Revue - GTV2.0 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 160 Old 10-16-2011, 12:41 AM - Thread Starter
avf5's Avatar
..........................................Revue GTV 2.0 TIPS
.....................For Updated Google TV Tips (sticky) & Revue Tips (sticky) --> CLICK HER!
.....................................Revue Tips were originated from this thread!
Netflix:
Tip: Netflix now supports streaming of available HD contents in 1080P / 5.1 surround Sound.
Tip: To quit Netflix/Pandora Apps, press and hold the [esc] key till the dialogue pops-up!
Tip: To Avoid Netflix Error Messages
..We're having trouble playing this title right now. Please try again later or select a different title...
..... Loading, Please wait . with a full Red bar displaying.
Press (repeatedly) the [Back] key to exit all opened Apps (in the background)and return to Home screen - before lunching Netflix App.
Or, Reboot Revue (Press Ctrl + Alt + DEL) - before Launching Netflix App.
Tip: Netflix issues,
From All Apps select Netflix App Press & Hold [OK] key - select Application info' from menu - >Force stop / Clear data - reboot - sign-in to Netflix Account.
Or
Go to Settings > Applications > Manage Applications > Netflix >Force stop / Clear data - reboot - sign-in to Netflix Account.
Tip: Deactivate (unlink) Netflix Account - wait 30min - reboot Revue - sign-in to Netflix Account
Tip: To Deactivate Netflix Account,
Go to www.netflix.com - Log-in to your Account >'Your Account & > Help' > 'Manage devices > Deactivate (takes about 30 min) - Reboot - sign-in to Netflix Account,
Or
From Revue's keyboard - Press (without delays) Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
Deactivate - Reboot - sign-in to Netflix Account
Tip: Reboot Modem/Router, after the reboot-up process (Modem first wait then Router second wait - Reboot Revue. (or have Revue unplugged from power before Rebooting Modem/Router )
Change Router channel /frequency (for N Routers)
Connect directly to a modem - bypass the Router.
Try changing DNS in Router - to Google DNS ( 8.8.8.8 ) or open DNS ( 208.67.222.222 ) - this option is for advance users.
Tip: Reboot Revue,
Unplug it from power (wait 30 sec.) re-plug it.
Tip: To Do Factory-Reset -three options to choose from -> .
Go to Settings - select Privacy & Safety - Select Factory data reset.
Lunch Chrome - press [Option] key - from the menu select Setting' > Reporting > Factory data reset (erases all data on device).
Hold down the button on the back of the Revue until the TV-logo comes up. (it may takes about 40 seconds) -> then the progress bar will display... (Factory-Reset will erases all data on device - like new Device).
Tip: Create a new Google Account at sign-in, after Factory-Reset
Tip: Turn OFF All Connected Devices (TV-STB-AVR-Modem-Router) - unplug /disconnect, Power cords & HDMI cables from All Connected Devices - Wait 10 min - plug Power cords & Power-up Modem/Router ( see above) - wait 5 min - reconnect HDMI cables - plug Power cords & Power-up all other Devices.
Tip: Adjust / Manage Netflix Video Quality,
Sign-in into your Netflix Account.
Click on Your account & Help.
Click Manage video quality.
Select Lower quality.
Bookmarks:
Tip: To Delete bookmark, Select the bookmark - hold down the [OK] key till the option-dialogue pops-up.
Tip: To add a bookmark to Home Screen, While in Chrome - select the bookmark - press the [Favorites key] (Star controller key) - from the dialogue select Add to home screen - go to Home - press the [Option] key (the dash key located between [Alt] &[Ctrl])- from the dialogue select Customize home items - select any icon to replace (one of the seven icons) - press [Ok] key - from the dialogue select replace - scroll down the list & select the bookmark.
Tip: To Add a whole Bookmarks folder to Home Screen
Download and installed BookmarkSB App from Market.
While in Home press the [Option] key (the dash key located between [Alt] &[Ctrl])- from the dialogue select Customize home items - select any icon to replace (one of the seven icons) - press [Ok] key - from the dialogue select replace - scroll down the list & select the bookmarkSB. (btw, bookmarkSB tip was posted by jTV ).
Tip: To find a Bookmark/Shortcut - was saved while in Chrome by adding a bookmark from the option Add to home screen - will Save/place the bookmark/Shortcut in All Apps Folder/drawer - to find it, from Home Task-bar select All Apps icon.
Tip: To find a Bookmark- was saved while in Chrome by adding a bookmark from the option Add to bookmark folder - will Save the bookmark in bookmark Folder- to find it, go to Chrome - press [Option] key - select Bookmarks from menu.
Tip: To edit a bookmark - press & hold [OK] key to display edit-menu.
Application info:
- From All Apps select App Press & Hold [OK] key - select Application info' from menu - select App.
- Or,
- Go to Settings > Applications > Manage Applications > App.
Chrome:
Tip: Chrome Settings for Adobe Flash /Privacy / Password-word / Security,
Go to Chrome >press [Option] key > Settings > Advance settings > select under the Hood > Privacy
Tip: To change Fonts,
Go to Chrome >press [Option] key > Settings > Advance settings > select under the Hood > select Customize Fonts
Tip: To close Chrome - Press [Ctrl] + [W] keys
Tip: To Refresh Page - Press [Ctrl] + [R] keys
Tip: To type URL - Press [Ctrl] + [T] keys
Tip: Bookmark menu - Press [Ctrl] + [D] keys
Tip: To Clear Browser Cookies/History/
- Press [Options] then [s] keys
Tip: To Search within a Page - Press [Ctrl] + [F].. keys (press controller [Previous] key to exit)
TV Mode
Tip: To Move/Adjust Picture-in- Picture - Press and Hold [Picture-in- Picture] controller key to display option menu.
Home Screen:
Tip: How to Place an App or a shortcut to Home Screen?
- By replacing one of the seven Apps from Revue Home Screen task bar.
- go to Home - press the [Option] key (the dash key located between [Alt] &[Ctrl]) - from the dialogue select Customize home items - select any icon to replace (one of the seven icons) - press [Ok] key - from the dialogue select replace - scroll down the list & select the Appk/shortcut.
Settings menu:
Tip: To display Settings menu,
- Press [Options] key then Press [s] on the keyboard while in Home screen.
- Or
- Via the Settings App.
USB Drive:
Tip: Revue Supports USB Drives formatted in NTFS & FAT32 Format.
Tip: To Safely Unplug /Remove USB Drive - Unmount it
- Press [Options] key - Press [s] key - Select Storage' - select unmount .
- Or
- Go to Settings - Select Storage' - select unmount .
Crackle - Vevo:
Tip: To install Crackle -web, type crackle in search App - select the link crackle-Watch free Full (w/Chrome icon) - bookmark it.
Tip: To add Crackle-bookmark/shortcut to Home Screen:
While in Chrome Select Crackle-bookmark -Press the [Favorites key] (Star controller key) - from the dialogue select Add to home screen - go to Home - press the [Option] key (the dash key located between [Alt] &[Ctrl]) - from the dialogue select Customize home items - select any icon to replace (one of the seven icons) - press [Ok] key - from the dialogue select replace - scroll down the list & select the bookmark/shortcut.
Tip: To install Vevo -web, type Vevo in search App- select the link crackle-Watch free Full (w/Chrome icon) - bookmark it.
Tip: To add Vevo -bookmark/shortcut to Home Screen:
Video:
Tip: Black Screen at start & after reboots - if STB /cable/satellite box is disconnected!
Press [Home] key.
Press [Option] key - from menu select Home and All Apps settings' - select startup applications' - select None'. (you may replace [TV] icon in Home screen if not need it).
Tip: Annoying menu at start & after reboots (asking to setup STB) see above tip.
Audio:
Tip: If no 5.1 surround sound when STB/ cable/satellite Box. Connected thru Revue -GTV 2.0 & AVR. Make sure the STB/ cable/satellite Box Audio system setting is set to Pass Through (NOT set to Auto or Lpcm) Assuming HTS connection as follow: STB >HDMI>Revue>HDMI>AV receiver>HDMI>TV
if the cable channel broadcasting in 5.1DD - correct sound field will be heard from All 6 speakers connected to AVR (transcended/5.1 PCM @ 48 KHz)
if the cable channel broadcasting in 2.0 DD correct sound field will be heard from LF&RT speakers + Subwoofer speaker connected to AVR (transcended/2.1 PCM @ 48 KHz). .
To change Audio system setting on the STB Cable box:
The STB Audio system setting menu (secret menu) can be accessed by turning Off > pressing menu on remote or front panel (Refer to the device owner's Guide for instruction).
For STB Motorola DCX-xxxx/DCTxxxx - To change Audio system setting (secret menu) - From the STB remote Control (Cable/satellite supplied remote) turn ON the STB then press [On/Off] Power button then press [menu]button (in quick succession) - a white system menu will display on the TV - Scroll down to: Additional HDMI Settings > Press [Ok] > Scroll down to: Audio Output: > Press [Ok] > toggle between Auto/Lpcm/ Pass-Through > Select Pass-Through - Press [ON/Off] to exit menu - press [ON/Off] again to turn On STB.
For STB Motorola QIP7232- To change Audio system setting (secret menu) - From the STB remote Control (Verizon-supplied remote) turn ON the STB -Press [On/Off] Power button then Press [OK] button then press [menu] button (in quick succession)- a white system menu will display on the TV - Scroll down to: Additional HDMI Settings > Press [Ok] > Scroll down to: Audio Output: > Press [Ok] > toggle between Auto/Lpcm/ Pass-Through > Select Pass-Through - Press [ON/Off] to exit menu - press [ON/Off] again to turn On STB.
Note : take extra caution when system menu is open & avoid change any other settings!! (Refer to the device owner's Guide for instruction).
Tip: Digital Optical Audio Cable, if connected between Revue and AV Receiver - the audio option of Stereo (2 channels PCM) or 5.1Dolby Digital (DD bitstream) can be selected - go to Settings > Picture & sound >Optical audio output.
Harmony Components:
Tip: Can't Control TV /AV Receiver / STB from Revue's keyboard,
- Remove Component (TV/AVR) from Revue - go to Settings > TV& AV Receiver > Select TV or AV Receiver > Remove - Yes
- Remove Component (STB) from Revue - go to Settings > TV Source > Select STB > Remove STB - Yes
- Reboot Revue, Press Ctrl + Alt + DEL
- Re-program Components.
- Place IR Blasters as needed.
Turn OFF HDMI Control from Television-set, AV Receiver & STB (to avoid conflict).
For example;
- Sony TV, turn OFF Control for HDMI, go to Home >Settings > Channels & Inputs > HDMI Settings > Control for HDMI > OFF.
- Samsung TV, turn OFF Anynet go to Menu > Media Play >Anynet+HDMI-CEC > Setup > Anynet = OFF, Auto Turn OFF=No.
Note: Revue doesn't send HDMI control signals to HTS (TV/STB/AVR) via HDMI cables (HDMI-CEC) - All control signals are send from Revue via IR signals.
IR:
Tip: For IR interference Harmony / universal Remote Control - try this,
Take an old 3.5 diskette apart, remove and discard top and bottom shells and woven liners, then take the dark flexible plastic magnetic disk out and cut large piece from it (discard the Hub), bend it 90° and place it to cover Revue IR window, use clear-tap to tap around it.
Make sure you cover the entire IR window (top & front) & Point the remote directly to Revue.
The dark flexible plastic magnetic disk acts well as a filter, especially when TV or other devices censers active. However, any IR remote with Revue will act slightly sluggish!
Tip: IR Blasters, will extend the IR signal - it's needed, if any of the connected devices of HTS (TV/STB/AVR) to Revue are not responding when pressing [Power] - [Volume]-[input] keys on Revue's keyboard. (it can be connected regardless! - No Con's).
Revue has a strong built-in IR Blasters that will send IR signal the IR receiver of the connected devices of HTS (TV/STB/AVR) any time [Power] - [Volume]-[input] keys on Revue's keyboard are pressed - some users may place Revue in a cabinet or place the TV distance away were the IR signal can't reach/bounce - the IR Blasters comes handy - connect it to the back of Revue and place it in front of the IR receiver (IR eye) of TV /STB/AVR - (you may connect more IR Blasters via splitters & extension cables).
Note: Revue doesn't send HDMI control signals to HTS (TV/STB/AVR) via HDMI cables (like Anynet) - All control signals are send from Revue via IR.
Tip: Adding discrete IR codes to Harmony Remote Control . (Exclude Harmony 300)
Log-in to your Harmony account on members.harmonyremote.com, then go to THIS link. You don't have to learn a button first. You create it on the fly. On that page, first click "Select an Active Device" and pick your device. Then click "Manual", paste your hex into the Data Value box under Pronto, and then click "Process". If it's valid, click "Next' and you get the option to name your new command and click "Add".
(thanks to first poster).
Keyboard
Tip: Keyboard Pairing, turn OFF Keyboard - Reboot Revue -
- Press the button on the back of the Revue for One sec - Follow On-Screen prompts.
- Change keyboard battery -(see step above)
Airplay Apps
Tip: Airtight App for GoogleTV - will allow users to stream content from the iPad or iPhone using Airplay
Modem/Router
Tip: For Wireless (WiFi ) or wired (Ethernet) Connection issues,
Unplug power cord from Modem/Router & Revue.
Re-Plug power cord to Modem, wait 5 min.
Re-Plug power cord Router , wait 5 min.
Re-Plug power cord to Revue.
Tip: For wired (Ethernet) - Connection issues,
Unplug the Ethernet cable & power cord from Revue.
Reboot Modem/Router, ( see above steps)
Plug the Ethernet cable to Revue.
Notes: if all devices (Modem/Router/ Revue) are plugged into the same Power-Strip' - turning On/Off The Power-Strip' may reboot all devices at the same time.
More Tips - Connection issues,
Disable MAC address filter on Router.
Make sure the Router is configured to the Primary Network WiFi connections ( Not Guest Network) - Revue may not support Guest Network.
Temporarily disable the Guest Network on Router.
Voice-Modem/digital phone device - connection failed... issues - add/install an additional Router - (Modem/Gateway with Voice/digital phone device > Router > Revue).
For Cable Modem - Connect the Coax cable to the cable Modem through USP to prevent signal spikes - ( Uninterruptible power supply (UPS) with Coax Protection (RG6) and Automatic Voltage Regulation (AVR) is recommended!)
Perform a Factory-Reset on the Router and re-configure it.
Try changing DNS in Router - to Google DNS ( 8.8.8.8 ) or open DNS ( 208.67.222.222 ) - (this option is for advance users).
Troubleshooting:
Tip: To Reboot Revue,
Tip: Device/App issues,
Clear data /cahe/ Force exit - from App (see Application info tip above)
Remove the last App was installed.
Factory- Reset.
[b]Tip: Turn OFF All Connected Devices (TV-STBs-AVR-Modem-Router) -Unplug /disconnect, Power cords & HDMI cables from All Connected Devices - Wait 10 min - plug Power cords & Power-up Modem/Router - wait 5 min - reconnect HDMI cables - plug Power cords & Power-up all other Devices.
Tip: HDMI handshake issues - HDCP issues -Black Screen - Green Screen -Purple Screen - Audio without Video,
Change HDMI cable - Swap cable ends - Plug cable in a different input - cycle between HDMI inputs.
Note: Turn OFF all connected devices, unplug Power cords or turn OFF Power- strip (if in use) - wait 10 min - if the TV red power light still On wait until it goes OFF, before plugging or unplugging any HDMI cables.
Tip: To Performa Factory-Reset -three options to choose from -> .
Tip: After Factory-Reset Harmony Components issues - Re - perform Factory-Reset, this time create new Google Account at sign-in.
If you have tips, share & Post.
Cheers!
avf5 is offline
post #2 of 160 Old 10-28-2011, 01:35 PM - Thread Starter
avf5's Avatar
Download PowerPoint Show file –(you may copy/past any of its contents) - Click here
Cheers!
avf5 is offline
post #3 of 160 Old 10-28-2011, 02:06 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
http://code.google.com/tv/android/do...a_formats.html
some things its supposed to be able to handle
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #4 of 160 Old 10-31-2011, 06:57 AM - Thread Starter
avf5's Avatar
Google TV 2.0 Rolls Out this morning w/ new UI & custom YouTube, including tight integration with Google TV search & new movies/TV App allowing users to browse through 80,000 movies and TV episodes across cable or satellite, Netflix, Amazon, YouTube, HBOGO, Hulu and other sites!!
http://www.psfk.com/2011/10/version-...interface.html
Cheers!
avf5 is offline
post #5 of 160 Old 10-31-2011, 07:21 AM
UHD Addict
aaronwt's Avatar
Quoted: 5195 Post(s)
Liked: 3103
Did it fix the terrible HDMI audio issues?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #6 of 160 Old 10-31-2011, 08:52 PM
donato's Avatar
I guess I'll hook mine back up again to at least check out how the update is.
donato is offline
post #7 of 160 Old 11-01-2011, 05:59 AM
betterdan's Avatar
I doubt it. No word at all on that and it is a common complaint. You would think they would have outed that as a fix if it was done.
betterdan is offline
post #8 of 160 Old 11-08-2011, 08:34 PM - Thread Starter
avf5's Avatar
Logitech has no plans to build a successor to Revue!!
Article, click here
avf5 is offline
post #9 of 160 Old 11-09-2011, 06:36 AM
UHD Addict
aaronwt's Avatar
Liked: 3103
Article, click here
Or did Intel make that decision for them?
aaronwt is offline
post #10 of 160 Old 11-10-2011, 06:47 AM - Thread Starter
avf5's Avatar
Well, Intel pulled the plug on Smart TV processors & Revue has the Intel CE4100 SoS chip. However, Logitech could‘ve gone with ARM chip!!
Also, Adobe abandoning Flash Player for TVs as well & Google TV is using it. Adobe has also bulled the plug on Flash for Mobile devices (acknowledging HTML5).
Now, It’s kind of a surprise to see a major update (GTV 2.0) coming to a discounted & discontinued device.
An STB by Motorola/Google TV maybe in the works (Google’s acquisition of Motorola)
http://gigaom.com/video/google-tv-motorola/
avf5 is offline
post #11 of 160 Old 11-10-2011, 07:19 AM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Man, what's taking Logitech so long to release 3.1 for Revue? Keep checking everyday and still not there.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #12 of 160 Old 11-10-2011, 09:11 AM - Thread Starter
avf5's Avatar
Could be something to do w/ Logitech's value additions to Google TV!! (like Harmony components..).
avf5 is offline
post #13 of 160 Old 11-10-2011, 04:35 PM
thiao's Avatar
Quoted: 17 Post(s)
Was ready to buy a $99 Revue, but so glad I found out that Logitech was pulling the plug on this product.
Last week, BB had a 15" Leveno laptop (e.g. dual core i3, 3GB, HDMI, USB, Win7, DVD, HD etc.) on sale for $299.
Given the superior capability and flexibility in hardware and software....well worth the extra $200.
thiao is offline
post #14 of 160 Old 11-11-2011, 07:16 AM
thiao's Avatar
Quoted: 17 Post(s)
Confirmation of the death of the Logictech Revue.
In addition to what some of you astute folks spotted in Logictech's 10K financial statement.......
Yesterday, Logitech hosted an Analyst and Investor Day and during his remarks, CEO Guerrino De Luca pulled absolutely no punches in describing the "mistakes" the company made with its Logitech Revue Google TV set top box. Calling the company's Christmas 2010 launch "a mistake of implementation of a gigantic nature," De Luca told investors that the company had "brought closure to the Logitech Revue saga" by making plans to let inventory run out this quarter and that there are "no plans to introduce another box to replace Revue."
De Luca suggested that Google TV was far from ready at launch, going so far as to call it "beta" software on one presentation slide, and that the company made a massive misstep by believing that it would revolutionize television right out of the gate. In short, Logitech "executed a full scale launch with a beta product and it cost us dearly." He added more color about Logitech's failure to read the television market in his remarks:
To make the long story short, we thought we had invented [sliced] bread and we just made them. [We made a commitment to] just build a lot because we expected everybody to line up for Christmas and buy these boxes [at] $300 [...] that was a big mistake.
http://www.theverge.com/2011/11/10/2...acement-coming
thiao is offline
post #15 of 160 Old 11-12-2011, 03:41 AM - Thread Starter
avf5's Avatar
Revue/GTV 2.0 update Due Before Year End!!
Click here
avf5 is offline
post #16 of 160 Old 11-12-2011, 07:14 AM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
So much for Revue update being rolled out "soon after" GTV2.0 for Sony devices .
Brajesh is offline
post #17 of 160 Old 11-12-2011, 01:36 PM
Dmon4u's Avatar
Quoted: 92 Post(s)
Liked: 68
Guess it's up to LG to bring out new GTV !
"There he goes again..." - Good Ol' R. Reagan's favorite Troll line !
Dmon4u is online now
post #18 of 160 Old 11-13-2011, 07:06 AM - Thread Starter
avf5's Avatar
LG /GTV 2.0 may show-up in January, hopefully revue/GTV 2.0 update would show-up before!!
Click here
avf5 is offline
post #19 of 160 Old 11-15-2011, 09:23 PM - Thread Starter
avf5's Avatar
Revue/GTV2.0 to be updated in the next couple of weeks!
Click here
Cheers!
avf5 is offline
post #20 of 160 Old 11-16-2011, 09:04 AM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Found this via a Google search for Revue news...
So, will we even get the 3.1 update? And assuming we do, beyond that, will Logitech even support the Revue?
Brajesh is offline
post #21 of 160 Old 11-16-2011, 10:56 AM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
They will support it - as in.. It breaks during your warranty period they will send you out a new one. All development of software will stop and probably has stopped for a while. All that's left is last minute testing of Honeycomb.
almostinsane is offline
post #22 of 160 Old 12-06-2011, 07:25 PM
balboa dave's Avatar
Quoted: 17 Post(s)
Logitech Revue Android 3.1 upgrade starts rolling out - Engadget
It appears owners of the Logitech Revue will finally be able to get their taste of Honeycomb starting tonight, as a few lucky users have already received an upgrade to Android 3.1 and support techs have informed them a wider rollout is beginning this evening. That puts it about a month behind Sony's Google TV boxes in receiving the upgrade, but will finally bring owners a whole new UI, and access to the Android Market -- and live up to those stickers on the outside of the box. The usual considerations apply about it being a rolling update so while your $99 box may not see the new software right away, it's definitely coming.
balboa dave is offline
post #23 of 160 Old 12-07-2011, 12:11 AM
Dmon4u's Avatar
Quoted: 92 Post(s)
Liked: 68
From the posts over in the Engadget thread, there is NO UPDATE !
http://www.engadget.com/2011/12/06/l...s-rolling-out/
This all came from a thread at Logitech's Forum:
http://forums.logitech.com/t5/Revue/.../740934/page/7
* I'm guessing Logitech will have some sort of Press Release in the morning !
My update, THIS MORNING:
http://blog.logitech.com/2011/12/07/...ogitech-revue/
Looks like this is happening !
post #24 of 160 Old 12-07-2011, 03:08 AM
Quoted: 17 Post(s)
Yeah, it appears Engadget took a single post from the Logitech Revue forum that claimed to have gotten the update, and blew it out of proportion by saying there were more. The update does exist, and it is due out this month according to Logitech, just not today, I guess. It certainly hasn't appeared on my Revue.
post #25 of 160 Old 12-07-2011, 05:12 AM - Thread Starter
avf5's Avatar
Revue GTV2.0 (Android 3.1) upgrade starts rolling out this week.
Article 1 click here….
Article 2 click here….
Article 3 click here….
Cheers!
avf5 is offline
post #26 of 160 Old 12-07-2011, 04:36 PM
Charles R's Avatar
Liked: 536
With Android 4.0 (Ice Cream Sandwich) becoming available later this month (already available on one device) isn't 3.1 over the hill? Before it's even released... and with Logitech killing off the Revue what's the odds it sees another update?
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #27 of 160 Old 12-07-2011, 05:04 PM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
GMail was in beta forever until what... last year? So yes expect updates, upgrades and new firmware versions for quite sometime.
Gary J is offline
post #28 of 160 Old 12-07-2011, 05:18 PM
Charles R's Avatar
Liked: 536
I have no doubt Android will be updated. However since Logitech has canned Google TV I can't see them doing the (required) work to pass them on... My guess is they were stuck with 3.1 since it's on the box... after that all bets are off?
post #29 of 160 Old 12-07-2011, 05:28 PM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
My guess is Google is too smart to not have something in a contract about continued support no matter what.
Gary J is offline
post #30 of 160 Old 12-07-2011, 05:50 PM
skro's Avatar
Quoted: 13 Post(s)
I don't think they do. Logitech is not going to upgrade after this 3.1 rollout. They are abandoning the Revue. (They don't seem to require this of phone manufacturers, look at the mish-mash of upgrades to newer android builds on older phones)
There is an article on "the verge" today stating the Google expects to have Google TV baked into about half of the TVs that are coming out next year. If that is the case, I can understand Logitech not wanting to stay in the game for much longer.
skro is online now
