Trying to connect roku to tv with no hdmi port...help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-29-2012, 12:37 PM - Thread Starter
Graphixaddict's Avatar
Hello, I purchased my parents a roku and I am trying to connect it to their panasonic th-42pwd8 tv. The tv only has vga, component, svideo, and I think coaxial inputs. Right now the cable box is using the component input and a oppo dvd player is using the vga input. the roku is hdmi and composite out. I tried going composite to svideo with a small adapter put the picture looked like crap. I am thinking I will have to go composite or hdmi to component then use a component switch. Are there anyother options? I could also buy an hdmi blade for the tv but they seem hard to find and expensive.
Graphixaddict is offline
post #2 of 6 Old 03-01-2012, 08:51 AM
SkiSmuggs's Avatar
A new TV would be the best solution. A 42 inch plasma might be the most cost effective. With 52" plasmas available for $600 and up, a 42 should be very reasonable.
SkiSmuggs is offline
post #3 of 6 Old 03-01-2012, 10:29 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Originally Posted by Graphixaddict View Post
I am thinking I will have to go ... hdmi to component then use a component switch.
That's a messy configuration but it will work. Probably your best option if you are going for decent video quality. Monoprice sells a HDMI to component adapter (~$38) with very good reviews and one reviewer specifically stated it worked with his Roku 2. Don't forget the stereo sound has to be output also. They also have a highly rated component video switch (~$18) to round out your configuration. Good luck.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #4 of 6 Old 03-01-2012, 11:18 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Ditto!
GusGus748s is offline
post #5 of 6 Old 03-01-2012, 12:03 PM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
$56 versus $400-$600 would be more cost effective? Hardly. If you're thinking that a new HDTV with 2 HDMI inputs would be a neater solution, then yes. You folks would actually run out and buy a new HDTV just to watch your Roku? Must be nice.
Mr.G is offline
post #6 of 6 Old 03-04-2012, 06:56 PM - Thread Starter
mr g. thanks! just the kind of solution i was looking for. It IS a 42 inch plasma! And it was well recommended here when i bought it, lol! (that was 2006 though)
