Official unRAID Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
Old 03-13-2012, 05:32 PM
mbryanr's Avatar
Problem is most every case requires bending of the tabs to fit 5x3 cages now.
mbryanr is offline
Old 03-13-2012, 05:51 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
This depends on what case you are using. There are a lot of cases out there that do not have the tabs.
GusGus748s is offline
Old 03-13-2012, 06:05 PM - Thread Starter
Chrisx510's Avatar
Are you guys referring to the tabs that are meant to hold single drives or optical drives in place?
My First Home Theater
300 Blu-Rays, 150 DVD's loaded in my Movie Server!
Thanks AVS for making me addicted to this hobby!
Chrisx510 is offline
Old 03-13-2012, 06:07 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Yes.
Old 03-13-2012, 06:24 PM - Thread Starter
Chrisx510's Avatar
Originally Posted by GusGus748s View Post
Yes.
My case didn't have that problem. The metal tabs came in a bag so you could install them if needed. Just another reason why i recommend my case for an unRAID Tower Build.
Old 03-13-2012, 06:26 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
What tower was that? I did mine with a recommend tower from the wiki unraid build.
Old 03-13-2012, 06:28 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Never mind found it on your first post. I was going to buy the same tower, but they wanted a little over $100 bucks at the time, and the Azza only cost me $77 with 2 day shipping.
I don't think my wife would be too happy about buying another case
Old 03-13-2012, 07:02 PM - Thread Starter
Chrisx510's Avatar
When did you buy your case? Didn't you start your build around the same time as me? It was only $49 on NewEgg. I think right now its $60.
Old 03-13-2012, 07:11 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Around the same time. I don't think I looked at that particular case, but it was another one by the same company.
Well, now I am stuck with this case. So, I've got to make it work. I don't have a problem with the case per say. I've got a problem with the Icy Dock running hotter than I wan it to run whenever I do the parity checks. It doesn't run as hot whenever I am streaming movies. So, that's alright.
Old 03-13-2012, 07:26 PM
hhwfbkle3's Avatar
I see. So you can run UNRAID without training wheels at first. I assume I could start with just a single drive and move to add a parity drive at a later date for that data protection?
hhwfbkle3 is offline
Old 03-13-2012, 07:51 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Yes you can do that. Your pictures are not coming up by the way.
Old 03-13-2012, 07:53 PM - Thread Starter
Chrisx510's Avatar
Yes, you can add a Parity whenever you want. If you want to try unRAID go with the basic for FREE and then when you're ready to upgrade buy a License.
Old 03-15-2012, 04:21 AM - Thread Starter
Chrisx510's Avatar
So today I was disconnecting my HP MediaSmart Server so I decided to organize all the cables at the computer desk. I powered down all the comps and the server. Connected everything back up and now I can't get unRAID "Tower" to show up on the network. I can access it just find threw the web gui and if I directly type \\\ ower\\movies but it just doesn't show up under Network anymore.
Does anyone know why all of a sudden it's not showing up?
I guess I can just create a shortcut icon on my desktop to "Tower" and access it that way.
Old 03-15-2012, 06:53 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Mine did the same thing a while ago. I dont know why, but i turned off my router for 30 seconds and turned it back on. Thereafter, tower was available under "NETWORK."
Old 03-15-2012, 06:03 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Well, now I am trying to decide if I should buy a Norco SS-500 or go for something cheaper and buy:
Norco:
http://www.amazon.com/NORCO-SS-500-S...sr=1-1-catcorr
or cheaper route
http://www.amazon.com/Cooler-Master-...1856132&sr=1-1
or
http://www.amazon.com/Sans-Digital-H...1856132&sr=1-3
Old 03-15-2012, 06:45 PM
jeff.lebowski's Avatar
Norco:
or cheaper route
I have one of these in my case and I like it. The fan is plenty quiet, but my server is in a walk-in closet, far away from anyone who would care.
jeff.lebowski is offline
Old 03-15-2012, 07:07 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
One of which, Norco or Cooler Master?
Old 03-15-2012, 08:49 PM
Oops. I meant to post something else that compared the two, then got distracted by something shiny...
The CM is what I was referring to.
Old 03-15-2012, 09:52 PM - Thread Starter
Chrisx510's Avatar
I would just buy 1 Norco for now then add 2 more as you go.
Old 03-15-2012, 10:41 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
I was going to buy a norco, but I ended up buying the Cooler Master 3x4 hdd cage for $28.00 dollars instead. I need to save $$ to buy more hard drives instead.
Old 03-20-2012, 09:50 AM - Thread Starter
Chrisx510's Avatar
When having a Cache drive do you have to transfer the movie files to the Cache folder to make use of it? If I transfer the movie to my movie share folder will unRAID automatically use the Cache drive?
Old 03-20-2012, 10:27 AM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 246
On the unraid share page, you can mark whether a share uses the cache drive or not. If you enable the cache drive for a share, when you transfer a file to that share, it will write to the cache drive and then be transferred a normal disk at the scheduled time.
So yes. If your movie share has cache drive use enabled, it will automatically transfer to the cache drive.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
Old 03-20-2012, 10:51 AM - Thread Starter
Chrisx510's Avatar
Ok I checked it Yes.
Old 03-20-2012, 11:19 AM
Quoted: 146 Post(s)
Liked: 246
It will put it in whatever folder you specify when you save to the share.
Old 03-20-2012, 11:24 AM
UHD Addict
aaronwt's Avatar
Quoted: 5203 Post(s)
Liked: 3111
I have mine setup to use the cache drive for everything. Using the cache drive is transparent. I just select the share and folder where I want to put my content. It is automatically transferred to the cache drive under the folder I selected. Then I have my unRAID set to move the contents of the cache drive to the array at 12AM, 8AM, and 4PM. Or I can manually initiate the move since I don't normally run my unRAID 24/7.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
Old 03-20-2012, 11:36 AM
Quoted: 146 Post(s)
Liked: 246
Yeah. If you've got it, you might as well use it for all shares. Mine only transfers once a day though at 4AM.
After reading this thread, I downloaded teracopy and it made a nice difference in my copy speeds. Transferring from my pc to my unraid and using a cache drive, I'm now averaging close to 70MB/s. It seems much less dependent on my PC's overhead than the explorer utility.
Old 03-20-2012, 11:45 AM - Thread Starter
Chrisx510's Avatar
I've had mixed speed results with Teracopy. I've got up to 86MB/s but also have gotten much less. Sometimes just drag and dropping the file into a share is faster than Teracopy for me.
Today I tried ripping a 35GB Blu-Ray directly into unRAID. Cache drive wasn't enabled at the time. Took around 50-55 minutes to rip over the network while writing parity. A lot faster than I expected.
I will try to rip over the network and see how much faster it is with a Cache enabled.
Once I fill up the remaining 7TB of free space in my server I will then probably assign the Cache drive as a data drive.
Old 03-20-2012, 12:10 PM
mbryanr's Avatar
When you have to change drives you'll wish for hot swap.
These are what I ended up purchasing...
http://www.istarusa.com/istarusa/pro...el=BPN-DE340SS
mbryanr is offline
Old 03-20-2012, 02:05 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
I've got 5 drives right now. Once I get like 10 drives I'll get a Norco SS500V2 since they seem to have the best airflow.
Old 03-21-2012, 06:23 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Well, yesterday was a pretty interesting day. I switch from having comcast cable internet for $73.00 dollars a month because my promotion expired. So, after making several phone calls, I ended up getting U-Verse, which included TV, with 2 DVR's and 18 mgps downloads speed for $82.00 a month.
However, I had to turn my whole network off since I had to re-route and take off several cable that were not needed anymore.
After a 3 hours installation....I ended up getting a new guy. The TV and internet worked. For a few hours lol. The internet works, and the living room TV works, but the master bedroom doesn't.
Furthermore, the Cat5e cable that goes from my router to the master bedroom doesn't have a signal anymore, which is probably why the TV doesn't work. I am thinking the installation guy(s) messed up the cable while installing the screws to hold the cables in place.
However, that was the least of my problems. After installing everything and turning everything on...I WAS UNABLE TO ACCESS MY UNRAID SERVER
After hours of changing and terminating Cat5e cables, and power cycling everything, I was still unable to access it. I posted this on Lime Tech Forum, and someone suggested to turn on DHCP on my OS USB Thumb drive.
Then, it clicked. I have two routers now. The U-Verse and my WNDR3700, which I am using mainly for the wireless N connection.
So, I went ahead and turned on the DHCP on my thumb drive, and magic. It is working again.
The best part: MY TRANSFER SPEEDS ARE FASTER LOL. I don't know why, but before I was averaging between 15 to 30 mbps, and now I am hitting 25 to 38 mbps.
So, yeah, today there will be another tech coming. He'll probably have to run two lines of Cat5e to the master bedroom. One for the TV box, and the other for my 5 port gigabit switch to access my server.
The first ATT tech who came over, gave me a power line internet adapter, which works ok for my xbox and streaming online content, but it stutters whenever I try streaming blu-ray rips.
So, we'll see how it goes tomorrow.
Popcorn Hour C 200 Networked Media Tank Black , The Boxee Box By D Link Hd Streaming Media Player
