Official unRAID Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
Old 02-22-2012, 07:15 AM
chanc's Avatar
Originally Posted by Chrisx510 View Post
Chanc,
I got the problem solved. The Workgroup setting default in unRAID was MShome. I changed it to "workgroup" and now my server shows up.
Good news!!! Did you have any problem boot up with the ECS A885GM-A2 ? There are reported problems at lime-tech forum about bios setup for that board? Just curious, what version of Unraid are you using?
Sharp 80" TV, Onkyo TX-RZ800, Klipsch speakers, SVS subwoofer, Tivo Roamio
chanc is offline
Old 02-22-2012, 09:00 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
I enable the samba and NFS shares for my server, and I just ordered a Dune B1 media player
GusGus748s is offline
Old 02-22-2012, 11:09 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
Dude,
I was about to break something. For some reason or another my unRaid server would not come up under Network on any of my PC's, but I was able to access via browser with //tower or IP.
I Googled it, and read a bunch of directions, changed settings, turned off the server like 10 times, and changed setting on the USB with unraid OS, and nothing.
Then I remember that I reserved IP addresses for my server, W7 PC and AIOS. So, I was like...I've turned everything off and on, with the exception of the router. I wonder if that would fix the problem.
So, I turned off the rebooted the router, and turned it back on. 30 seconds later, I can see tower under network
Old 02-22-2012, 02:15 PM - Thread Starter
Chrisx510's Avatar
Nope not a problem booting up the MB. They must have something in the BIOS configured incorrectly. I know RAJAHAL from Lime has used this board and tested it and had no problems either. The thing that really made me go with this board beside the $45 price is that this MB can handle up to a 20 Bay server. That will come in handy when i decide to upgrade.
My First Home Theater
300 Blu-Rays, 150 DVD's loaded in my Movie Server!
Thanks AVS for making me addicted to this hobby!
Chrisx510 is offline
Old 02-23-2012, 01:21 AM
Murilo's Avatar
Quoted: 128 Post(s)
Liked: 31
I have an unraid question, when you rip or download files to the server I thought unraid showed up as on device, but looking at the gui you rip or download files to separate drives?
Is unrad user shares the only thing that shows up as one single device?
Murilo is offline
Old 02-23-2012, 01:37 AM - Thread Starter
Chrisx510's Avatar
Once you set your shares (movies,music,pictures) then you would just transfer/rip files directing them to the specific share you want that file in. Not sure if thats what you were asking..
Old 02-23-2012, 05:39 AM
Murilo's Avatar
Quoted: 128 Post(s)
Liked: 31
Well I was more so curious if you can rip to specific drives in the server over the network, or if it just shows up as one big drive or server?
So if im on my pc and look at the network and want to rip to the unraid server, is it just all one device or can you rip to specific drives in the server?
Murilo is offline
Old 02-23-2012, 06:39 AM
dbs179's Avatar
Both. Once your unraid is set up you can see all of the "User Shares" you set as well as each individual disk in the server.
dbs179 is offline
Old 02-23-2012, 06:42 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
You can set it up to use individual disk or use a JBOD (just a bunch of drives). If you want to access individual drive, it would be cheaper to buy an external hard drive enclosure than to build a unRaid server.
I was using a 4 bay Mediasonic external hard drive enclosure, which holds drive up to 3tb, which will give you a total of 12tb storage. You can hook it up via esata or usb 3.0.
As a matter of fact, I am selling it since I built my unRaid server I do not need it anymore.
Old 02-23-2012, 06:48 AM
UHD Addict
aaronwt's Avatar
Quoted: 5221 Post(s)
Liked: 3123
I was using a 4 bay Mediasonic external hard drive enclosure, which old drive up to 3tb, which will give you a total of 12tb storage. You can hook it up via esata or usb 3.0.
You can also use the Mediasonics with unRAID. I plan on eventually using five of the Mediasonic 4 bay enclosures with my second unRAID build. I currently use five of the multibay SansDigital enclosures with my first unRAID build and they have worked without any issues. So hopefully I don't have any issues with the 4 bay MediaSonics since I have used seven of them with my WHS for the last couple of years without any issues.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
Old 02-23-2012, 07:16 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
That's true, but at the moment I have no need for it since my case can hold up to 15 drives. I would keep the Mediasonic if my case was maxed out.
Old 02-23-2012, 10:49 AM
Somewhatlost's Avatar
Quoted: 20 Post(s)
Liked: 25
how so? with unRAID, if you want, you can rip/write directly to Drive X (X being any individual data drive) and then have your media player/PC/whatever read from share "\\\\unRAID\\Movies" (or wherever...)
one nice thing about doing it that way is that share "\\\\unRAID\\Movies" can be set to read only....so no worries about someone accidentally deleting something they shouldn't...
how do you do that with just a external hard drive enclosure?
I guess there are always other ways to get there... setting up read/write permissions on a user based level or some such...
but unRAID just makes it so easy by default... why bother futzing with more complicated solutions?
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Somewhatlost is offline
Old 02-23-2012, 12:29 PM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
With an external enclosure, you use your windows PC program to make the share read / write. It's pretty much the same concept with the exception of having no back up unless you use hardware / software raid.
Old 02-23-2012, 02:40 PM
sean_w_smith's Avatar
My dune D1 is on the way. Syabas is lame. sent me two totally DOA boxes. support never returns phone calls and took 4 days to comment on a RMA ticket on their website. SAD!!!!!!!!!!!!
sean_w_smith is offline
Old 02-23-2012, 02:48 PM
Its not the same. windows doesn't have the concept of user shares like unraid where it automatically determines which physical disk to put the data on. not even close even when discounting the raid.
Old 02-23-2012, 04:07 PM
mlknez's Avatar
Quoted: 206 Post(s)
Liked: 52
Check out storage pools in windows 8...
mlknez is offline
Old 02-23-2012, 04:54 PM
I read about it (from you) and it doesn't exist yet (I dont run beta OS's) but I have no issues with unraid. once it comes out I will consider using it to build a future server if its anything like unraid.
Old 02-23-2012, 06:24 PM - Thread Starter
Chrisx510's Avatar
Did you call the Fremont, CA number? I never have any trouble getting a hold of Syabas. Their office is right around the corner from my house. Anyways you're probably better off with a Dune. More solid and plays forced subs with no issues.
Old 02-23-2012, 06:43 PM
I have called The Fremont Number and left over 20 messages with 0 returned calls. I have succesfully called them 10-20 times in a row and hitting 1 to actually get a person twice in the last month but thats it. that approach failed yesterday where I called then over 30 times. PCH support is a joke. Even responding to an RMA request took 4 business days.
we'll see if it works well. what are you using to create your MKV's with forced subs that work. I read the MakeMKV wont do this and you have to do an more complicated process with MkvMerge.
how are you doing this?
Old 02-23-2012, 06:50 PM - Thread Starter
Chrisx510's Avatar
I rip my blu-rays to .ts. I've been having issues with PCH not working with subs properly. dbone was telling me that Dune Players actually work with forced subs because the pay for Licensing.
Old 02-23-2012, 06:56 PM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
I use ClownBD for bluray movies, and makemkv for dvd movies. I do the occasional bluray with makemkv just in case I have issues with ClownBD, which so far I've done with one movie.
Old 02-23-2012, 07:01 PM
subs seem to work with the MKV's on the PCH when authored with mkvMerge. Thats part of your problem. creating MKV's with working forced subs is not as easy as it should be.
so Forced Subs work with .ts on any player?
Old 02-23-2012, 07:22 PM - Thread Starter
Chrisx510's Avatar
Forced subs with .ts only work if you turn them on from the pch remote or your universal remote.. Thats one of my peeves with PCH. Sometimes you don't know if a movie has subs and its irritating to come across a scene that you don't know what they're saying. so you have to rewind then turn on subtitles from the remote and and watch the scene again. According to dbone this isn't a problem with Dune.
Old 02-23-2012, 07:27 PM - Thread Starter
Chrisx510's Avatar
I also use ClownBD and MakeMKV for DVD's. Clown works good most of the time It just takes much longer to rip a movie with ClownBD than it does to rip a movie to a folder structure using AnyDVD HD.
Old 02-23-2012, 07:43 PM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
Yeah, it usually takes me about 45 to 1 hour to rip a movie with ClownBD. I only do ISO DVD TV shows with AnyDVD HD.
Old 02-23-2012, 09:01 PM
gotcha but thats not forced subs. I will be exciting to see forced subs work but I'm very disapointed in learning the dune doesn't do chapter marks.
So back to unraid. Did you get unmenu installed and able to load some additional modules with its package manager.
Can't wait till all this gets totally integrated in 5.0
Old 02-23-2012, 09:07 PM - Thread Starter
Chrisx510's Avatar
What would that be considered then?
I ran preclear yesterday and cleared out my drives. Everything is up and running right now. I started transferring files with Teracopy. I got about 7TB of files to transfer so should take a couple days.
5.0 sounds like its going to be pretty awesome!
Old 02-23-2012, 09:10 PM - Thread Starter
Chrisx510's Avatar
Are you still in Los Altos Sean? I love it out there.. That $100mil house just sold out there recently.
Old 02-23-2012, 09:31 PM
thats considered subtitles not forced subtitles. Its only forced subtitles when you don't have to manually turn it on.
Yes it will take a while. I have mixed results with teracopy.
5.0 should be cool but I want them to get this shipped and probably 5.01 before I think about adding any 3TB drives. Hope this means they support the new 4TB drives too.....
Yes I still live in Los Altos but am currently in utah snowboarding. back in April.
Old 02-23-2012, 09:45 PM - Thread Starter
Chrisx510's Avatar
I'm bummed I haven't been snowboarding this year!
Popcorn Hour C 200 Networked Media Tank Black , The Boxee Box By D Link Hd Streaming Media Player
