WMP12 flac streaming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-12-2012, 09:43 AM - Thread Starter
mipuglie's Avatar
Hello,
I have a problem to share the flac files with windows media player 12.
Initially I could not even locally read .flac, but then installing the codecs and WmptagPLUS I was able to open them and WMP was able to recognize the tags.
The problem arise with my receiver (Yamaha rx v771), which is DLNA certified, supports flac (so much that I can easily open them locally, such as via USB), supports playback of remote FLAC but in practice, when I browse the multimedia library, I can see the mp3 files but I can't see the FLAC files.
The manual of the receiver, regarding the reproduction of FLAC "remote", shows the following note: "to play FLAC, install the server software that supports file sharing via DLNA flac on PC." I imagine that the note has been inserted because WMP 12 does not do it natively ... how can I fix it?
Thanks to all
mipuglie is offline
post #2 of 5 Old 03-13-2012, 11:42 AM
DragonZX's Avatar
^^ As Windows Media 12 does not support FLAC natively you will need to install a decoder, Something like Madflac and M4a/Flac/Ogg/Ape/Mpc Tag Support Plugin for Windows Media Player once this has been done you should be able to stream your music to your Yammy
Good Luck & Best Regards
DragonZX is offline
post #3 of 5 Old 03-16-2012, 11:50 PM
AVGeek99's Avatar
Quoted: 22 Post(s)
Has anyone been able to stream FLAC to any AV Receiver using WMP as the DLNA server?
AVGeek99 is offline
post #4 of 5 Old 03-17-2012, 09:59 AM
Michael Sargent's Avatar
Quoted: 179 Post(s)
Liked: 164
I don't know if anyone has, but I couldn't. I used dbPoweramp's Asset UPNP instead and that worked well.
But in the end I ditched DLNA and went with a Squeezebox Touch. It works perfectly, since it's not saddled with DLNA restrictions. In fact, it works so well I now have two of them.
Highly recommended.
Mike
Michael Sargent is online now
post #5 of 5 Old 03-20-2012, 09:29 PM
AVGeek99's Avatar
Quoted: 22 Post(s)
Highly recommended.
Mike
Thanks for pointing me toward the Asset UPNP. It works perfectly for what I need!
AVGeek99 is offline
