*Official* Popcorn Hour A-300 / C-300 Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 446 Old 02-09-2012, 03:21 PM
Wireless member
pepar's Avatar
Quoted: 912 Post(s)
Liked: 502
Originally Posted by sean_w_smith View Post
HTML and Flash.
NMJ != YAMJ They are totally different programs. pick one and use it.
YAMJ is far better
Yes, I got that from reading, especially the "poll." Very telling.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #62 of 446 Old 02-09-2012, 03:23 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Originally Posted by ashope View Post
Just finished making some overlays and mini mods for Eversion/evZap ..
Here's a quickie video of it in action:
http://www.youtube.com/watch?v=gcLrydNbCsI
And, the link to the thread over on NMT
http://www.networkedmediatank.com/sh....php?tid=58729
Did you have any issues getting the Zap skin working? I prefer the Zapp skin (I have the HTML one on my A200 and use Zappiti on my Dunes), but one person who mentioned it to me said it was a PITA to set up
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #63 of 446 Old 02-10-2012, 10:13 PM
ashope's Avatar
Quoted: 24 Post(s)
evZap! is very easy to setup and run ... all of the eversion "eskins" are much easier than the old html-based skins.
Take Care
Allen
Vizio M70C3, XBMC (Win8) running off a QNAP Synology.
ashope is offline
post #64 of 446 Old 02-11-2012, 09:36 AM
sean_w_smith's Avatar
cool will have to try some. I really like the stock skin as it gives you details without having to push down into each movie. Its really nice to get a summary without clicking to select the movie.
Hopefully some other skins retain this great feature.
Question: Can you automate the Popbox to boot into Eversion. With the C200 it would reboot back to the name network share see the index.html and auto load eversion so it "appeared" like eversion auto loaded.
is there any way to get this type of behavior or do I have to go apps then select yamj then select the quick start link. not exactly wife friendly.
I know the the 300 the same trick as the C200 should work but with the Popbox V8 there is no HTML skin support.
sean_w_smith is offline
post #65 of 446 Old 02-11-2012, 09:55 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
If you just put the popbox on Standby when you turn back on it loads right into the last screen you were on (so if you were still in Eversion that is what would appear when you turn back on). If you actually do a hard power down of the Popbox you will just be taken back to the main screen (same goes with the PCH)
Also, why would the trick work for the 300 series, it does not support HTML skins like the 200?
Cheers,
Damian
post #66 of 446 Old 02-12-2012, 09:36 AM
OK Did not realized they removed HTML Support of the A300 as well.
The C200 will return to the last used share on cold reboot so thats enables the auto re-start of eversion.
Thanks for the info.
post #67 of 446 Old 02-12-2012, 12:01 PM
halfelite's Avatar
Quoted: 423 Post(s)
Liked: 227
I posted a way how to make eversion autostart on boot on the nmt forums but only it works with NMT apps installed.
halfelite is offline
post #68 of 446 Old 02-12-2012, 12:05 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
NMT apps requires an internal or attached drive, correct?
Cheers,
Damian
post #69 of 446 Old 02-12-2012, 11:58 PM
halfelite's Avatar
Quoted: 423 Post(s)
Liked: 227
internal drive/attached drive or a usb stick.
post #70 of 446 Old 02-13-2012, 08:12 AM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 129
halfelite, can you please post the link to your instructions for eversion autostart on boot? I searched NMT forums, but couldn't find it. I assume this works with A-300, but not PopBox v8?
Also, is there a way to disable the 'YAMJ update available' popups that come up when you start eversion? I hit 'Ignore', but it's annoying to do everytime I launch eversion. Thanks.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #71 of 446 Old 02-13-2012, 08:16 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Some conversation here:
http://www.networkedmediatank.com/sh....php?tid=58575
Cheers,
Damian
post #72 of 446 Old 02-13-2012, 09:32 AM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 129
Thanks, no PopBox as NMT apps and CSI are needed. Now, for A-300, just need to figure out what the path to my WHS share should be in the code halfelite shared.
Brajesh is offline
post #73 of 446 Old 02-13-2012, 10:46 AM
halfelite's Avatar
Quoted: 423 Post(s)
Liked: 227
If its on a share you will need one more line of code to mount the share also. I will post it up in a bit. If I were You I would stick eversion locally just to get the hang of it then modify it for network shares.
Also to disable the update message its in esettings-default.xml in eversion eversion just make your own esettings.xml files and make the changes in it.
post #74 of 446 Old 02-13-2012, 11:00 AM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 129
Okay, thanks. Will look for your updated instructions on autostart for eversion on a share.
Brajesh is offline
post #75 of 446 Old 03-02-2012, 04:26 PM
Wireless member
pepar's Avatar
Quoted: 912 Post(s)
Liked: 502
Unboxed my A-300, my first networked media device, two days ago and hooked it to a mulitmedia monitor in my main computer room. After two days of reading, I downloaded and installed Hanewin NFS server on my Win 7 64-bit PC. Sharing a folder and getting the A-300 to see it was very easy. I copied an ISO into the shared folder and NMJ saw it and, after some key presses, it populated the folder with art and an NFO. OK, at that point I deleted the ISO and now have Clown running to output a BD folder structure. After this movie is ripped and I have verified everything is working as I expect it to (read: I have verified that I know what the hell I am doing), I will rip 2-3 more titles and see what NMJ ... or maybe YAMJ by then ... does with them.
Then it's on to my DVD-A and SACD titles. There is something called music daemon which is said to read DSF/DSDIFF files from a server, converts them on the fly to PCM and plays them on the A-300.
Jeff
pepar is online now
post #76 of 446 Old 03-03-2012, 05:10 AM
gagX's Avatar
Hi everybody,
I am about to by an A300. I just need to clarify something:
Did anyone have tried to read MKV file with A300 and can say if yes or no cinavia is embedded on the A300?
Thank you for your help;
gagX is offline
post #77 of 446 Old 03-03-2012, 05:23 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Originally Posted by gagX View Post
Hi everybody,
Cinavia does not apply to the A300 regardless of whether or not it is present in the file itself
Cheers,
Damian
post #78 of 446 Old 03-03-2012, 05:38 AM
gagX's Avatar
Thank you Damian,
This is good news. Since i'll be able to read all the files, I will buy this player and get rid off my PS3!
gagX is offline
post #79 of 446 Old 03-03-2012, 07:06 AM
Wireless member
pepar's Avatar
Quoted: 912 Post(s)
Liked: 502
Thank you Damian,
What is the model number and system software (firmware) of your PS3?
pepar is online now
post #80 of 446 Old 03-22-2012, 08:40 AM
bk
bk's Avatar
Does anyone know if the A-300 will display PGS subtitles from MKV wrapped BD rips?
TIA
bk is offline
post #81 of 446 Old 03-22-2012, 09:40 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
TIA
Yes
Cheers,
Damian
post #82 of 446 Old 03-22-2012, 09:54 AM
Wireless member
pepar's Avatar
Quoted: 912 Post(s)
Liked: 502
Hi Damian,
I have posted this over on NMT but have yet to receive any help. Maybe you know or can direct me to a dummies guide.
I have an NFS share - temporarily my share is on a RAID attached to my main PC until I get everything working and roll out a dedicated media server in the basement. I can access the share via "networked media" in NMJ and I can browse my movies in YAMJ/Eversion. While movies play via NMJ, they don't in YAMJ. They said I needed to "Add Share" which I have tried to do, but it asks for username/password when none were set. I have given it the Windows logon and that wasn't it. Plus, I am not sure about the shared folder name ... is there a / in front, two / and/or haw about :?
I am stuck on basics and it is frustrating.
Thanks in advance!
Jeff
pepar is online now
post #83 of 446 Old 03-22-2012, 10:00 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Originally Posted by pepar View Post
Hi Damian,
Thanks in advance!
Jeff
Sounds like your playerpath is incorrect possibly in YAMJ. FOr NFS it should be something like this:
nfs://MyServer:/Videos
Where MyServer = Your PC Name or IP Address
Where /Videos = shared videos path
What does your playerpath look like in your My_Library.xml file?
Cheers,
Damian
post #84 of 446 Old 03-22-2012, 10:19 AM
Brajesh's Avatar
Quoted: 301 Post(s)
Liked: 129
On mine, for NFS, I need the actual IP adress as opposed to the server name like "HPSERVER". SMB is easier, so you may want to try that first.
Brajesh is offline
post #85 of 446 Old 03-22-2012, 10:26 AM
Wireless member
pepar's Avatar
Quoted: 912 Post(s)
Liked: 502
I've got the IP address in and correct. Checking My_Library now ...
pepar is online now
post #86 of 446 Old 03-22-2012, 10:32 AM
Wireless member
pepar's Avatar
Quoted: 912 Post(s)
Liked: 502
I will fire up the system and look at my entries.
J:\\PCH
As I said I am able to access my movies via the browser, just haven't been able to "Add Share" and get to them via the share. accident tells me I am having a "300 series share problem." And once the 300 can use the share, they can get yamj to work with it also.
pepar is online now
post #87 of 446 Old 03-22-2012, 10:33 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
J:\\PCH
Seriously, that is your playerpath??? No wonder why it doesn't work, you have no path specified
Cheers,
Damian
post #88 of 446 Old 03-22-2012, 10:55 AM
Wireless member
pepar's Avatar
Quoted: 912 Post(s)
Liked: 502
That is what the "guide" said to enter ...
My movies are in one folder on the PC where YAMJ is installed.
Ya got me looking again on the NMT site ...
pepar is online now
post #89 of 446 Old 03-22-2012, 11:03 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
This is what my My_Library.xml file looks like:
Code:
    \\\\\\\\MyServer\\Videos\\Movies Family HD
    smb://MyServer/Videos/Movies Family HD/
    My Videos
    True
Cheers,
Damian
post #90 of 446 Old 03-22-2012, 11:54 AM
Wireless member
pepar's Avatar
Quoted: 912 Post(s)
Liked: 502
Here's where the ../ came from ... http://www.dentedboxes.com/doku.php/yamj:install:single
pepar is online now
Popcorn Hour A 300 Networked Media Jukebox , Popcorn Hour C 300 Extreme Networked Media Jukebox
