HiMedia HD900B Full 3D Media Streamer (Realtek 1186-based) - Page 53 - AVS Forum | Home Theater Discussions And Reviews
post #1561 of 1578 Old 02-11-2014, 06:44 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Originally Posted by inefekt View Post
It'd be nice to have a quad core CPU but my main focus when buying a media player is the ability to play 3D Bluray ISO files. This unit does not do that while one of the HiMedia's selling points is that it's the only Android device to play these files.
As usual there doesn't seem to be one player that can do everything I need it to lol
What else do you need aside from 3D Bluray ISO files? Just curious, definitely not a fan of HiMedia
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #1562 of 1578 Old 02-18-2014, 05:48 PM
zort's Avatar
I spent tons of time searching for a newer firmware to install. I was using Ollyp's last version and I felt outdated. I saw someone recommend a Bast Castle firmware from a long time ago, then through further research I found a modified version of (possibly) the best version of BC. It was just released in December so I am pretty sure it is the most recent mod. It is labeled BC_v1.04_Mod3. I am unsure of forum rules as far as posting a download link. I'll post it anyways in hopes that it's ok. If not - I apologize to the adminsand they can delete my message. I have personally installed this version using safe mode and it works great. I no longer have the urge to go buy another player right away. It was meant for the Egreat r6s but works fine on the Himedia 900's.
Download link
zort is offline
post #1563 of 1578 Old 02-18-2014, 05:58 PM
Stiltz's Avatar
Quoted: 18 Post(s)
If anyone is looking for one of these let me know.
Media Room - JVC RS500 PJ, 130" Dalite JKP 1.3, Anthem MRX 1120 AVR, Panasonic UB900 UHD, Martin Logan Vantage, ML Stage, 4xML Motion FX, 4xML R Ceiling, PS Audio PWD, Seaton Submersive F2 / 2xOutlaw LFM-1EX / HSU MBM Subs, Dune 3D, Sonos, HTPC, 2xButtKicker
Family Room: LG 65EF9500 OLED, Marantz SR7010, Philips UHD, 2xMartin Logan Motion 15, ML Motion C2, 2xML Motion 2, 2xML IC Ceiling, REL T9 Sub, HTPC
Stiltz is online now
post #1564 of 1578 Old 02-18-2014, 06:54 PM - Thread Starter
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Not worth buying this player at this point as several (far) better alternatives exist. HiMedia was the only game in town when it first debuted, one of the very first RTD1186 players on the market. At this point, better to go with Mede8er X3D series (my #1 pick), followed by PCH 400 series, followed by Dune TV303D, followed by other 1186 players like KdLinks if you must.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #1565 of 1578 Old 02-19-2014, 02:35 PM
fight4yu's Avatar
Liked: 43
Download link
what does this FW do?
fight4yu is offline
post #1566 of 1578 Old 02-19-2014, 05:44 PM
zort's Avatar
Call me a fool but I know very little about it. I went off the reputation of bast castle firmwares constantly having been updated. From what I read they actually stopped releasing newer versions and this version has been modified by someone named HiHat.
It plays my videos smoother than the last ollyp firmware I had. The GUI has a totally different appearance. I noticed all of my audio files have played correctly. DTS HD MA, DD TrueHD, etc. For the BDMV folders you hit play and it goes to the disc menu. It included an IPTV app but it doesn't really work. I don't need it for that anyway.
Here's the thread I got it from:
http://moservices.org/forum/viewtopic.php?f=40&t=2938
I figured out how to edit the IPTV playlists in the web based interface. It's pretty awesome. Used google to translate the russian and find some m3u playlists.
zort is offline
post #1567 of 1578 Old 06-20-2014, 07:06 AM
Liked: 0
hi zort,
found your posts looking for new firmware for my hd900b. tried and it working great.
can you get the led panel display the right command? mine only show word 'boot' after flashing. do you know where to look to fix it?
biscuity is offline
post #1568 of 1578 Old 06-20-2014, 03:27 PM
zort's Avatar
Originally Posted by biscuity View Post
hi zort,
I'll have to check, I know there is a web based interface that you can log into, but the text is all Russian and by dumb luck I only figured out how to update the iptv.m3u playlist. I'm sure there is a way to modify the information but that sounds more like a code error. Maybe the player that it was originally designed for doesn't have an led display? I just have the 900A so mine lacks the display.
http://"media player network ip address"/editor/
zort is offline
post #1569 of 1578 Old 06-21-2014, 07:48 PM
Liked: 0
hi zort,
thanks for your quick reply.
found out the firmware really does not support display panel. after digging further i found older version 1.0.5.7 with mos3 installed. - http://www.moservices.org/forum/view...tart=60#p44726
got back the display, and a bunch other stuff come with mos3. very happy now.
biscuity is offline
post #1570 of 1578 Old 08-28-2014, 01:48 PM
maddy_in65's Avatar
Liked: 0
I got new 3D tv, I tried to play 3D Iso as well as 3D MKV files but nothing is working. When i tried to play 3D ISO, unit hangs for long time and it restart. It happened several times. When I tried to play 3D MKV files I am getting split image on screen, I tried to change various settings like 3D conversion, 3D top bottom, 3D side by side but still having split image not actual 3D image. My TV is Samsung Plasma 43H4900.
maddy_in65 is offline
post #1571 of 1578 Old 08-29-2014, 03:54 PM
vampiresk's Avatar
Smile
Hi Maddy
Do you use a HDMI cable 1.4?
vampiresk is offline
post #1572 of 1578 Old 08-31-2014, 04:42 AM
saj2001ind's Avatar
Unprocessed lossless audio out through optical out
Hi guys,
If I connect my speakers to optical out of hd900b and steam music through dlna on to hd900b will it be sending unprocessed lossless audio signal to my speaker system
actually I have a nad viso 1 speaker system which has its own DAC and I just want to feed to it raw unprocessed audio signal so that the DAC is only used of nad and not on hd900b
saj2001ind is offline
post #1573 of 1578 Old 12-01-2014, 01:33 AM
pamarakos's Avatar
Hi my friend,
Can you please check a dolby atmos true hd 7.1 sample
and let us know if it plays ok?
Thanks a ton
pamarakos is offline
post #1574 of 1578 Old 12-01-2014, 05:39 AM
bernardo61's Avatar
Quoted: 12 Post(s)
Hi Guys !
i need your kind help
I know i should have read all the thread before asking but please ... try to understand my pain
I have this hd900b ... i upgraded to what i think is the last FW but still i cannot use the keyboard
Some of the buttons are still in chinese language
So i am here to ask to you very kindly and with great hopes:
1) which is the best FW around possibly without chinese terms in the menu ?
2) an usb mouse is working not so a wireless keyboard. What are you using as keyboard ?
3) i see a pretty similar model the HD910b. Maybe this have a better FW and GUI. Can i load them on to the HD900B ?
4) is it possible to upgrade to Android 5.0 Lollipop ? it must have a usb audio support. I would like to use the HD900B as a nice digital source for a usb dac i already have
Thank you anyway
Great people. Great site.
Kind regards,
bernardo
bernardo61 is offline
post #1575 of 1578 Old 12-05-2014, 09:04 PM
Liked: 0
hey bernardo61,
check my previous post for custom fw hd900b (scroll up my last post)
for Q1 - 3, try the firmware first to see if it fix all 3.
Q4 - impossible to upgrade to lollipop, you need to customize the fw, the hardware itself not sufficient for lollipop requirement. for the audio, maybe you can try converter cable like this >> ebay.com/itm/New-5ft-USB-Male-A-to-3-RCA-AV-TV-Adapter-Cord-Cable-red-yellow-White-/121251020070
biscuity is offline
post #1576 of 1578 Old 12-09-2014, 03:30 PM
bernardo61's Avatar
Quoted: 12 Post(s)
Talking
hey bernardo61,
Hi thank you very much indeed for your kind and valuable reply
I have downloaded now the FW and tomorrow i will try it for sure
as it is with the original FW is a joke this player
I mean .. it can be perfectly ok for the chinese market. Hardly an exportable product.
Also my dog speaks english these days ...
Thanks but i am trying to use this hd900 because i have to say that the video is not bad at all reading from a usb disk
I see a potential but the GUI must be reworked completely
And i am sure they could do it ... with great commercial benefits
this i dont understand ... a cable from usb to analog AV ??? and it works ???
By the way i will try an external dac and listen for improvements anyway
But i would like to use it mainly as a network streamer (wired not wifi ... life is already complicated)
To end thank you sincerely again
I will load the FW hoping to succeed
Kindest regards,
bernardo
post #1577 of 1578 Old 12-09-2014, 05:40 PM
Liked: 0
yes, you need to check input jack type on the speaker.
if AV output from himedia to USB input on speaker, that cable should work.
biscuity is offline
post #1578 of 1578 Old 12-10-2014, 01:23 AM
bernardo61's Avatar
Quoted: 12 Post(s)
Good morning and thanks a lot again for your kind and very valuable support
I am eager to try the FW
But i have to wait the weekend ... i am in deep s..t at work
I will let you know how it will go
I have seen the update procedure and found it a little tricky
Hope to be able to carry it out
Thanks again, bernardo
