*Official* Popcorn Hour A-300 / C-300 Thread - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 449 Old 04-20-2012, 04:53 AM
dbone1026's Avatar
Quoted: 221 Post(s)
Liked: 111
Originally Posted by WynsWrld98 View Post
I have an A-300 with latest firmware, played my first ISO on it (Fast Five BluRay), played fine until about half way through and froze up completely so I can't agree with the comment above AT ALL. You also see a slight pause as it goes from one segment of ISO to next (Fast Five has multiple m2ts files is why I made an ISO of it vs. just playing a single m2ts on A-300 if Fast Five had been done that way).
Correct, I noted that when I reviewed the A-300 as well, it has some issues with seamless branch blu rays (i.e. multiple m2ts). You see a skip/pause/jump when moving from one m2ts to another. The easiest way around this is to make a main movie Blu-ray rip with Clown_BD. The seamless branch issue affects many players (I think/wonder if it is BD Lite related?)
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #152 of 449 Old 04-21-2012, 10:52 AM
WynsWrld98's Avatar
Quoted: 294 Post(s)
Liked: 113
Originally Posted by Gary J View Post
How did you determine the problem is the player not the file?
File plays fine on my PC. Popcorn Hour freezes up at random times in general for me and I always keep firmware updated. You gotta love the only way to fix it is unplug it (how ridiculous), the power button does nothing to fix the freezeups.
WynsWrld98 is offline
post #153 of 449 Old 04-21-2012, 10:58 AM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
There still might be something else going on. Put "freeze" in Search this Thread and yours is the only one.
Gary J is online now
post #154 of 449 Old 04-21-2012, 01:02 PM
cHarOn99's Avatar
i would say that you have network issues, maybe try it with 10/100 setting, or put a 10/100 switch between your Popcorn and your gigabit switch
cHarOn99 is offline
post #155 of 449 Old 04-22-2012, 10:54 AM
WynsWrld98's Avatar
Quoted: 294 Post(s)
Liked: 113
File is on hard drive in Popcorn hour, no networking involved.
Nomad174 likes this.
post #156 of 449 Old 04-28-2012, 08:49 AM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
Hi, sorry, but I couldn't find an A-210 thread when I searched and I'll assume there's a lot of posters here that either have or had one. I have an unusual situation that cropped up I can't figure out how to fix.
When I go to use the MNJ menu it just appears at about 1/3 the size on the upper left corner on the screen. I have no idea how to get it to full screen.
Current Gear: Anthem AVM60, D-Sonic 3500/7, Oppo UDP-203, PS Audio Nuwave Phono Pre, Technics SL1210 w/ Denon DL103, Dune Duo 4K, LG Oled55e6, Paradigm Sig. S6 & C3 v.3's, Monitor ADP's, Velodyne SPLR1200.
rnrgagne is offline
post #157 of 449 Old 04-28-2012, 09:37 AM
Wireless member
pepar's Avatar
Quoted: 1043 Post(s)
Liked: 544
What is the resolution of your display and the output resolution of PCH? Is content scrunched into the corner as well?
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #158 of 449 Old 04-28-2012, 06:01 PM
halfelite's Avatar
Quoted: 451 Post(s)
Liked: 237
take the resolution off of auto in the setup. It needs to be at least 720p+ for NMJ to work. when its on auto it picks it up as the wrong size and you get the little window
halfelite is offline
post #159 of 449 Old 04-28-2012, 07:27 PM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
Thanks guys, the output resolution is set to 1080p/60, framerate sync to NTSC/24p & TV to 16:9. (I have a 24fps capable PJ.)
Everything except the NMJ wall displays properly.
rnrgagne is offline
post #160 of 449 Old 04-28-2012, 07:51 PM
halfelite's Avatar
Quoted: 451 Post(s)
Liked: 237
was it set on auto the first time you loaded NMJ. I have herd of it getting stuck. set the resolution to 720p/60 hit save launch NMJ see if it goes normal then go back to 1080p/60 if not a firmware flash or factory reset might be in order
post #161 of 449 Old 04-29-2012, 05:58 AM
Wireless member
pepar's Avatar
Liked: 544
+1 ... that can cure a lot of ills.
pepar is offline
post #162 of 449 Old 04-29-2012, 11:01 AM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
Thanks, that did the trick!
Since you're in the know, I might as well ask about the only other issue;
I've been getting sporadic audio dropouts streaming Blu Ray ISO's with the hi-rez codecs, the video streams fine. I don't recall this being an issue with the A-210, if it isn't, is there something else that could be a weak link in my set-up causing it?
Everything is hard wired running a ReadyNAS NV+ to a Telus Actiontec V1000H then about a 50' cat 5e to a D-Link DGS 1008D switch that the A-210, pre-amp, BD player, and cable box are all connected to. All cables are either cat5e or cat6.
rnrgagne is offline
post #163 of 449 Old 04-29-2012, 11:58 AM
dbone1026's Avatar
Quoted: 221 Post(s)
Liked: 111
Some audio tracks are experiencing audio dropouts, it isnt your network
Cheers,
Damian
post #164 of 449 Old 04-29-2012, 01:50 PM
halfelite's Avatar
Quoted: 451 Post(s)
Liked: 237
Yes there is some audio dropout issues when using iso/bdmv sigma supposedly fixed the issue and pch was testing the fix to make sure nothing else broke by it. But if they are files with true-hd inside them they seem to be most affected by network issues, if you have not already do the rwin value tweak located here http://www.networkedmediatank.com/sh...highlight=rwin
and also make sure you are not running jumbo frames.
post #165 of 449 Old 04-30-2012, 08:04 AM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
Thanks again guys. Good to know there's a fix in the works, audio drop-outs, especially on concert vids, are just not acceptable.
rnrgagne is offline
post #166 of 449 Old 05-11-2012, 07:32 AM
diamond design's Avatar
There will be some good news announced early next week regarding PCH and Popbox.
diamond design is offline
post #167 of 449 Old 05-11-2012, 07:33 AM
cHarOn99's Avatar
what kind off?
cHarOn99 is offline
post #168 of 449 Old 05-11-2012, 08:11 AM
UHD Addict
aaronwt's Avatar
Quoted: 5961 Post(s)
Liked: 3666
I guess we need to wait until next week to find out.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #169 of 449 Old 05-11-2012, 08:12 AM
dbone1026's Avatar
Quoted: 221 Post(s)
Liked: 111
I am guessing either Diamond will be a reseller and/or new online content is coming to the PCH/Popbox Vudu, maybe Netflix, etc...)
Cheers,
Damian
post #170 of 449 Old 05-11-2012, 08:13 AM
Brajesh's Avatar
Quoted: 303 Post(s)
Liked: 130
Maybe a new player? XBMC integrated, new chip? Hey, as I posted in the PopBox thread, I can dream .
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #171 of 449 Old 05-11-2012, 08:16 AM
dbone1026's Avatar
Quoted: 221 Post(s)
Liked: 111
I doubt a new chip since the 8646 just came out for the 300 series. I believe Vudu was/is very close to being released, and Netflix talk had heated up as well (but then again I heard this at the end of last year from my source)
Cheers,
Damian
post #172 of 449 Old 05-11-2012, 08:20 AM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 221
Probably firmware update.
post #173 of 449 Old 05-11-2012, 09:30 AM
cHarOn99's Avatar
i think more that diamond is going to sell them, anything else doesn't make sense since he is a dune reseller
cHarOn99 is offline
post #174 of 449 Old 05-11-2012, 09:50 AM
djc11369's Avatar
Quoted: 273 Post(s)
Liked: 156
You mean they don't already sell them? They show the players on their website. Or was this an oops?
http://www.diamondhomedesign.com/dune.html
djc11369 is offline
post #175 of 449 Old 05-11-2012, 09:53 AM
cHarOn99's Avatar
huh did they change the site now?!
i was there http://www.diamondhomedesign.com/store/Default.aspx
and there i don't see any popcornhour or popbox device
cHarOn99 is offline
post #176 of 449 Old 05-11-2012, 09:56 AM
djc11369's Avatar
Quoted: 273 Post(s)
Liked: 156
Try again, not sure what happened the first time.
djc11369 is offline
post #177 of 449 Old 05-11-2012, 10:00 AM
dbone1026's Avatar
Quoted: 221 Post(s)
Liked: 111
That is definitely new
Cheers,
Damian
post #178 of 449 Old 05-11-2012, 10:06 AM
cHarOn99's Avatar
yes definitely because if i click now on popbox v8 or c300 it will go into the shop and shows a error, so someone changed the site but it is not finished
cHarOn99 is offline
post #179 of 449 Old 05-11-2012, 11:55 AM
LVS
LVS's Avatar
does this mean they will also have a Control4 integrated IP driver?
LVS is offline
post #180 of 449 Old 05-11-2012, 12:04 PM
cHarOn99's Avatar
ahhh that could be maybe the news, would make sense if you look at the resellers page
cHarOn99 is offline
Popcorn Hour A 300 Networked Media Jukebox , Popcorn Hour C 300 Extreme Networked Media Jukebox
