Official unRAID Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #721 of 799 Old 02-13-2014, 07:35 PM
UHD Addict
aaronwt's Avatar
Quoted: 5195 Post(s)
Liked: 3103
Originally Posted by kweisen View Post
I have my unraid server tucked away in a storage room and had to have my router switched out with a new one. This changed all the IP addresses and now I dont know what the IP address is anymore and cant access the tower/main frown.gif Is there anyway I can figure out what the ip address is so I can access the tower/main page? I can access it through my shared network devices still on my windows HTPC but just cant type the IP address in my browser because I dont know it. Any suggestions so I dont have to lug it out and plug it into a tv (no monitors)? Thanks guys
Just look at the IP addresses listed in your router and you should see the unRAID server IP address there. This is how it works on mine.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #722 of 799 Old 02-13-2014, 07:37 PM
kweisen's Avatar
Im an idiot! Thanks will go do it right now you're awesome!
kweisen is offline
post #723 of 799 Old 02-14-2014, 04:15 AM
ilpostini2's Avatar
Quoted: 41 Post(s)
I'm new to this server world and need some help.
I have an unraid box and an HP Microserver that's running Synology. The synology was jbod and it crashed, I have all my files on the unraid server.
What's the fastest way to get these files to my Synology build over LAN?
ilpostini2 is offline
post #724 of 799 Old 02-28-2014, 09:01 PM
kweisen's Avatar
Originally Posted by jeff.lebowski View Post
Not exactly. Power down the unRAID server anyway you can (likely just a hold of the power button), then remove the USB drive from wherever it's plugged into your server, then plug that USB drive into your computer and read the contents as you would any other USB drive.
So i turned off the server and unplugged the usb and then plugged it into my windows machine retrieved the IP address and then plugged the usb drive back into the unraid server and powered it back on. However now im freaking out because I cant connect to the IP/main through a web browser and when I go to my Networked devices where I could connect to it before and watch my media all that appears now is my tower but it simply displays everything on my USB drive like the config, packages, preclear_reports, and unmenu its as if the server isint running fully.... I just pray I didnt loose any media
kweisen is offline
post #725 of 799 Old 03-01-2014, 02:06 AM
jeff.lebowski's Avatar
Start small.
Click the Windows logo, type CMD, press enter.
Type ping THE.SERVER'S.IP.ADDDRESS, press enter.
It should look like this if the IP and network are functioning correctly:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\jeff.lebowski>ping 192.168.3.175
Pinging 192.168.3.175 with 32 bytes of data:
Reply from 192.168.3.175: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.3.175:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
If your result matches mine (sent 4, received 4), then open Windows Explorer, then type \\THE.SERVER'S.IP.ADDDRESS in the address bar. Press enter. You should see all disks and shares.
If this test is also successful, type THE.SERVER'S.IP.ADDDRESS into your browser's address bar. Press enter. The webgui should appear.
kweisen likes this.
jeff.lebowski is offline
post #726 of 799 Old 03-01-2014, 08:56 PM
kweisen's Avatar
Start small.
Thank you for helping! It says the "reply from IP ADDRESS: destination host unreachable."
"Packets: sent =4 received=4 lost=0 (0%lost)"
So its unreachable but somehow received the packets still? seems odd
kweisen is offline
post #727 of 799 Old 03-02-2014, 01:50 AM
Here is my network.cfg file from boot/config
# Generated settings:
USE_DHCP=no
IPADDR=192.168.3.175
NETMASK=255.255.255.0
GATEWAY=192.168.3.1
HWADDR=xx:xx:xx:xx:xx:xx
DHCP_KEEPRESOLV=yes
DNS_SERVER1=192.168.3.1
DNS_SERVER2=
DNS_SERVER3=
My router's address is 192.168.3.1, and the server's address is 192.168.3.175. Can you edit your network.cfg file, save it, then plug the USB drive back into the server? You'll most likely want to leave the HWADDR as you find it.
post #728 of 799 Old 03-02-2014, 11:12 AM
kweisen's Avatar
Edit it in what way?
kweisen is offline
post #729 of 799 Old 03-02-2014, 11:42 AM
Edit yours so it matches mine not exactly, but whatever your Gateway and DNS server (Router) address are, DHCP = no, and the IP address should be in the same network. 192,168.1.x, 10.0.0.x, or whatever you use.
post #730 of 799 Old 03-02-2014, 02:15 PM
kweisen's Avatar
THANK GOD nothing was lost! For some reason the network file had USE_DHCP set to "yes" instead of no. I was able to establish a connection to the main tower and restart the array in which I found all my files safe and sound. Doing a parity check now just incase. Thank you for your help!
kweisen is offline
post #731 of 799 Old 03-30-2014, 06:01 PM
adaminnj's Avatar
Could anyone point me to an updated hardware guide to recommended unraid builds? I want to build a midrange system to serve as HTPC storage, Timemachine backup shares for a few macs in the house, mapped network drives for iTunes, iPhoto, etc. and who knows what else. I would like to have 4-6 TB to start with. The hardware guide at LimeTech doesn't appear to be that up-to-date. I would like to keep the budget under $700 or so, as I am also building an HTPC and upgrading my Hackintosh.
adaminnj is offline
post #732 of 799 Old 03-31-2014, 05:57 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
There isn't one. You can pretty much use anything out there. You just have to change the settings under BIOS so upon starting the server is reads the USB port for the OS rather than the hard drive. I would recommend using Intel CPU's. They are more reliable and efficient.
GusGus748s is offline
post #733 of 799 Old 03-31-2014, 03:34 PM
adaminnj's Avatar
Thanks Gus. Your Media Server looks amazing, by the way!
Adam
GusGus748s likes this.
adaminnj is offline
post #734 of 799 Old 03-31-2014, 06:42 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Adam
post #735 of 799 Old 04-05-2014, 11:17 AM
Aryn Ravenlocke's Avatar
Quoted: 351 Post(s)
Liked: 134
Finally, it's that time. I've decided to bite the bullet and am looking to build out a streaming home theatre system. I posted in another thread and was able to get enough information on the basic skeleton of the system that I am going to put together. This is not something I am looking at doing "on the cheap", but I'm also not looking to spend more than I paid for my SUV in order to stream movies to the different devices in my home. Anyway, I'm preparing to put together my disc farm and am still a bit undecided as to what my best solution would be. A big reason for this is that the "experts" I have been talking to down at the shop are anything but impartial and decidedly unhelpful when it comes to answering questions about anything other than their standard stock suggestions.
So, I thought I would come here and see if I might get some info from folks that actually use similar systems in the same fashion I am looking to.
I will be looking to build from scratch, a media server with an initial pre-redundancy capacity of 40 TB. That will be enough storage for what I already have in the house, plus what I am likely to acquire within the next year. At that point I will need to be able to expand by adding another machine to the system to expand the number of drives I can place in the array. When I first set about trying to figure out what I was going to need in order to build my system, I had pretty much sold myself on unRAID to provide a means by which to protect my data from loss, as ripping DVDs and Blurays can be quite time consuming, not to mention a lost drive would mean having to drag discs out of storage. However, ever since I began asking around about building the system, I have been repeatedly warned off of using unRAID. I am told it is finicky and does not provide nearly as much protection as is claimed.
Here's the thing though, no one can give me specific examples of where unRAID comes up short. Therefore, I feel like I am missing out on potentially important information, and that I may simply be falling victim to the bias of those with financial motivation to steer me one way versus another. Currently I am weighing the following options: a Synology system, a Mediasonic disc farm using FlexRAID, an unRAID server, or using Windows 8.1's software RAID solution.
That brings me to why I am here. I am hoping some of you can answer some "simple" questions for me. I have tried contacting customer service over at Lime-tech, but they have been entirely unresponsive to my enquiries.
  1. Are there any significant short-comings to an unRAID system? Looking at the layout, it would seem that it can only sustain failure to one drive at a time, but it doesn't seem that that particular problem is unique to unRAID
  2. How easy/difficult will it be to add an additional enclosure to the array in another year?
  3. Since I am building the system from scratch, I am not worried about mixing and matching drive sizes, all will be the same size. Besides the ability to mix/match drives, what is unRAID's strong "selling" point? Essentially, why do I want to choose unRAID over the other options listed above?
I'm looking for any and all input that I can get. I'm hoping to begin building the system in the very near future and want to make sure that I am doing things right the first time around.
Aryn Ravenlocke is offline
post #736 of 799 Old 04-05-2014, 12:04 PM
1) Transfer speeds to the server can be slow when not using a cache disk. It's never been a concern for me, I average 25,000 kbytes/s and that's plenty. I'm in no rush. Serving speed is obviously fine.
2) Can you clarify what you mean when you type, "add an additional enclosure to the array"?
3) A year ago, I would have said choose another solution due to the SERIOUS lack of updates from Lime-Tech's owner regarding the next version. It was bad. Things have greatly improved, as has the unRAID OS. Well, it was strong before, but there was a big gap between updates. Like >2TB disk support, and likely other things.
I'm a very simple user. I need an array, shares, redundancy, email notifications. That's pretty much it. Dual parity disk is exciting, even though the chance of two disk failures at once is fairly low. In the old days with 2TB disk as the maximum, dual parity was a pipe dream, as we were all concerned about slots for data disks. But now with 4TB support, it's easier to spare a slot for a second parity disk.
post #737 of 799 Old 04-05-2014, 12:30 PM
Quoted: 351 Post(s)
Liked: 134
I suppose I should have been a bit more clear. The options I have been looking at building have all been based off of a 10-drive enclosure. Even if I go with a case /enclosure that will allow me to use more hard drives, eventually the time is going to come when I will run out of disc space. So, whatever path I take in building the media server needs to accommodate adding another enclosure at some point in time. The new enclosure will likely only have 1-2 drives at first, but will over time slowly have more drives added.
I've gone back and forth about whether or not to use a cache disk. I suspect that I will decide to use one, if only to ensure the most consistent possible streaming experience. I could potentially have as many as 3 blurays streaming at once, though it is more likely that I would have a single bluray and a single DVD streaming and nothing else. However, once the media server is built, it is entirely possible that viewing habits in the house will change, and I want the media server to be ready for that eventuality. As for write speed to the server, I've already resigned myself to allowing up to 10 days for all of my external hard drives to be transferred onto the new media server. Once that process is complete, the server will have info added 1-2 discs at a time, so I'm not too worried. Discs simply continue to get added anytime I happen to be sitting at the computer already. I imagine that will pretty much stay the same.
post #738 of 799 Old 04-05-2014, 01:08 PM
Ah. Case!
I started with a single case/server three years ago, added a second smaller server at month ten, and finally a third 24 bay enterprise server at month 27. But, my reasons were to segregate all content. Movies on server 1, TV on server 2, backup/everything else on server 3. I kept things simple, no VM, nothing difficult. Just more boxes and more IP addresses.
The cache disk is only for transferring TO the server, not for serving back to devices on the network. As far as I recall, anyway. The general process is: Transfer files to server (cache disk), the Mover script moves those files from the unprotected cache disk to the protected array at a specified time.
I strongly suggest you COPY data from the external drives to the server using a md5 check. I like TeraCopy. Once everything has passed hash check, then delete from your externals.
post #739 of 799 Old 04-05-2014, 01:21 PM
Quoted: 351 Post(s)
Liked: 134
I considered separate cases for television, movies, and anime/music. I decided that might be going a tad bit overboard though, especially on power consumption. It sounds tome that if I were to choose to go unRAID that there would be no issues with adding another case to the array. Good to know. Thanks!
post #740 of 799 Old 04-05-2014, 01:39 PM
Remember your power consumption will be fairly low when using a modern CPU and generally only one to two disks will be spun up at any time. My three year old rig:
CPU: AMD Sempron 140
Motherboard: ASUS M4A785-M Micro ATX
RAM: Kingston 2GB
Case: Cooler Master 590
Drive Cage(s): Icy Dock 5 in 3
Drive Cage(s): Norco SS-500
Drive Cage(s): Built in CM four slot cage
Power Supply: CORSAIR Builder Series CMPSU-500CX 500W
SATA Expansion Card(s): SUPERMICRO AOC-SASLP-MV8 PCI Express x4 SAS SAS RAID Controller
Fans: 2x Masscool SL-FD12025 120mm for the top (exhaust), one Scythe S-FLEX SFF21E / 120mm 1,200rpm installed on the side panel (intake), then stock fans for the front (intake) and rear (exhaust)
14 2TB disks
It consumes ~70W at idle. I think newer rigs are closer to 40W at idle. Especially with a smaller case and fewer cooling fans. That case has seven fans...
Also, careful with the terminology. In this application, an array is referred to as a system with a single parity disk that protects data disks. Generally within a single case. There are ways to expand a small case with another small case and it still be part of the same array. But generally, when you build a separate case, that is a different array.
post #741 of 799 Old 04-05-2014, 01:47 PM
Quoted: 351 Post(s)
Liked: 134
This is why I am not the IT guy and I am asking around to make sure I get what it is I need. When I walk into the shop I need to make sure I am asking for the right stuff. Thanks!
Yes, it will eventually be 2 cases. Though I doubt I will ever need a third case to house my many hard drives, I have learned to never underestimate just how much hard drive space I might need. So I will avoid saying that I will never need to add a third case filled with drives. What I need is for whatever system I do build to accommodate adding extra cases with drives to whatever already exists with little or no fuss.
post #742 of 799 Old 04-05-2014, 04:56 PM
UHD Addict
aaronwt's Avatar
Liked: 3103
You can always add external enclosures if you want with port multiplier capable eSATA ports. Although that is not the norm. I think I am one of the few people that uses external enclosures with unRAID. I have three unRAID setups. The two that are at max drive capacity each use five external enclosures along with drives in the main PC case. My most recent unRAID setup, uses an HP Proliant G7 N54L. So I have five drives in that plus four external enclosures. But I have not maxed out my drive capacity with that setup yet. One of the enclosures only has one drive in it. While the other enclosures each have four drives. And I still have an eSATA port available to add a fifth enclosure.
post #743 of 799 Old 04-19-2014, 02:45 PM
John_Galt's Avatar
Building onto that last post, I have a few questions about adding an additional enclosure. I currently have my 15 bay server full, and am trying to decide on the optimum solution to get more space.
My ideas:
1) upgrade to bigger hard drives (currently have 15 3TB drives). This seems like an expensive option to get minimal space.
2) build a second server. Doesn't seem like a horrible idea. It would be a lot of money to drop on additional hardware for a second build, and then concerns about space and power consumption. Could also backup very important files across both builds.
3) add an additional enclosure. This is the most intriguing to me, but I have no idea how practical this would be and whether my existing server would "play nice" to this idea. What should I be looking at? I know I don't have an eSATA port on my server, but hopefully have space to add a card (currently out of town). Once an enclosure and drives are connected, is it essentially the same process to configure additional drives? Are there any limitations to this, as in total drives or drives per additional enclosure? I guess I have a unRAID pro license, so I could add an additional 9 drives. What would the downsides be, I guess the potential of losing all your data at once instead of at least having some spread over two separate servers.
Any help is appreciated.
John_Galt is offline
post #744 of 799 Old 04-19-2014, 05:12 PM
UHD Addict
aaronwt's Avatar
Liked: 3103
It's the same process with external drive as internal. It doesn't matter to the unRAID software. But you need a Port Multiplier capable eSATA card as well as a port multiplier capable enclosure. That way you hook one 4 or 5 bay enclosure up to the eSATA port and unRAID will see each drive separately like internal drives. The only downside I've seen is power usage. The external enclosures will use more power than if all those drives were in a large tower case. But the main reason I went with external enclosures was so I could fit everything into a smaller space than having one gigantic PC case that could hold 20+ drives. But since 15 of your drives would already be in the internal PC enclosure. Adding a couple of eSATA ports and enclosures might be the cheapest way to expand it without building a new unRAID setup.
I found the hardware to use from the unRAID Wiki page that has hardware that has been known to work with unRAID. Then I just made sure I got the same chipsets. The last couple of eSATA(port multiplier capable) cards I got were the Rosewill RC-218 cards. I paid around $55 for each of those. They are PCI Express x4 cards since you also need the bandwidth to handle all those drives from a single card. I got those because they had four eSATA ports so I could connect four external enclosures. Then I could supplement that with a single port eSATA card for a fifth enclosure.
post #745 of 799 Old 04-21-2014, 05:35 PM
John_Galt's Avatar
Good info, that definitely has me leaning that route. I just looked up my mobo though and am wondering if I will run into any speed problems.
I have:
2 PCI slots
1 PCI Express x1
1 PCI Express 2.0 x16
I have a NIC in the PCI-E x 1
SATA card (connecting two breakout cables) in the PCI-E 2.0
And a SATA card connecting one additional drive in one PCI slot, with one PCI slot free
My initial thought would be to get a new card to replace the SATA card for the PCI slot that would have two external connectors and one internal. Would that limit me too much on bandwidth? My system is solely for video streaming, primarily BD ISO rips.
post #746 of 799 Old 04-21-2014, 08:41 PM
UHD Addict
aaronwt's Avatar
Liked: 3103
PCI is slow. If I remember correctly one drive is the most that you would want to put on a PCI controller. Maybe it was two. I'm pretty sure I tried it on one of my unRAID setups and I had to stick with only one drive. Otherwise it would slow down the unRAID speed too much when doing a parity check. But I could be mis-remembering and was able to use two drives. It's been awhile.
post #747 of 799 Old 04-22-2014, 06:16 AM
John_Galt's Avatar
Yeah, I guess the bus speed is just part of this that I don't quite grasp. I'll never be pulling data from more than one drive at a time, so why would it matter how many I have hooked up through that card? (rhetorical question, no response needed)
So, what about switching the NIC to PCI and getting a SATA card for the PCI Express x1. Would that allow enough speed to do what I need?
post #748 of 799 Old 04-22-2014, 11:01 AM
UHD Addict
aaronwt's Avatar
Liked: 3103
That would be a better use of the PCI express slot. in normal use you really don't need the extra bandwidth. But when doing a parity check in unRAID it is accessing all the drives at the same time. So very slow access to one drive will slow everything down.
I know with my second unRAID setup, I repurposed an old PC. So the MB was old and had an older version of PCI Express. So I had to use two port mutliplier capable cards and only connect two external enclosures to each one. Instead of the four I had connected to one card in my first unRAID setup. They both get similar speeds with how it's setup but the PCI express slots on my second unRAID had half the bandwidth. Which is why I needed to use two of them for the same amount of external enclosures.
post #749 of 799 Old 06-23-2014, 09:44 PM
Yardl3y's Avatar
Hi guys, I've been looking around in search of a cheap storage solution and found the link below. Seems to be the cheapest I can find with everything else being a huge price jump. Is this product a good buy?
http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
Yardl3y is offline
post #750 of 799 Old 07-19-2014, 04:39 PM
stef2's Avatar
Quoted: 333 Post(s)
Liked: 212
I am extremely happy with my unraid server! I have been using it for more than three years to store backups of all my movies. I play those movies with 3 Dune HD media players and i am totally satisfied with it!
unraid software has been faultless so far. I have experienced two hard drive failures but lost no data thanks to unraid! replacing the defective chinese HD (WD green 2tb) was as easy as 1-2-3.
Building my own server was a satisfying experience, but I would have bought an already built server directly from unraid, had they been available at that time.
shutter-bug likes this.
stef2 is online now
Popcorn Hour C 200 Networked Media Tank Black , The Boxee Box By D Link Hd Streaming Media Player
