*Official* Popcorn Hour A-300 / C-300 Thread - Page 15 - AVS Forum | Home Theater Discussions And Reviews
post #421 of 450 Old 07-10-2014, 01:23 AM
Liked: 0
Popcorn A300 help!!
Hi everyone
My father in law has just got himself a A300 and I ahve a problem setting it up for him
It seems that the parental lock is on and there is no way to turn it off to allow me to run the set-up wizard.
Does anyone have any ideas??
Many thanks in advance
trotter232 is offline
post #422 of 450 Old 07-10-2014, 05:36 AM
UHD Addict
aaronwt's Avatar
Quoted: 6388 Post(s)
Liked: 3951
WHy not reset to the factory defaults? It's in the firmware update section.
Or according to the manual, the default setup lock password is 4896.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #423 of 450 Old 07-18-2014, 07:49 PM
spinbot's Avatar
I've had a few issues , mostly operator error or operator playing with 3rd party software causing an error. This time, I think I am innocent of issue, but just not sure how to resolve it.
When I am in file browsing mode, i can no longer switch to Jukebox or Jukebox Manager as I get a "Database Read Error".
The server I am accessing is run by UnRaid and works perfectly, so I have no concerns with it, especially considering I can access it and play content back through File Browsing Mode.
Any suggestions would be appreciated.
spinbot is offline
post #424 of 450 Old 07-18-2014, 11:13 PM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
your NMJ database is corrupted. I would try to open it with NMJtoolbox and see what it says. if not just delete it and start over.
halfelite is online now
post #425 of 450 Old 07-25-2014, 06:17 PM
spinbot's Avatar
I tried NMJtoolbox 2 many months ago and thought it was an excellent tool until I ran in to an odd issue that I simply could not fix (after manually trying to get my Vikings episodes to display right). The issue I had was basically I had a default image in the graphical listing for Vikings (as it wasn't reading it properly) and when selected, it would reboot the Popcorn Hour on me. Regardless of my reason, the point i was getting to is that I stopped using the Toolbox. I've since changed computer and don't have it setup anymore.
I've tried to install it again (which isn't the hard part). I had stored my "nmj_database" folder on one of my network drives (this wasn't so much planned as that is where it just happened to land). When I browse to the "media.db" file, it tries to load but gives me a big window indication an error of:
Error Retrieving Database Object (as the heading) and then a really long body saying:
System.Data.SQLite.SQLiteException: SQLite error
no such table: DB_VERSION
at System.Data.SQLite.SQLite3.Prepare
(and a lot more after this)
I just click "OK" and get an "Unhandled Exception has occurred in your application...." and press "Continue"
At this point I am at least in to the program, but no DB has loaded. I'm guessing the lack of Path's is a contributing factor, but if I select "Paths" I immediately get an error of "no such table: SCAN_DIRS". I click OK a few times and it just kicks me out of the PATHS section.
I guess the question that I should answer not asked, but soon to be asked is "Why do I not just start over again with my Popcorn Hour". The issue is that I am between 3000 and 4000 items on my server and it took a lot of updating to fix things up. I didn't rename all my folders each time a problem was found, I rather just used the PCH's feature and scanned for the right movie. I also found that all my previously stored artwork , in each movies folder, didn't display very well for fan.art. The resolution of my art was too high so it didn't get compressed right for the Jukebox.
So, I was hoping to fix my problem rather than start from scratch and spend many days updating again.
It would be nice if the Setting for the PCH C-300 just had a "Repair" option.
spinbot is offline
post #426 of 450 Old 09-10-2014, 07:09 AM
ChldsPlay's Avatar
Quoted: 772 Post(s)
Liked: 426
How does the C-300 work as far as Cinavia is concerned? Does it make it pretty useless for movies that have that protection?
ChldsPlay is online now
post #427 of 450 Old 09-10-2014, 07:15 AM
dbone1026's Avatar
Quoted: 233 Post(s)
Liked: 116
Cinavia does not apply to the C-300, so you can play any movie you want in any format
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is online now
post #428 of 450 Old 09-10-2014, 07:39 AM
ChldsPlay's Avatar
Quoted: 772 Post(s)
Liked: 426
So, I can just rip my Blu-rays to a HD (or to a PC attached to the same network), and then play them from the popcorn? Including 3D and HD audio? Is it possible to control with an android app?
Any other similar devices that are better?
post #429 of 450 Old 09-10-2014, 08:16 AM
dbone1026's Avatar
Quoted: 233 Post(s)
Liked: 116
The C-300 does not handle Blu Ray 3D. You would need either the PCH A400, Dune 3D series, or Mede8er. Android Apps are available for all players.
Cheers,
Damian
post #430 of 450 Old 02-06-2015, 03:50 PM
bdoyle13's Avatar
I have been a good supporter of Popcorn hour for a few years until now.
My Popcorn hour stopped communicating with my network. I tried tech support and it has taken months to try and resolve the issue since they can take days or a week to respond to support e-mails.
I didn't change anything on my network and it just started lagging like crazy and wouldn't play anything.
Turns out the network card and main board are fried after only two years of moderate use.
I need to return it to the manufacture for repairs at a cost of $65. plus I pay for initial shipping.
I've paid them and they cant even find the time to give me the damn shipping address.
When it works popcorn hour is great but buyer beware if you have a technical issue that Cloud Media needs to help you with.
Must love home theaters!!
bdoyle13 is offline
post #431 of 450 Old 02-06-2015, 10:14 PM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
You do know that PCH isn't based in CA, USA anymore right? They customer service was lousy then, and now that they are in China...I think it is even worse. I sold both of my PCH as ASAP!
GusGus748s is online now
post #432 of 450 Old 02-07-2015, 09:56 AM
bdoyle13's Avatar
Ya, I found out they moved but it was after I had purchased my unit. They still said I'd be shipping it to the U.S. but haven't given me an address. I'll never buy their product again if it's going to be this hard to use it and fix it. There's been issues since the beginning.
bdoyle13 is offline
post #433 of 450 Old 02-10-2015, 04:40 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
PCH and Dune both are worse than ever. I sold my PCH and Dune. I built a HTPC, which turned out to be much better for my family and I.
post #434 of 450 Old 02-10-2015, 04:51 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
My Popcorn A-400 is rock solid. HTPC so last century.
Gary J is offline
post #435 of 450 Old 02-10-2015, 04:56 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
That's good that it works for you. For my set up and large library of movies and TV shows, PCH didn't work.
I also like playing music and both Dune and PCH wasn't the best option for that. You cant beat a HTPC if you one a versatile system.
post #436 of 450 Old 02-10-2015, 05:10 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
There are plenty of PCH people with huge libraries and playing music, using apps, etc.
Gary J is offline
post #437 of 450 Old 02-10-2015, 06:01 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
That's awesome. All I know is not to buy or recommend anything from PCH. if it works for you that's great.
post #438 of 450 Old 02-10-2015, 06:09 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
All I know is PCH 400 threads are all but dead because there are all but no issues with them.
Gary J is offline
post #439 of 450 Old 02-10-2015, 06:28 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
PCH moderators pretty much remove any comments they deem detrimental to their products.
post #440 of 450 Old 02-10-2015, 06:48 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
I am talking about AVS forums. As for PCH forums I have not needed them for years. Pretty wild un-backed up claim anyway.
Gary J is offline
post #441 of 450 Old 03-12-2015, 08:24 PM
GregF's Avatar
I'm not posting to gloat, but to those who find this device endlessly frustrating as I did: I finally had enough and built a low cost HTPC and have no regrets whatever. I can play things I couldn't play before, and everything is much much faster, and zero crashes.
My sincere thanks to everyone who makes AVSforum such an awesome resource.
GregF is offline
post #442 of 450 Old 03-13-2015, 04:44 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
Same with PCH 400 except nothing to build/maintain.
Gary J is offline
post #443 of 450 Old 03-13-2015, 04:49 AM
tf4
tf4's Avatar
Quoted: 34 Post(s)
I am experiencing green artifacts on dark scenes on the Popcorn 410 (MKV Bluray). Anyone else have this issue? I also have issues playing larger FLAC files. I am not very thrilled at this point with this player.
tf4 is offline
post #444 of 450 Old 03-13-2015, 05:22 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
Nope such issues. User error.
Gary J is offline
post #445 of 450 Old 03-13-2015, 09:21 AM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
Usually anything green related is HDMI handshake. But since you are also having problems with flac files. Is this coming over a network or local?
post #446 of 450 Old 03-14-2015, 06:45 AM
UHD Addict
aaronwt's Avatar
Liked: 3951
I know I rarely post anything about my two A400s. They have worked great with my 2D and 3D BD ISOs and my MKVs. Streamed from my three unRAID setups.
aaronwt is offline
post #447 of 450 Old 05-13-2017, 01:48 PM
Liked: 0
About DTS HD-MA lossless.
I have connect via HDMI with a Yamaha RX-V 779. But I don't have any sound. Any solution to have sound on this audio type ?
Vasilis07 is offline
post #448 of 450 Old 05-13-2017, 03:10 PM
GregF's Avatar
Got a notice because I used to have one of these. Built an HTPC for about $700 and never looked back. A little more outlay, but something to consider if you're frustrated with these media tanks.
GregF is offline
post #449 of 450 Old 05-14-2017, 05:14 AM
Sledgehamma's Avatar
Quoted: 297 Post(s)
Liked: 154
What format is the movie in? Is it a BD folder or .iso?
The 300 series had some serious issues with that. Try switching the audio several times. This used to do it for me, but not always.
Sledgehamma is offline
post #450 of 450 Old 10-10-2017, 01:39 AM
Liked: 0
Online streaming with A-300
Hello,
Is there a way to play some movie through streaming, with a popcorn hour a-300?
I am looking for an app lie vstream in Kodi, or to stream via a web site like hds.to
thanks in advance!
zorglub81 is offline
Popcorn Hour A 300 Networked Media Jukebox , Popcorn Hour C 300 Extreme Networked Media Jukebox
