New Home Audio Help - AVS Forum | Home Theater Discussions And Reviews
Old 04-28-2002, 08:09 PM - Thread Starter
mlsignups's Avatar
Building a new home. Had wiring installed and house will have in-wall as well as wireless network.
Also had speakers put in and plan to have 6 zone sound system.
We have over 1000 CD's that I'd like to have access to from any of the zones.
I'd also like to have control of what plays in what zones over either 4 or 5 PC's distriubted through the house or through a TV screen. I'd like to be able to select albums/songs but cover art isn't critical.
Assuming that I rip the CD's to something, can you please give me some suggestions as to the best Product(s) to get. I'm willing to go with a specialized system (like the fireball) but I'd slightly prefer to go with a PC based system.
Again, my main goal is PC control (or TV control) and multizone distribution of a hard disk version of the CD's...
Thanks for any input...
Mike
mlsignups is offline
Old 04-29-2002, 06:23 AM
bsaitz's Avatar
i'm sure you'd rather spend more $$, but put the savings into some new CD's.. or better yet, screw the RIAA and put the $$ into cattle futures ;-)
go get an http://www.audiotron.net
Mitsi 55907
Denon 3801
Sony HD-100 STB
DirectTV/HD-DVR
OTA
ROKU
bsaitz is offline
Old 05-01-2002, 07:03 PM
RSongco's Avatar
I'm in the same situation. Bookshelf speakers in all bedrooms, in-wall speakers in the family room, living room and hallway, and outdoor speakers in the garage and patio/pool area. I have a hybrid solution:
1. Digital: Using a combination of ethernet (house is pre-wired with ethernet cable only in some rooms, including the office) and PNA (for all the other rooms), all rooms can access the PC acting as a music server in the family room, using both the Rio receiver (in the other rooms) and the Audiotron (in the family room). This allows independent playback of music in each zone. I like the Rio for the bedrooms because it has a built-in amplifier, so all I need to add are speakers, and the Audiotron in my family room because it has a "component" look to it which keeps my HT rack looking consistent.
2. Analog: My house is pre-wired with speaker wire for the family room (5-channel configuration), living room, upstairs hallway and patio/pool area. Using a JVC multi-room receiver directly connected to the audio out of the music server (as well as to the Audiotron, DVD/Audio player, graphic equalizer, etc) I can pipe music anywhere in the house from any component source. For instance, during parties the receiver does double duty by playing background music in the living room, hallway and patio, while serving as a Dolby Digital receiver for watching DVD's or HD in the family room. To keep from taxing the receiver I have its line out's to a separate Onkyo amp to feed all those other speakers.
3. Wireless: got one of those x10 wireless audio transmitters as part of an x10 video transmitter package. Can use it to transmit the same music from the receiver to speakers in my garage. Of course, my garage has been remodeled to be a showroom/HT with its own components anyway, so the wireless transmitter doesn't get used much.
Anyway, lots of options and you don't even have to have your house pre-wired for ethernet. But if you do, all the better, especially if you want a graphical UI for each playback device (ie, a PC monitor).
Good luck!
"Mixing a teaspoon of manure with a gallon of ice cream produces a gallon of manure."
RSongco is offline
