how much power for media server - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-08-2012, 01:28 PM - Thread Starter
jntaylor63's Avatar
Starting an new project to convert an PC into a media server. All this box will do is run a dlna service and store music, tv shows and movies. I plan on having 5 HD in the case but I know I will need to update the current power supply.
How many watts would you recommend? (Brand names would be welcome too!)
jntaylor63 is offline
post #2 of 4 Old 02-08-2012, 01:47 PM
sean_w_smith's Avatar
no need to upgrade 200 watt supply is more than adequate for that config
sean_w_smith is offline
post #3 of 4 Old 02-09-2012, 10:19 AM - Thread Starter
jntaylor63's Avatar
Thanks for the reply. That does seem low to me; but I'm not a expert so I asked.
post #4 of 4 Old 02-09-2012, 10:40 AM
halfelite's Avatar
Quoted: 422 Post(s)
Liked: 224
drives them self take very little power once running. The main issue is matching a PSU to the amount of AMPS it takes to spin the drives up. Most drives are rated around 2AMPS during spinup
So make sure your current PSU has the amps matched to spinup and you are set if it dont you can sometimes set staggered spinup. I run a 600watt psu for 15 drives myself. And never had a problem.
halfelite is online now
