Pivos AIOS HD Media Center: The *Semiofficial* Thread - Page 18 - AVS Forum | Home Theater Discussions And Reviews
post #511 of 1134 Old 05-11-2012, 08:00 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Originally Posted by aasoror View Post
Use the cover mode (press one of the coloured buttons on the remote ... green ?) and it will pickup and display folder.jpg within each folder and it will be considerably larger.
That's what I used to use. Press the blue button and it will come up. The only problem with this the movies won't be in alphabetical order. So, I stopped using it that due to that reason.
GusGus748s is offline
post #512 of 1134 Old 05-14-2012, 08:33 AM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
Guys, I am compiling a list of messed up BR titles due to the Java incompatibilities and the tendency of the player to pickup the longest track (when menus isn't supported), hopefully Pivos would "attempt" to resolve it with Realtek.
If you any titles that exhibited such behavior, please name them.
TIA.
They "supposedly" working on that.
aasoror is offline
post #513 of 1134 Old 05-14-2012, 08:37 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
TIA.
Wondering when that's going to finally get fixed though!
post #514 of 1134 Old 05-21-2012, 08:43 PM
bigspud's Avatar
transfered 1080 .mov (AVC1) files from canon elph 300 to pivos with 320gb hdd,. playback is very choppy. not enough cpu in pivos? any settings to tweak, or should i return it? have latest update installed.
bigspud is offline
post #515 of 1134 Old 05-21-2012, 08:59 PM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
well, it depends on the encode settings, pass the file through mediainfo and post the output here.
aasoror is offline
post #516 of 1134 Old 05-21-2012, 09:33 PM
bigspud's Avatar
General
Complete name MVI_0562.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 1.11 GiB
Duration : 4mn 33s
Overall bit rate : 34.9 Mbps
Encoded date : UTC 2011-08-09 18:00:33
Tagged date : UTC 2011-08-09 18:00:33
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=12
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 4mn 33s
Bit rate : 33.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.671
Stream size : 1.06 GiB (96%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 4mn 33s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 50.2 MiB (4%)
Language : English
bigspud is offline
post #517 of 1134 Old 05-21-2012, 09:40 PM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
General
Format : MPEG-4
Codec ID : qt
Duration : 4mn 33s
bit rate is too high for the mov container (on the AIOS).
At this bitrate I would stick with M2TS (or set your camera to lower bitrate if you can't change container)
aasoror is offline
post #518 of 1134 Old 05-21-2012, 09:50 PM
bigspud's Avatar
seems pivos not up to spec for use with 2 year old point and shoot camera, will look for better media player.
bigspud is offline
post #519 of 1134 Old 05-21-2012, 09:57 PM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
Its not specs related (45mbps AVC streams runs butter smooth on the AIOS in M2TS containers, which is the bluray container and the default for more recent camcorders out there), mov is one of the most resource consuming containers out there, its not that surprising its being "phased out" as a recording formate for many camcorders out there.
There is a reason these boxes are being sold for less than $100, its optimized for the more popular demands.
aasoror is offline
post #520 of 1134 Old 05-22-2012, 12:23 PM
whipdancer's Avatar
I would say pivos has moved beyond that outdated spec.
whipdancer is offline
post #521 of 1134 Old 05-22-2012, 01:49 PM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
not at all 1185 isn't outdated in any way (its still challenging to find a chip that would cost less and offer more), it services well for Pivos (and other providers) as cheap entry level boxes.
Speaking of moving forward, Pivos has created a landing page for the XIOS DS.
http://www.pivosgroup.com/#!vstc3=products/vstc0=xios
aasoror is offline
post #522 of 1134 Old 05-22-2012, 01:54 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
Nice looking unit. Hope if comes in black because it would look weird among my black ht equipment.
Hopefully, bitstreaming of HD audio will not be a problem.
audit13 is offline
post #523 of 1134 Old 05-22-2012, 02:02 PM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Has anyone tried installing Mede8er's 500X2/450X2 firmware on the AIOS? Curious if it would work.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #524 of 1134 Old 05-22-2012, 02:03 PM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
No black (yet).
I will be able to confirm bitstreaming shortly as finally upgraded my receiver.
aasoror is offline
post #525 of 1134 Old 05-22-2012, 02:04 PM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
Nope, wont install.
The whole firmware is AES encoded so one can't even go on and try unlocking it.
aasoror is offline
post #526 of 1134 Old 05-22-2012, 02:08 PM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Figured that, but thought I'd ask. Thanks.
Brajesh is offline
post #527 of 1134 Old 05-22-2012, 05:37 PM
bigspud's Avatar
i see, mov container is no good.
found canon camera hack on utube, to reduce 1080 bitrate.
bigspud is offline
post #528 of 1134 Old 05-22-2012, 06:12 PM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
Good to know, keep us updated about your results.
aasoror is offline
post #529 of 1134 Old 05-23-2012, 07:38 AM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Also try MKV container. I've had success with my 1080p/60 camcorder clips playing back fine after demuxing, then remuxing via MKVMerge as MKV's.
Brajesh is offline
post #530 of 1134 Old 05-23-2012, 10:52 AM
bigspud's Avatar
i just want to transfer movies and pics from camera to pivos, then watch them. re-encoding them is not an option.
bigspud is offline
post #531 of 1134 Old 05-23-2012, 11:06 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
No black (yet).
Cool. Keep us informed.
audit13 is offline
post #532 of 1134 Old 05-23-2012, 11:50 AM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
Not suggesting you re-encode, simply that you might want to try MKV for the container. It works better for me for 1080p/60 camcorder files that otherwise don't play in some streamers.
Brajesh is offline
post #533 of 1134 Old 05-23-2012, 02:14 PM
bigspud's Avatar
so how do i get the .MOV video into a mkv container without using a computer?
bigspud is offline
post #534 of 1134 Old 05-24-2012, 07:57 PM
jsmiddleton4's Avatar
Quoted: 589 Post(s)
Liked: 199
Moved from an Argosy 335T to the Pivos AIOS. Liking it so far. Way more flexible. The Argosy is a good unit, rock solid, just not up to date on interface and flexibility. The Linux kernel enables lots of possibilities.
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is online now
post #535 of 1134 Old 05-25-2012, 06:14 PM
GeorgeM's Avatar
Originally Posted by JLBENEDICT View Post
So far, so good after a week of owning my AIOS.
Setting up the jukebox / moviesheets wasn't too difficult and looks really good.
I just installed R-19. How did you set up Jukebox for movies. My movies are on a PC.
George M
JVC RS500, Panasonic UB900, HD Fury Integral, HD Fury Linker, Denon x7200w,
126x52 Screen made with AVS V6 Material, 7.4.2 Atmos speaker setup.
GeorgeM is offline
post #536 of 1134 Old 05-25-2012, 09:39 PM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
Check here for a how too (little involved though)
http://www.pivosforums.com/viewtopic.php?f=10&t=299
aasoror is offline
post #537 of 1134 Old 05-30-2012, 02:44 PM
blunt_eastwood's Avatar
This is on sale today at newegg for $66 ($94-$9 discount-$20 MIR + FS).
Do you guys think it's worth it at that price?
The $9 discount expires today 5/30.
blunt_eastwood is offline
post #538 of 1134 Old 05-31-2012, 01:25 PM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
I hope you jumped on it, I think the lowest price to date was $60
aasoror is offline
post #539 of 1134 Old 06-07-2012, 06:20 PM - Thread Starter
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
The remote has been updated (shipping for some time already),
Glow in the dark buttons, and WAY BETTER button placement.
Pivos will start an replacement initiative soon where customers only pay for shipping and handling to replace their "non-defective" old remotes (only one free replacement per box is allowed though).
aasoror is offline
post #540 of 1134 Old 06-07-2012, 07:39 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
aasoror, will Pivos contact us, or do we have to request the remote?
thanks
vega509 is offline
