Recommended hub/switch to be connected to Netgear WNDR4500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-06-2012, 08:48 AM - Thread Starter
nyguy4u's Avatar
Hey guys,
I am looking to network my entire system together, and I think I need some advice
In my office, I have a Netgear WNDR4500 Router. It needs to stay in my office, because I have a 4TB G-Drive connected to it for file sharing, and a printer connected to it for print sharing.
As for my HT set-up, I have a Pioneer VSX-1021 Receiver, D*TV Box, Apple TV, and PS3. That is 4 things I need to wire up. I already ran a single Cat5 from my WNDR4500, to the back of my HT setup. But now I am at a standstill. What type of hub (is that even what it's considered??) do I use that will work best with my WNDR4500. Obviously I don't want to lose any speed. And I want everything to work when I use my iPad for the remote for my VSX-1021.
Can someone recommend a good unit to get?
nyguy4u is offline
post #2 of 10 Old 01-06-2012, 09:10 AM
Swampfox's Avatar
You need a switch. Figure out how many ports you need, and then look at the usual suspects (cisco, linksys, netgear). Gigabit switches are a commodity. You don't need any fancy enterprise level network capability.
You probably should find one that's fan-less, quite, and energy efficient.
Mine is in a sealed equipment room, and is an older netgear 24 port gigabit switch. It works fine but is noisy,but because it's in a sound isolated space the noise doesn't matter.
http://www.newegg.com/Store/Category...red-Networking
Swampfox is offline
post #3 of 10 Old 01-06-2012, 09:14 AM - Thread Starter
nyguy4u's Avatar
Thanks for the reply.
I just don't want to lose any speed with a crappy switch connected to a great router that I have.
I'll check out that link. Thanks again.
nyguy4u is offline
post #4 of 10 Old 01-06-2012, 09:20 AM - Thread Starter
nyguy4u's Avatar
So something like this would tie in to the WNDR4500 nicely?
http://www.newegg.com/Product/Produc...82E16833122111
nyguy4u is offline
post #5 of 10 Old 01-06-2012, 09:49 AM - Thread Starter
nyguy4u's Avatar
oh, everything is going to be wired up via Cat6 too..
nyguy4u is offline
post #6 of 10 Old 01-06-2012, 10:09 AM
GordonB's Avatar
Any decent consumer grade switch should do fine. I use this D-Link with my WNDR-4000 router. No problems at all.
GordonB is offline
post #7 of 10 Old 01-06-2012, 10:14 AM
Swampfox's Avatar
I had the previous version of that switch until I out grew it. It worked fine for years. I don't see why it wouldn't work.
Swampfox is offline
post #8 of 10 Old 01-06-2012, 10:59 AM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 108
I use this one in my bedroom. Works fine. None of the 4 components you mention will come close to overloading it. ...and I'm sure your awsome router won't get mad at you for plugging the two together.
http://www.newegg.com/Product/Produc...82E16833156250
-Suntan
Suntan is online now
post #9 of 10 Old 01-06-2012, 11:04 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
-Suntan
I've got the same switch as Suntan in my bedroom as well. It works perfectly. I've got it hooked up to a wndr3700. I got it on saleve for $18.00 bucks shipped from amazon I believe.
GusGus748s is offline
post #10 of 10 Old 01-06-2012, 11:31 AM - Thread Starter
nyguy4u's Avatar
Excellent. Thank you guys!
nyguy4u is offline
