HiMedia HD900B Full 3D Media Streamer (Realtek 1186-based) - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 1578 Old 12-01-2011, 11:22 AM - Thread Starter
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 128
1:1 copy (Use AnyDVD HD or DVDFab to get an unprotected ISO).
Hi-deft Media Keen Videosaurus
Brajesh is online now
post #542 of 1578 Old 12-01-2011, 11:37 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Originally Posted by diablozoe View Post
Do I need to convert to SBS or should a 1 to 1 copy work just fine?
The whole reason for this player is to be able to retain 1:1 and not convert to SBS
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #543 of 1578 Old 12-01-2011, 12:55 PM
DiabloZoe's Avatar
Quoted: 14 Post(s)
Yeah I'm new to the 3D scene and with the narnia move what I watched of it nothing really was jumping off the screen right infront of me and I did a 1:1 iso with Fab
DiabloZoe is offline
post #544 of 1578 Old 12-01-2011, 02:02 PM
theaxledentaldj's Avatar
Avatar 3D is always a good demo 3D. If you want more pop out and things thrown at you, Just wait for Final Destination 5 3D. I hear Open Season 3D is a good demo. I'd also check out Despicable Me 3D. Narnia The Dawn Treader was a 2D converted to 3D movie.
theaxledentaldj is offline
post #545 of 1578 Old 12-01-2011, 03:29 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Keep in mind not alot 3D movies are created equal. The ones that were filmed in 2D and converted to 3D can be hit or miss. Avatar is a great example, many of the Disney animation movies and great, and t he IMAX Under the Sea is solid
Cheers,
Damian
post #546 of 1578 Old 12-01-2011, 06:40 PM
inefekt's Avatar
This media player must have alzheimer's cause whenever you turn it off it completely forgets everything you taught it!
Not only does it forget your media library but also your network settings as well as any external HDD's you have attached to it.
Every time I turn it on it fails to recognize the external HDD, in fact the HDD doesn't even power up, I have to remove it from the USB slot then put it back in, this unfortunately makes the player reboot itself!
HiMedia - just give up and leave the media player business to those that actually know what they are doing
inefekt is offline
post #547 of 1578 Old 12-01-2011, 07:49 PM
teohwk's Avatar
Hi guys. Any of you tried displaying 2 subtitles of different languages at once? Is this possible? This feature is important to me. Me and my other half has different language preference.
teohwk is offline
post #548 of 1578 Old 12-01-2011, 08:35 PM
DiabloZoe's Avatar
Quoted: 14 Post(s)
You would think a movie given out with a starter 3d pack would rock but guess not!
post #549 of 1578 Old 12-01-2011, 09:56 PM
denass's Avatar
Quoted: 16 Post(s)
I am awaiting external sata caddie to arrive and connect to the sata port on the 900b.It has easy front access to the hdd and means the 900b doesnt have a hdd in it.If I have problems like you with usb this thing the 900b is gone.Feel your sediments about himedia too.I just wanted something that was stress free.The audio thru a TV dropping to 30% is just not on.Dont they do any basic testing.
I thought I was wrong once but I was mistaken
denass is offline
post #550 of 1578 Old 12-02-2011, 02:57 AM
teratak's Avatar
i'm very disappointed with the player after 3 week use it cannot boot up...even i want to safe mode upgrade also can't coz it can't detect pendrive. Send it to seller, he give me the new player. With new player 1st time turn on everything ok but after 2nd time turn on VFD no display but the player can function as normal. Is it any setting on player to turn off/on the VFD.
teratak is offline
post #551 of 1578 Old 12-02-2011, 03:20 AM
denass's Avatar
Quoted: 16 Post(s)
yes there is in the menu where you can turn VFD on or off
In your manual--page 5 number 4 down
denass is offline
post #552 of 1578 Old 12-02-2011, 03:49 AM
teratak's Avatar
i tiried to triggered it ...no display also.
teratak is offline
post #553 of 1578 Old 12-02-2011, 03:50 AM
teratak's Avatar
why when i using android the display was exceed from my televisyen display ..i'm using panasonic 50 inch plasma. I tried to play around with the video setting all same ...anyone have the solution...pls advice. HDMI cable can cause the problem?
teratak is offline
post #554 of 1578 Old 12-02-2011, 04:34 AM
denass's Avatar
Quoted: 16 Post(s)
have you tried the VFD button on the top of your remote
denass is offline
post #555 of 1578 Old 12-02-2011, 05:55 AM
quicktrick's Avatar
2 leo140hd
Is it possible to make the button 'Search' working while playing music in the same manner as while playing movies?
quicktrick is offline
post #556 of 1578 Old 12-02-2011, 06:25 AM
zaras27's Avatar
Which internal sata are you proposing for the 900B please ?
zaras27 is offline
post #557 of 1578 Old 12-02-2011, 07:54 AM
silverlight's Avatar
[Bug Report]
Was sitting down and using the unit for the first time last night with the new (beta) firmware. Updating was smooth and no problem, just used the advice of others and unplugged the internal hard drive. I use an internal 2TB HD and have about 1.5GB of BD ISO's on it (both 2D and 3D). We sat down to watch a movie (Hancock) in BD, and it started stuttering very badly about 6 min's in. Tried skipping around the movie, changing from the various BD navigations (BD Lite, 1.0, etc.) and could not avoid the stuttering. The recreated with the same file after a full re-boot. Also happened with the next two 2D BD ISO's I tried (Iron Man 2, LoTR). All the movies start just fine, it's after a few minutes, or any chapter searching the it starts. These files work flawlessly on my computer (iMac 27 latest version running Mac BluRay Player).
So... basically a brick at this point. Will see if it's possible to downgrade the firmware to the 0.26 version to see if that enables basic 2D playback.
AV stuff here
silverlight is offline
post #558 of 1578 Old 12-02-2011, 08:03 AM
frostiex's Avatar
I have been reading this thread, as I am in the market for one. My current PBO is starting to fail and I need a replacement. It seems people are frustrated with this box? I am contemplating on the Aios or this one. how are you guys liking the 900B?
frostiex is offline
post #559 of 1578 Old 12-02-2011, 10:12 AM
quicktrick's Avatar
Not at all. I like it very much. I play the movies and music from the NAS and the player behaves very well, there are practically no problems. I've been using it for about a month.
post #560 of 1578 Old 12-02-2011, 10:45 AM
DiabloZoe's Avatar
Quoted: 14 Post(s)
There is a button on the remote
post #561 of 1578 Old 12-02-2011, 04:21 PM
denass's Avatar
Quoted: 16 Post(s)
if your not wanting 3D get a dune.I have both dune and 900b. The 900b is full of problems and not supported from the manufacturer.Might be best to search product forums to see just how good or bad they perform.Nothing worse then buying something and tearing your hair out trying to get it to work as advertised.
denass is offline
post #562 of 1578 Old 12-02-2011, 07:58 PM
teratak's Avatar
already tried it but still no display ....i think it hardware problem. I already open the player see if have any contact problem on the cable socket to VFD ..nothing abnormal found, this is the 2nd player dealer give to me...1st one only use 3 week can't boot up ..flash also failed. For me this player was not very good in quality term.
teratak is offline
post #563 of 1578 Old 12-03-2011, 10:40 AM
xiaNaix's Avatar
The Dune can play SBS rips but not full 3D BD. I have a Dune Prime as my main player and a Panasonic BD player for the 3D stuff.
xiaNaix is offline
post #564 of 1578 Old 12-04-2011, 04:30 AM
denass's Avatar
Quoted: 16 Post(s)
I have sent the following to Himedia direct.
hopefully they will be able to fix.
I have purchased a 900b of yours.
I have found the sound volume when connected to a fairly new LCD TV via hdmi extremely low.
I am not using a amplifier or receiver.The 900b is just connected to the TV.
I have noticed others on forums saying the same thing.
The volume is 30% of the TV and my bluray player so when you switch back to the TV or bluray after watching the 900b you are blasted by a huge amount of sound---the 900b is not level matched like the bluray player.
Questions
Are you going to fix this and can it be fixed via a firmware update.
If not can I return the unit as I am not happy with this issue.
Again others are having the same issue.
denass is offline
post #565 of 1578 Old 12-04-2011, 11:43 AM
mraudio13's Avatar
I have the same tv and the same problem. I think it is sending too much of an overscanned picture to the tv. Honestly the "android" part of the 900b is just a marketing gimmick to sell the player. They put the android robot on the box and make it sound like android is a big part of the OS, but it isn't. I am really questioning my purchase of this unit for the sole advantage of playing BD ISO's. I keep comparing it to a boxee or my HTPC, and it doesn't stand a chance against either.
mraudio13 is offline
post #566 of 1578 Old 12-04-2011, 06:31 PM
inefekt's Avatar
Yes it seems the only good thing about this player is that it plays 3D BD ISO and it doesn't even do that 100% well (forced subs not working).
Also, does anyone else notice an intermittent flash of 'enhanced grain' when watching mkv files? Sorry but I can't explain it better than that, it is especially prevalent in darker scenes, like a flash of bright grain that lasts a fraction of a second and occurs every 5 seconds or so?
inefekt is offline
post #567 of 1578 Old 12-05-2011, 03:53 PM
leo140hd's Avatar
Originally Posted by quicktrick View Post
2 leo140hd
Yes it is supposed to work the same..., please if you have any other observation just tell me.
(I'll send the obs to HM)
Real 1080p Fan ! ! ! Living to Enjoy it's very best ! ! ! (...if I can afford it...)
leo140hd is offline
post #568 of 1578 Old 12-05-2011, 04:45 PM
dmoney94's Avatar
Im glad i didnt jump on it when it came out....
dmoney94 is offline
post #569 of 1578 Old 12-05-2011, 05:14 PM - Thread Starter
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 128
For less than $200, it isn't bad at all for what it's really meant for: playback of full 3D BD-ISO's. I rely on my PCH A-300 and PopBox v8 for 2D (with full jukebox and streaming from my home server), so I'm using HD900B for 3D BD-ISO's only (via local USB). With the exception of forced subs in movies like 'Avatar' and sync invert issue in 'Rio', this player is just fine with 3D BD-ISO's. If you're looking for a really good 2D home theater streamer as well, this isn't it (yet anyway), rather Dune or PCH/PopBox v8.
post #570 of 1578 Old 12-05-2011, 05:24 PM
denass's Avatar
Quoted: 16 Post(s)
Is the upscaling any good on the 900b.I havent had a chance to check it out--my dedicated hometheater has the dune and that's excellent.I am waiting on the hardrive caddie to arrive and run it from the side sata outputs.Havent heard back from Himedia about low audio matching problem on my Tv with the 900b.
denass is offline
