Sirius Radio not allowing login with Yamaha RX-A1010 - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 161 Old 01-31-2015, 04:01 PM
PretzelFisch's Avatar
Quoted: 396 Post(s)
Liked: 262
Originally Posted by CaptainVideoJW View Post
Had to change my login in July I think because of a subscription change.
Haven't been able to login on my 2010 or 720! 😡
my sirisxm and rhapsody won't connect on the 720 for most of this month. 2030 is working fine though
PretzelFisch is online now
post #152 of 161 Old 03-01-2015, 01:37 AM
CaptainVideoJW's Avatar
Liked: 42
Updated firmware on my RX-A2010, and RX-A720 because I couldn't login to SiriusXM.
After update, I can login on both receivers.
BUT, I can't listen to various channels like Watercolors (66), or The Message (63).
It tries to buffer and them says access error on LCD display.
CaptainVideoJW is offline
post #153 of 161 Old 03-22-2015, 12:47 PM
qodfathr's Avatar
Access errors on all channels (A2010)
Today was my first attempt to get Sirius IR working. It was also when I happened to notice a firmware update was available.
I took the firmware update -- seemed to apply fine.
I used my Sirius XM online streaming credentials (which work in my web browser and on my iPod) -- login seemed successful and I get a list of stations.
Any attempt to play a station gives me Access Error.
qodfathr is offline
post #154 of 161 Old 03-29-2015, 07:00 AM
qodfathr's Avatar
Just a quick follow-up on this. I did a factory reset and that did not help -- I still get "access error" on every station, although I am able to get the list of stations (indicating that some level of communication is working properly).
qodfathr is offline
post #155 of 161 Old 04-02-2015, 08:50 AM
Liked: 0
So I can log into Sirius 675 model, but it cuts out every1-10 minutes – gets pretty annoying. Iam using DHCP with a LAN cable hardwired from the router.
Called Yamaha several time with no results any luck –suggestions? I have the latestfirmware. Someone said use a static IP,but with my provider I have to pay for one, so all my devices are connected viathe router.
ParkerDD is offline
post #156 of 161 Old 04-02-2015, 10:22 AM
FuegoMCS's Avatar
You should be able to set a static IP on the "private" side of the router. That's what they are referring to, and not on the ISP/Internet/public side. The private network side of your router will typically use IP addresses like 192.168.xxx.yyy or anything in the 10.xxx.yyy.zzz range (far less common or likely). Your specific router's help files or documentation should help you with finding a non-DHCP address that you can assign to your receiver.
Sent from my SAMSUNG-SM-N910A using Tapatalk
FuegoMCS is offline
post #157 of 161 Old 04-02-2015, 12:15 PM
Liked: 0
Wow - awesome thanks for the info. Not network saavy but I should be able to stumble through. Has this solved anyone else's issue...I am reading for some it fixes but not quite everyone?
ParkerDD is offline
post #158 of 161 Old 08-29-2015, 05:24 PM
Liked: 42
Sirius Internet radio update letter I got. Why can't they just keep well enough alone!?!
Name:	Sirius Yamaha Update.jpg
post #159 of 161 Old 08-29-2015, 08:20 PM
Quoted: 396 Post(s)
Liked: 262
because they can't keep running windows 2000 forever.
post #160 of 161 Old 09-13-2015, 12:49 PM
ifish42na's Avatar
The firmware update has already been posted.
http://download.yamaha.com/top/?site...om&language=en
ifish42na is offline
post #161 of 161 Old 12-15-2015, 05:08 PM
Liked: 0
Greetings!
I just discovered the problem I was having and while I didn't see anyone mention this, I didn't scan through all of the pages of this topic (so pardon me if this has already been highlighted):
I was trying to log onto Sirius on my RX-A750 with the same credentials that I use to log onto the Sirius website, when in fact Sirius requires different logon credentials for "SiriusXM Internet Radio Login". You'll find those settings under "My Account Info" on the Sirius website. Once I entered the right credentials, everything worked swimmingly!
Hope this might help anyone who comes to this thread.
Chip
ChipWarren is offline
Yamaha Rx A1010bl Receiver
