HiMedia HD900B Full 3D Media Streamer (Realtek 1186-based) - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 1578 Old 12-14-2011, 06:06 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Hey Brajesh,
Is this the issue you had with Rio?
Source: Unmodified 3D Bluray.ISO of Rio (European version)
Playback: HDMI 1.4 directly on Samsung TV
BDLite = OFF
Problem: Most (90%) 3D Bluray.ISO contain content that is Left Eye First, 10% Contain content that is Right-Eye First.
Normally a 3D Bluray player detects the content type and sends Left Eye First to the TV.
The Prodigy does not seem to do this check and sends Right-Eye First to the TV.
As the images are reversed the picture contains no 3D depth and gives you a headache.
Workaround: On Samsung and some other TV's it is possible to switch image
- Samsung "C" Series > Tools > 3D options > Image Correction
- Samsung "D" Series > Menu > 3D > Select Left Eye First or Right Eye first
- Wear your glasses upsidedown (for testing)
Known disks with Right-Eye First:
Rio (Tested incorrectly)
Sammy's adventures (Not tested Yet)
Gullivers Travels (Not tested Yet)
In general the Realtek 1186 is not looking too promising (at least in its current state)
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #632 of 1578 Old 12-14-2011, 06:27 AM - Thread Starter
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 129
Yep, it's the same issue with the U.S. disc/ISO I have. You can manually invert sync on most 3D displays, but with my Optoma HD33 PJ, that option is greyed out when using RF mode/glasses (and only available with DLP link mode/glasses).
Glad to see HiMedia aggressively releasing firmware updates. Hoping some of the issues are not with the 1186 Realtek chip itself.
By the way, have you tried the latest firmware? Wondering if Na'vi subs in 'Avatar 3D' now work, or forced subs in general.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #633 of 1578 Old 12-14-2011, 06:47 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I am not sold on the 1186 chip tbh. Just finished reading around on the Xtreamer forum and lots of problems over there as well. It is tough to distinguish between fw issues and limitations in the chip. One person commented that they believed that the chip could not handle high bitrate scenes for 3D Blu ray, don't know what the consensus is.
I haven't turned on the HiMedia in the last few weeks. Hope to wrap up the A300 review, then work on the Mede8er, and hopefully at that point things will appear a little clearer/brighter for the HiMedia
Cheers,
Damian
post #634 of 1578 Old 12-14-2011, 07:24 AM
inefekt's Avatar
Originally Posted by denass View Post
glad it has worked out fine--seems then usb 2.0 is ok then---you learn something new every day
I am finding tho that the 900b isnt playing the movie as smooth as on the dune--its like frame jumping on moving objects-very minor but noticeable
yeah I've noticed that too, not really bad though.
inefekt is offline
post #635 of 1578 Old 12-14-2011, 07:27 AM
inefekt's Avatar
yes, this is a major issue and I swear I saw it working on my unit when I'd first purchased it, prior to doing any firmware updates so I'm sure it's not a limitation of the chip.........I mean, they're just subtitles after all
inefekt is offline
post #636 of 1578 Old 12-14-2011, 07:43 AM - Thread Starter
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 129
Honestly, I've always regarded Realtek chips as second rate to Sigma, long before 3D (maybe it's being unfair). So, if the issues are indeed chip-related, players like the HD900B will be a stop-gap until we see those with Sigma's next-gen ones.
Brajesh is offline
post #637 of 1578 Old 12-14-2011, 07:47 AM
denass's Avatar
Quoted: 16 Post(s)
I thought it might be a setting or the tv but bluray discs played on a panasonic bluray player are fine--I hate this jerky movement--I put one on the 900b this evening--SPACE BATTLESHIP YAMATO--it was distracting so went and put it my dune thru my projector and was smooth as silk.I am downloading the beta firmware now--god I am hating this 900b
I thought I was wrong once but I was mistaken
denass is offline
post #638 of 1578 Old 12-14-2011, 07:49 AM
denass's Avatar
Quoted: 16 Post(s)
thats exactly my plan--hopefully on a new dune
Never heard back from a email I sent to Himedia in china about the very low volume of the 900b on a normal fairly new LCD.
denass is offline
post #639 of 1578 Old 12-14-2011, 09:38 AM
denass's Avatar
Quoted: 16 Post(s)
Have just downloaded firmware 1.01.10 beta and set in menu DIRECT PLAY and now SPACE BATTLESHIP YAMATO is playing smoothly
maybe check and see what you think--I only checked briefly but looks better
denass is offline
post #640 of 1578 Old 12-14-2011, 05:36 PM
inefekt's Avatar
what have they fixed in the newest firmware, can't find anything on google
inefekt is offline
post #641 of 1578 Old 12-14-2011, 06:25 PM
theaxledentaldj's Avatar
Dbone/ Damian, have you or anyone else tried playing the Planet Earth - Bird Clip 60MB/s on the HiMedia 900B? http://www.nmtfiles.info/DVD5Test/Bi...ing/bird60.mkv
Would that be a high enough bitrate test for the 1186?
theaxledentaldj is offline
post #642 of 1578 Old 12-14-2011, 09:02 PM
denass's Avatar
Quoted: 16 Post(s)
Couldnt find anything about the new firmware either--going to test it some more this evening
Just been checking out the 900b and the image is now running smoothly and DIRECT PLAY seems to be the way.All was going well until I tried switching the unit off.It stayed on with the harddrive spinning loudly--had to pull the power plug on the back--tried a few times switching it off and on but was working fine again.Make sure the red light comes on when you turn it off.Happy with the picture being smooth and not jitttery.
denass is offline
post #643 of 1578 Old 12-15-2011, 04:11 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Haven't tried yet but that is one of my usual tests (I actually have the bird scene going from 30MB/s to 100 MB/s). 60MB/s-70MB/s is typically where I cap out over SMB on any of the players that I test (with NFS I can usually get up to 100MB/s)
Cheers,
Damian
post #644 of 1578 Old 12-15-2011, 04:31 AM
zaras27's Avatar
From futeko and OllyP for the 1.0.1.10
- Fixed network visibility ( shown as HD900B )
- Lipsync activated
- Use your own backgrounds for Homescreen
- greatly improved German translation
- Weather app on the Homescreen
- HiMedia Online-TV removed (IMS button opens Internet Apps)
zaras27 is offline
post #645 of 1578 Old 12-15-2011, 05:53 AM
denass's Avatar
Quoted: 16 Post(s)
- Lipsync activated
from what I can gather there is the 1.0.1.10 beta brought out by himedia and the one on futeko is modified himedia firmware--1.0.1.10 is working fine on my machine but I dont think I have the modified firmware--hopefully we will be informed soon
denass is offline
post #646 of 1578 Old 12-15-2011, 12:14 PM
o21r3s's Avatar
Portuguese characters like ã, é, ô in external subtitles are replaced by chinese characters, i think. Is it a bug?
o21r3s is offline
post #647 of 1578 Old 12-15-2011, 05:04 PM
inefekt's Avatar
- Lipsync activated
So, forced subs STILL NOT FIXED.
C'mon Himedia, get your act together!
inefekt is offline
post #648 of 1578 Old 12-16-2011, 02:13 AM
totti1001's Avatar
- Lipsync activated
That is not the changelog for the Himedia Version, this is OllyP´s own Custom rom and was his has fixed in die 1.0.1.10
totti1001 is offline
post #649 of 1578 Old 12-16-2011, 07:30 AM
silverlight's Avatar
Just want to say on the constructive side I DO appreciate the frequency with which new beta's are coming out. I have notices improvements in my setup as they've rolled out. So I hope this pace keeps up!
AV stuff here
silverlight is offline
post #650 of 1578 Old 12-17-2011, 06:38 PM
brm66's Avatar
Where I can buy this player on the Internet. I live in Miami, Florida
brm66 is offline
post #651 of 1578 Old 12-18-2011, 07:29 AM
DiabloZoe's Avatar
Quoted: 14 Post(s)
http://www.multiupload.com/8Z4XUZMPW2
- Bit Torrent Working ********** !
- Lipsync activated
- greatly improved Italian translation ( by sensistar9 - Futeko Forum )
- new Portuguese translation (in the moment with google!)
DiabloZoe is offline
post #652 of 1578 Old 12-18-2011, 07:48 AM
Hemanth's Avatar
Hi all,
I am planning to buy the new HiMedia 900B. Could anyone please answer the following questions?
1. Does it support 3TB NTFS formatted USB 3.0 external hard drives (All my MKV 1080p movies are two of those Seagate Goflex 3 TB drives) ? My research showed that many others like NeoTV 550 or WDTV HD do not have this support and won't detect external drives above 2TB.
2. I have a Virgin Broadband with Wifi at home. Will I be able to connect 900B to this WiFi network to stream content like youtube videosetc.?
Cheers,
Hemanth
Hemanth is offline
post #653 of 1578 Old 12-18-2011, 08:01 AM
djc11369's Avatar
Quoted: 243 Post(s)
Liked: 141
You can get it on Amazon or from the vendor selling it on there, nikingstore.
Personally I'd get the Micca EP950 which is $70 less and looks to be a 900B clone. I bet you could even flash it with the HiMedia firmware if they're not already the same. You can get that on Amazon also and is fulfilled by Amazon so returns are real easy.
djc11369 is offline
post #654 of 1578 Old 12-18-2011, 03:48 PM
Metric's Avatar
Quoted: 182 Post(s)
Liked: 57
So you use a usb mouse for apps... anyone gotten bbc or itv players to work?
I want to die in my sleep like grandpa... not kicking and screaming like the people in his car.
FS: Sony 40ES with UH-380
FS: New Xbox One S
Metric is offline
post #655 of 1578 Old 12-18-2011, 08:59 PM
DiabloZoe's Avatar
Quoted: 14 Post(s)
Ok WTF this micca player is identical! Everything the remote, the software?? Is this a company owned by HiMedia or vice versa?
post #656 of 1578 Old 12-18-2011, 10:27 PM
Well almost identical as the EP950 has no built in 802.11n wifi. HD900B is on amazon for $269. Thats $120 bucks more for wifi than the Micca EP950. There might be other h/w differences.So who wants to do a side by side comparison between the two? You have to own both.
post #657 of 1578 Old 12-19-2011, 04:46 AM
djc11369's Avatar
Quoted: 243 Post(s)
Liked: 141
The Nikingstore must have ran out of stock, it was on there for $220 yesterday.
The Xtreamer US Distributor vendor is over priced on just about every media player.
I don't own either so yes a side by side comparison would be good. I wonder what the wifi dongle costs for the Micca, I'm betting still less than $70. The one on Amazon is $20 but not sure if it's compatible with this player. Jack at Micca frequents this forum so start a thread with Micca EP950 as a heading and I'm sure he'll clarify the differences.
djc11369 is offline
post #658 of 1578 Old 12-19-2011, 06:29 AM
denass's Avatar
Quoted: 16 Post(s)
Sent a couple weeks ago a email to Himedia in china via their web page asking about the very low audio volume when just connected to a lcd tv.Still no reply and bet I wont get one either--this company hasnt even the common decency to at least reply.Cant wait for the new dune models next year and this piece of crap is gone.
denass is offline
post #659 of 1578 Old 12-19-2011, 08:43 AM
b.corso's Avatar
Are you the only one with this audio volume problem or is this a common issue?
I emailed HiMedia directly about an issue I was having, they replied within a few days. Maybe you should send a follow up email.
b.corso is offline
post #660 of 1578 Old 12-19-2011, 08:54 AM
denass's Avatar
Quoted: 16 Post(s)
Futeko.com helped--it was the volume on the remote is set by default to 50%.I never tried using it as I just used the tv volume.Feel like a real idiot for not checking it--just upped the volume to max on the 900b and volume is now level matched to the other components.
much gratitude to futeko.com
happy now
denass is offline
