*Official* WD TV Live Streaming Media Player Thread - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 85Likes
post #1261 of 6208 Old 01-24-2012, 07:00 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
Well, that is the current version... I'm not sure what the problem could be.
I have five different shares connected from my NAS...
The reason I asked was that it used to be a limitation in the firmware two versions ago.. you could only add the WHOLE NAS or ONE SHARE.
Now, you can no longer add the WHOLE NAS all at once, but you can add ALL of its shares individually.
WDFan1970 is offline
post #1262 of 6208 Old 01-24-2012, 07:48 PM
pinky58's Avatar
You have all been alot of help in getting my new toys setup, one thing I neglected to get for my home theater, was a BD DLNA player to run thru my network. Do any of you have any suggestions?
Bill
pinky58 is offline
post #1263 of 6208 Old 01-25-2012, 03:05 AM
norliss's Avatar
I'm hoping that my setup is not causing it problems. Rather than having a NAS with a single share containing multiple folders i.e.
Media > Films
Media > TV
Media > Music
I have mine setup with individual shares i.e.
Films
TV
Music etc.
Is the WDTV ok with this? As things stand, I can go and add one share but as soon as I try to add another it just brings up the same share again i.e. READYNAS/Films and doesn't let me browse to add the subsequent shares.
norliss is offline
post #1264 of 6208 Old 01-25-2012, 05:43 AM
MrTechnician's Avatar
Originally Posted by oldskool75 View Post
Has anyone successfully added video RSS feeds from any sources? (other than BBC)
As an example, these video RSS feeds work in Google Reader, but the SMP says "Failed. Invalid address. Please try again."
SMP fw: 1.06.04
Some URLs I tried, as an example:
h**p://www.youtube.com/rss/user/ERB/videos.rss (channel)
h**p://gdata.youtube.com/feeds/api/playlists/F74A97B69AD3507A (playlist)
And some other free video streaming sites that offer RSS feeds..
Anyone have any success or failures with RSS video feeds?
Hi oldskool,
I've tried these RSS feeds without any probs, using same firmware.
h**p://feeds.twit.tv/aaa_video_large
h**p://feeds.twit.tv/twit_video_hd
Replace ** with tt as I wasn't allowed to post links yet.
I've logged in through a pc and copied the links into the RSS feed option and saved it.
Cheers
MrTechnician is offline
post #1265 of 6208 Old 01-25-2012, 06:18 AM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
Just realized something else.
Are you doing this via the "Media Library Manager?" Or via "Select Content Source?"
You need to use the former.
Setup / System / Media Library / Media Library Manager / Add....
post #1266 of 6208 Old 01-25-2012, 09:49 AM
norliss's Avatar
Thanks for your reply. I am using the former.
Something has just occurred to me though. I wasn't able to connect until I put the name of the share in as a user name (blank password). Perhaps it is connecting to that Share thinking that is all there is? What would I need to put in the username field in order for it to connect to the whole server rather than a specific share?
norliss is offline
post #1267 of 6208 Old 01-25-2012, 10:07 AM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
...What would I need to put in the username field in order for it to connect to the whole server rather than a specific share?
Depends on your NAS configuration. If they're PASSWORD Protect Shares, then ALL shares you expect to aggregate must be accessible to the same user.
If they all have different user-names, then you will only be able to use ONE.
If they are NOT password protected, then just use "anonymous" and no password.
IIRC, the WD puts "****" in the password field, even if it's technically "empty," so don't let that confuse you.
post #1268 of 6208 Old 01-25-2012, 10:15 AM
norliss's Avatar
I think this *might* have been where I've been going wrong.
It was suggested on another forum that I needed to put the NAS's administration username & password in here which I subsequently found to be wrong. It was then suggested that I needed to use the share name but as said above, this gives me a single share and no opportunity to get others.
I'm about 50/50 (ie I think I might have tried) on whether I have already just tried using the default "anonymous" and ******* blank password but I shall certainly try again when I get home later. Hopefully this sorts it out.
I'll report back here a little later and in the meantime, thanks again for your help.
norliss is offline
post #1269 of 6208 Old 01-25-2012, 11:59 AM
norliss's Avatar
Still no luck
I've just tried to add the share, leaving the un as "anonymous" with a blank password and get the following message:
"Unable to connect to the selected source. Please make sure the selected source is active and available for sharing."
Which it is, and can be seen by two PCs, a Mac and a Netgear NeoTV550
Why is this thing such a ball-ache to set up?!
norliss is offline
post #1270 of 6208 Old 01-25-2012, 12:39 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
Ugh... I don't know what's up with that.
It should definitely not be that difficult.. It only should take about a minute to set up a half dozen shares...
post #1271 of 6208 Old 01-25-2012, 12:59 PM
Lt. Dang's Avatar
Still no luck
Have you tried turning off the WDTV Share Server in the WDTV network settings. Weird as it may sound but turning this off sometimes works when the streamer is reluctant to see your shares.
Lt. Dang
It's life Jim..... But not as we know it.
Lt. Dang is offline
post #1272 of 6208 Old 01-25-2012, 02:36 PM
norliss's Avatar
Lt. Dang
Tried this, alas to no avail...
norliss is offline
post #1273 of 6208 Old 01-25-2012, 02:55 PM
Timh's Avatar
Still no luck
I had the same issue you had as I thought there was no need to enter the NAS user name and password login.
Once I entered them it worked perfectly.
Timh is offline
post #1274 of 6208 Old 01-25-2012, 03:03 PM
norliss's Avatar
Sadly not, in my case. I'm about to give up on this for local content and stick to my NeoTV, in all honesty!
norliss is offline
post #1275 of 6208 Old 01-25-2012, 03:50 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
Well, before you throw the baby out with the bathwater, try putting a UID and password on the shares, and see if THAT works.
post #1276 of 6208 Old 01-26-2012, 08:26 PM
konaseema's Avatar
When i tried to add network shared drive, it complains that the folders are not writable. Does it require write permissions?
Anyway, I have given write permissions.. but it is still complaining for the same. I switched off and turn back on, still have the same problem. Any idea?
konaseema is offline
post #1277 of 6208 Old 01-27-2012, 06:35 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
Yes. If you are watching a title and stop in the middle, the Live-S bookmarks the position and writes a file to the share with the information. When you restart the title you are presented with a "Resume/Restart" menu. This way it can remember your viewing position for every title on your system. Many people, like myself, don't like the idea of it writing bookmark files all over my NAS and wish it would use a single central folder. But, it is what it is and I feel the function is too useful to not use it by making the shares write-restricted.
Also, by doing it this way it is backward compatible with the Live+ so I can start watching on the Live-S in the family room until I get kicked out because my girls want to watch "reality" trash. Then retreat to another room and continue where I left off on the Live+.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #1278 of 6208 Old 01-27-2012, 08:07 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
I'm guessing the Live+ stores this information locally? My 3 Live+'s don't share this info, I wish they did though, lol.
Bill
mrfattbill is offline
post #1279 of 6208 Old 01-27-2012, 10:10 AM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
External Resume points only work with DVDs being played in DVD Navigation mode.
post #1280 of 6208 Old 01-27-2012, 11:16 AM
Kelson's Avatar
Liked: 1147
And that tends to be where I use it the most -- hit "play all" for the episodes on a disk and use resume to get back to where I had to stop.
- kelson h
Kelson is offline
post #1281 of 6208 Old 01-27-2012, 01:46 PM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
So the resume feature when streaming is only stored locally then?
Bill
post #1282 of 6208 Old 01-27-2012, 04:55 PM
Kelson's Avatar
Liked: 1147
Bill
No, it looks like it's file dependent. I just checked the folders in my NAS unit and the Live only writes the external bookmarks when playing DVD.iso files. I see them for both main_title DVD.iso and full-disk-rip DVD.iso. I do not see them for BluRay BD.m2ts files. The resume point for them is stored in the Live, there is no file on the NAS. I don't know under what conditions I would lose the resume point for BD.m2ts.
- kelson h
Kelson is offline
post #1283 of 6208 Old 01-27-2012, 05:50 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
Bill
No, the others are stored in the Media Library database, but that's not useful to the Live/Live+, since they don't support it.
post #1284 of 6208 Old 01-28-2012, 02:38 PM
desertwedge's Avatar
Hope Raphael is still watching this forum and can help or someone else has any ideas I would appreciate it. I tried updating the default theme online with the font folder included in the theme. The device took the update fine. After doing a complete shutdown of the device though, it won't boot pass the welcome screen now. Tried the following:
1. Holding the reset button on the bottom of the device.
2. Tried connecting to the device via the web but can not connect. Along with this, I tried to ping the device but wasn't able to connect to it.
3. Tried resetting firmware by installing latest firmware on USB into front & rear.
None of the above worked. Any thoughts or do I have a brick?
desertwedge is offline
post #1285 of 6208 Old 01-28-2012, 04:46 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
Don't HOLD the button down. All that does is change the NTSC / PAL setting.
Just press it for a couple of seconds.
If that doesn't work, you bricked it.
Now, exactly WHAT did you do? There is no "Font" folder as part of a theme.
post #1286 of 6208 Old 01-28-2012, 06:25 PM
Tried the reset for a few seconds, no go. In the GPL download file I downloaded there is a font folder. I included it in the theme. It obviously did not work.
post #1287 of 6208 Old 01-28-2012, 06:39 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
Uh oh... Yeah, I can't imagine a good end to that...
I would suggest calling WD and let them know exactly what happened, and they will probably wind up RMA'ing it...
post #1288 of 6208 Old 01-29-2012, 10:22 PM
sksahai's Avatar
Has anyone noticed that the accuweather app has the wrong date listed? Also it does not update the little "temp" icon on the home page.
For example, today Sunday Jan 29, the app tells me the weather for Sugar Land, TX. BUT the date displayed is "Monday, January 30th."
I have noticed this everytime I check the weather, the app always thinks it's tomorrow. But when I check the "7 day forecast" it shows today highlighted.
Also, I can't figure out how to get rid of the accuweather temp icon showinig the outside temp on the home screen. It never updates, so it's useless info.
I have to manually goto the accuweather app, wait for it to update the temp, and tell me it's tomorrow, and then go back "home" If I turnon the device a few days later, the old temp shows.
Has the latest firmware.
sksahai is offline
post #1289 of 6208 Old 01-30-2012, 06:23 AM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 50
Hmmm. I've not noticed that, but I'll be paying more attention.
Not had any problem with the home page not updating the temperature, though...
post #1290 of 6208 Old 01-30-2012, 06:46 PM
Projectorguy1's Avatar
Please forgive me if this has been addressed...
I am trying to get the hdmi passthrough to pass anything but Prologic to my RXV-661 reciever.
When I select "digital out via hdmi only" and "auto", I get a "not supported by TV" message. If I select anything other than just AAC, I get video, and no audio at all. If I select AAC only, or "auto", I get video with sound, but prologic audio only.
I am running hdmi from the WDTV Live, through a 4x2 Monoprice powered switcher, and then into the reciever. I have heard that the hdmi will not pass anything above the pro logic.....is this true?
Since I run my hdmi video through my reciever, I have no idea how to use the optical output for sound, while actively passing through the hdmi video to my TV...
HELP!
WWJD
Projectorguy1 is offline
Western Digital Wd Tv Live Streaming Media Player Wifi , Western Digital Wd Tv Live Streaming Media Player
