TVpad Owner Thread for the Asian Community - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 132 Old 04-20-2012, 02:38 PM
maxleung's Avatar
Quoted: 22 Post(s)
I found his ebay page (his user name starts with a 7 I think). Seems to be around $40-50 shipping normally.
I'll check with him for this promotion.
maxleung is offline
post #32 of 132 Old 04-20-2012, 02:49 PM - Thread Starter
mofo888's Avatar
Yes that seems to be his ebay ID. But I would still contact him through his facebook page and will probably give you a better shipping rate since he doesn't have to pay the high ebay fees.
mofo888 is offline
post #33 of 132 Old 04-26-2012, 12:00 AM
naddie's Avatar
How do you reinstall the apps? I deleted the music app and now I want it back.
Shen I first used it, all the apps were available to download. Now it isn't. I also tried to download the pkg files and put it on a FAT32 USB flash drive and TVPad does not recognize the drive. I tried several drives. It don't recognize the drive so I can't even use the TVpad to format it, though Windows sees it just fine.
I also tried to factory reset, but it sits there for hours saying its working and do not turn it off. After many ours, I hit the power on the remote and it turned off. Turning it back on reveals that nothing changed.
naddie is offline
post #34 of 132 Old 04-26-2012, 01:34 PM - Thread Starter
mofo888's Avatar
if you can't read any of your usb drives, sounds like you have a bad USB port. Plus not being able to reset your device back to factory default is not normal. I think you may have a defective device. I was going to suggest you to flash your firmware, but you can't even get your USB to work.
mofo888 is offline
post #35 of 132 Old 04-28-2012, 11:49 AM
naddie's Avatar
How do I go about exchanging it? I'm not very good with my Cantonese. I don't know Madirin. It is for my parents.
naddie is offline
post #36 of 132 Old 04-28-2012, 12:36 PM - Thread Starter
mofo888's Avatar
If you got the device directly from TVpad, just contact them and they should be able to exchange it for you since you have a 3 year warranty. You should be able to email them in english and they usually respond in chinese. I'm sure your parents can help you with that.
mofo888 is offline
post #37 of 132 Old 04-30-2012, 06:15 PM
strpyw's Avatar
Great to know about this tvpad, earlier i posted question aboutD70, something similar to this and there was no response.
strpyw is offline
post #38 of 132 Old 05-05-2012, 11:21 PM
strpyw's Avatar
Got my tvpad, only took 4 days shipped from china to california, sweet.
Initially hooked up to my plasma via hdmi, but decided to use inferior composite video /audio connection to my Replaytv for time shifting purpose.The Replaytv actually "calm down" artifacts , so it is fine. Amazingly, the hd picture fill up my widescreen tv!Sweet!
strpyw is offline
post #39 of 132 Old 05-06-2012, 12:04 PM
Ein
Ein's Avatar
Any of the VOD HD, especially the TVB dramas?
Ein is offline
post #40 of 132 Old 05-06-2012, 03:18 PM
strpyw's Avatar
When I connected the TVPad using hdmi to my 1080p display, when watching jade HD, obviously the picture clarity IS not the same when I download the program from torrent.I suspect the bit rate is far less than what is real HD.
Nevertheless, it is still stronger than tvb via cable/sat.I think the box is worth having.I connect mine to Replaytv via composite, and the Replaytv smooths out the picture , and on my plasma display, the 480i picture looks pretty good, though, not reference standard.
strpyw is offline
post #41 of 132 Old 05-06-2012, 07:19 PM - Thread Starter
mofo888's Avatar
Yes the VOD TVB series are very up to date. Current TVB episodes are available a day or 2 after HK broadcast. I usually watch all 4 or 5 episodes on the weekend. It's better than chasing an hour at a time!
mofo888 is offline
post #42 of 132 Old 05-07-2012, 12:49 PM
strpyw's Avatar
another excellent website:
http://www.tvpadzone.com/chinese/download/apps270.html
unfortunately, english site is still in construction
strpyw is offline
post #43 of 132 Old 05-08-2012, 09:57 AM
jogshuttle's Avatar
Hi there..
is there only one VOD app on TVpad? How often do they update the american tv shows on the movie valley app?
thanks.
June
jogshuttle is offline
post #44 of 132 Old 05-08-2012, 10:02 PM - Thread Starter
mofo888's Avatar
there are English movies but no American TV shows at least I haven't found any. This is mostly for Asian TV. If you want American TV shows, best to go with Apple TV or Roku.
mofo888 is offline
post #45 of 132 Old 05-09-2012, 08:43 PM
bnm81002's Avatar
does TVPad get all of the TVB channels?
bnm81002 is offline
post #46 of 132 Old 05-10-2012, 07:27 AM
strpyw's Avatar
no tvb movies channel
I connected mine to slingbox for whole house access, using composite, then output slingbox signal to harddrive recorder for timeshift.When using the slingbox component, using ipad's hdmi to a separate hdmi-component converter, the component signal is still 1080p and no independent recorder can handle it.
strpyw is offline
post #47 of 132 Old 05-11-2012, 05:49 PM - Thread Starter
mofo888's Avatar
check the 1st post with the snapshots of all the channels available. you should find a few TVB channels in HITV and Cantonese BETV.
Lily TV (purple icon) is no longer working. I hope they fix it soon.
mofo888 is offline
post #48 of 132 Old 05-14-2012, 11:06 PM - Thread Starter
mofo888's Avatar
Just wondering if anyone bought TVpad from ebay and what is your experience. Also why did you decide to buy from ebay and not the official site using the $30 discount promo code on this thread?
mofo888 is offline
post #49 of 132 Old 05-15-2012, 11:47 PM
Ein
Ein's Avatar
I got one last week from eBay. The price was less than Hong Kong"s even with the $30 off.
There are just too many steps to follow when ordering from TVPad. The eBay seller offered 60 day exchange. If there is a problem with the seller, eBay will resolve it. When I was shopping last week. There were two sellers, both received good feedbacks from their customers.
Ein is offline
post #50 of 132 Old 05-17-2012, 12:59 PM - Thread Starter
mofo888's Avatar
Totally agree! It just give me a warm and fuzzy to have an extra layer of protection by ebay buyer's protection policy. On top of that it's cheaper on ebay than it is with the discount coupon code getting it directly from China. Some sellers are even selling the latest version 2.72.
mofo888 is offline
post #51 of 132 Old 05-21-2012, 06:17 PM - Thread Starter
mofo888's Avatar
Anyone seen the list of channels available for the new Niji Japanese channel app for TVpad?
mofo888 is offline
post #52 of 132 Old 05-24-2012, 01:10 PM
strpyw's Avatar
I use a separate PC ,using watch slingbox software in full screen, then use a recorder to capture video output from the PC( actually an intel macbook).The component output from the SlingPro HD is actually 720P, but 1080P, that means when Elagto's Game Recoder is out, i will be able to timeshift at HD!
strpyw is offline
post #53 of 132 Old 05-24-2012, 11:04 PM - Thread Starter
mofo888's Avatar
Seems like a lot of work just to record programs on tvpad. Isn't the program you are recording in movie valley? Also very curious how is your bandwidth usage since you have to leave TVpad on and continuously streaming? Do you go over your usage?
mofo888 is offline
post #54 of 132 Old 05-27-2012, 01:19 PM
Troll
ufokillerz's Avatar
Liked: 47
hate to ask this, but can someone send tell me how to get the update for 2.62? i have a m121 version, and for the life of me, i cannot read the chinese, or i get blocked from downloading.
ufokillerz is offline
post #55 of 132 Old 05-27-2012, 04:21 PM
Ein
Ein's Avatar
Ein is offline
post #56 of 132 Old 05-28-2012, 01:28 AM
Troll
ufokillerz's Avatar
Liked: 47
Thank you!!
post #57 of 132 Old 05-29-2012, 10:35 AM
dssjr's Avatar
A friend send me this link on Facebook to get TVpad for 179.99 or wifi package for $199.99. Father's day sale.
Facebook page is Club TVpad. Anyone dealt with them before? Is it safe to get from this seller? Please share your experience. thanks!
w w w facebook.com/pages/ToyzMore4u-Club-TVpad/212039942176662
dssjr is offline
post #58 of 132 Old 06-07-2012, 08:53 PM
dssjr's Avatar
Any other TVpad owners out there that can give me some personal review on this item? thanks!
dssjr is offline
post #59 of 132 Old 06-08-2012, 10:20 AM
strpyw's Avatar
Not everything was recorded in movie alley. There is this tvbhd saturday show "The Lourve and The Forbidden City" which is a show about comparison of the east and west cultures through museum collections that i have been following.
The total bandwidth was less than 1G a day.
strpyw is offline
post #60 of 132 Old 06-15-2012, 10:31 AM - Thread Starter
mofo888's Avatar
Has anyone installed the new TVB App? It's pretty awsome! Has the latest and current TVB shows and the quality is close to 720p.
mofo888 is offline
Roku Streaming Player
