Please post any reviews, comments, experiences, comparisons with other media player about this player.
IT APPEARS SUPPORT FOR THIS MEDIA PLAYER HAS BEEN DISCONTINUED.
It appears support for this product is only via email.
Micca only has a 30 day return / exchange policy with 1 year limited warranty. If you get a defective unit, the buyer will have to open an RMA and pay for shipping. It will be up to Micca to either repair or replace the unit.
Can anyone help with setting up the EP950 with Windows 7? I've started the Samba process on the EP950 settings and enabled media sharing on W7. Should I be able to see the EP950 from "view network computers and devices" or do I need install a Samba client on W7? Or, enter "\\\\EP950\\" from Start -> Run?
There are extra files/steps needed to flash the boot code, so as long as you are just flashing the firmware itself, the boot code will be intact. So there is nothing to worry about for most people.
Once you turn on SAMBA file sharing and have a drive installed/attached to the EP950, it should show up on your network. In Windows 7, it should show up when you click on Network in file manager.
is there any difference between the guts of the 350,600 and 950 other than gigabit lan speeds? Not interested in the hard drive option as all my blu ray rips are on a nas.
Before cross flashing with another Realtek 1186 vendor's firmware, it would be a good idea to make sure you already have the .img file for the exact replacement firmware that matches your player. This would allow a "safe mode recovery" if that is ever needed. The safe mode replaces the boot code that Jack@Micca mentioned.
Here's a link to helpful info I collected for the Realtek 1186 box firmware.
Especially see the section titled, "important Consideration."
if I connect an external hard drive (WD MyPassport) using one of the usb ports in the EP950, I can successfully play all my media files? or I necessarily need a sata external drive?
The EP950 is current out of stock on Amazon but should be available again within the next week or so. They are on American soil.
Both the EP350 and EP600 uses the 1185 chip while the EP950 uses 1186. All of which will support external hard drives attached via USB. The EP600 and EP950 has an external SATA connector, and the EP950 further has an internal SATA bay. It's not necessary to install a hard drive in the EP950 to use it.
1. When I merge two 1080p AVCHD .MTS files together into a MKV file by using mkvtoolnix tool, the merged video plays but not smooth anymore - for every few second, it jumps 1 second. The original 1080p MTS file plays smoothly.
2. The player popped up error message saying audio is too slow and not recoverable when I play 720p MKV files with AC3 audio stream.
3. The home screen splashes during reboot or return from previous screen.
4. The last is I was hoping the box can play Panasonic MOD files as I have lots of videos from my old Panasonic camcorder. The .MOD file format is similar to .MPG file format as if you change the file extension from .MOD to .MPG, it plays fine. But why not directly adding support? Just a suggestion.
Thanks for your response, Jack. I can actually access the EP950 by way of "\\\\ip-address", but I cannot see it from my Windows 7 Explorer's Network view, as you described. Any thoughts?
Anyhow, I am getting Samba transfer rate (write) of around 11 MB/sec from my PC. I've got a Cisco E3000 (Gigabit) running between my PC and EP950. Is it possible to achieve a faster speed?
Jack, has anyone ever reported stuttering while playing MKVs off the hard drive? That is what I have experienced with my player when I installed an 1Tb Hitachi drive in it. The playback stuttered to the point the movie was totally unwatchable... When played from the network that same file has been played more or less fine...
That's strange, it sounds as if the player's host name isn't being broadcasted by the DHCP server. Does the EP950 list out the other devices on your network when you go to browse the network connections?
The transfer speed sounds about right. This is a few MB/s faster than players with a 100mbps link. The gigabit connection does make transfers faster, but it will not be as fast as a computer. I would compare this to the USB port on certain WiFi routers that let you attach and share a disk out. Those devices also are limited to transfers in the 10-15MB/s range.
Can you provide a MediaInfo output of the MKV that exhibits this issue? Is it all files or just specific ones? Also, try connecting the HDD to the external SATA port to see if the behavior changes.
I believe in both cases the director's commentary is a completely different video file with a matching audio track. There is no way to exit this file to a menu. The .iso files in question play with menus from a server to a different media player, but I am playing them in the ep950 through an internal sata hdd, if that makes a difference.
(sorry I cant post the url yet...but it's on Micca's website...)
Some improvements...HiTV is it's own catagory but still offline.
LL&P
John
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
