer market and this product is headed for the grave.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #5780 of 6211 Old 05-22-2015, 04:46 PM
Keenan's Avatar
Quoted: 2466 Post(s)
Liked: 2312
Wasn't DTS-HD MA decoding dropped in the later model(s) as well? Maybe I'm thinking of something else.
Keenan is online now
post #5781 of 6211 Old 05-22-2015, 05:10 PM
cc_in_oh's Avatar
Liked: 590
Treating them as separate products makes no sense to me. The SMP on current FW is far more similar to the "Media Player" than it is to the SMP itself on previous FW...
CC
post #5782 of 6211 Old 05-22-2015, 05:41 PM
Kelson's Avatar
Liked: 1201
No DTS-MA pass-through is alive. When they added that, nothing else in this price range could touch the WD Live. For that reason it would be a shame for this one to fade away.
- kelson h
Kelson is offline
post #5783 of 6211 Old 05-22-2015, 05:48 PM
Kelson's Avatar
Liked: 1201
I would love to have been a fly on WD's wall, but I think the issue with Netflix was the elephant in their room. I would rather they do what they did and re-release the Live-SMP as the WDTV Media Player without Netflix instead of issuing a firmware update to the Live-SMP that stripped out Netflix. They certainly could have gone that route -- the 12/14 update to the WDTV-MP stripped out Cinema Now functionality.
I'm glad they chose to go the route they did.
- kelson h
Kelson is offline
post #5784 of 6211 Old 05-23-2015, 03:32 PM
stinkfingerx1's Avatar
I've had my WD Live Media Player for about a year no problems. Now in the last month it will not show new pictures on my movies. Only the ones I've had on for the last year. I've tried unplugging and clearing the library. It will show pictures for all of my movies except the ones from the last month or so. I looked in the actual folder and my computer and it show they have all the files they need(folder, meta blah, blah, blah) any ideas?
stinkfingerx1 is offline
post #5785 of 6211 Old 05-24-2015, 02:13 PM
Osirus23's Avatar
Quoted: 103 Post(s)
Liked: 256
Well mine appears to have completely gone to ****. When I try to open YouTube Leanback it just crashes and restarts. When I tried Netflix it just froze on a black screen and had to be unplugged to reset.
Osirus23 is online now
post #5786 of 6211 Old 05-25-2015, 01:19 AM
Liked: 640
I've given up on the WDTV Live SMP and have been looking at alternatives. Going to take delivery with an android box solution offered by HIMEDIA called the Q16.
Think it's much better than WDTV Live SMP in terms of features as well as support. Will be posting in another thread regarding this journey of discovery.
post #5787 of 6211 Old 05-25-2015, 05:39 AM
zaphod7501's Avatar
Quoted: 87 Post(s)
Liked: 79
I've had a couple of times the player absolutely refused to rescan a folder. I was able to get it to update by moving out some files (ones that it was showing OK) to another directory, then forcing a rescan or two.
I've also found that if I start the media player while one of the shared computers is off, then I always have to rescan the share.
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is online now
post #5788 of 6211 Old 05-25-2015, 06:42 AM
cc_in_oh's Avatar
Liked: 590
Since I turned off media lib I've never had to rescan (actually I'm not even sure if there's a rescan option). If I change the contents of a folder, backing out of it and re-opening always updates the folder contents correctly...
CC
post #5789 of 6211 Old 05-25-2015, 08:06 AM
zaphod7501's Avatar
Quoted: 87 Post(s)
Liked: 79
Folder view doesn't need rescans as far as I can tell, only the Media Library. I like the Media Library because I can include the folders in "favorites" and put them on the "Dashboard" so I can get to my files quickly. (along with Netflix, Accuweather, etc)
The Media Library scan is slightly hidden. From Setup -> system -> media library -> Manager for network shares - select share & and delete or rescan (all shares on that PC will actually be scanned)
post #5790 of 6211 Old 05-25-2015, 08:29 AM
cc_in_oh's Avatar
Liked: 590
Yes I remember using it frequently when I couldn't get to the individual folder to use Option>Rescan. Unfortunately with several thousand TV episodes, navigation speeds were unacceptable when using ML. Occasionally having to change content source is a small price to pay for decent navigation performance...
CC
Western Digital Wd Tv Live Streaming Media Player Wifi , Western Digital Wd Tv Live Streaming Media Player
