Computer audio: real, myths...or else? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-26-2012, 10:35 AM - Thread Starter
orologio's Avatar
Quoted: 31 Post(s)
hello,
I decided to use a computer (mac mini or an imac) as a music player/server. So, I have been reading a lot of people's opinions regarding whether there are reasons that would benefit me using a Mac mini as opposed to an iMac, as personally I don't know much this field.
But I am a overwhelmed by reading things I would have never thought. Lots of people claim:
- differences between two different computers...
- or different sound from SSD as opposed to conventional spinning drive...
-different sound from different cable ( USB as opposed to Ethernet or spdif)...
-Different/better sound when they upgrade power supply...
-Better sound when they load extra memory...
-and much better sound when they strip down the operating system on the Mac mini (ex: mach2music)...
-Some say it's better to store the music files on external drive...
- According to some it's better if the computer doesn't have the screen (like Mac mini)...
Making and analogy with photography, all of these arguments wouldn't stand a chance in my opinion. Bits are bits right?
Again, I don't know much about it, and my goal is to learn. Are these claims myths, real is else?
Thank you
orologio is offline
post #2 of 10 Old 05-26-2012, 11:47 AM
Selden Ball's Avatar
Quoted: 3090 Post(s)
Liked: 1509
While bits-is-bits, and most of the differences you mention are, shall we say, unlikely, not all software and hardware can deliver the same bits. For example, SPDIF cannot deliver lossless multichannel audio. It can only provide lossless stereo LPCM or lossy multichannel DD or DTS. HDMI with HDCP is required in order for a system to be allowed to deliver lossless multichannel LPCM, Dolby TrueHD or DTS-HD MA.
One of the argued issues is how much jitter must be present in a digital signal for it to cause audible distortion. HDMI has been measured to have significantly higher jitter than SPDIF in most cases. Apparently there is just enough jitter in HDMI from some devices for it to be able to cause effects which might be just barely audible in extremely favorable circumstances.
In the vast majority of listening environments, however, jitter is completely inaudible, and the differences that most people hear are primarily caused by "expectation bias". Also, whenever you listen to anything extremely carefully you'll hear things you never noticed before.
Edited to add: Another major cause of an audible quality difference is the volume level. Even a very small fraction of a db difference will cause the louder source to sound better. Exactly matching volume levels is extremely difficult.
Selden
Selden Ball is offline
post #3 of 10 Old 05-26-2012, 12:36 PM - Thread Starter
orologio's Avatar
Quoted: 31 Post(s)
From what you're saying, it sounds to me that in your opinion an iMac can perfectly work as a music server for a two channel music system, With all the music in its the hard drive: iTunes> dirac live> FireWire to external sound card> coax spdif out. Correct?
Thanks for your reply.
orologio is offline
post #4 of 10 Old 05-26-2012, 12:56 PM
Liked: 1509
Yes, that is correct.
Selden
post #5 of 10 Old 05-26-2012, 01:22 PM - Thread Starter
orologio's Avatar
Quoted: 31 Post(s)
Thank you
orologio is offline
post #6 of 10 Old 05-26-2012, 01:24 PM
Liked: 1509
You are very welcome.
Enjoy the music!
Selden
post #7 of 10 Old 05-26-2012, 07:53 PM
pdr1979's Avatar
In my opinion I think what you want to do is pretty simple. I currently use an HP desktop as my server running iTunes. From the pc I use digital coax to my 2 channel receiver. The pc is on a different floor from my audio system so I use the apple remote app via my iPad and iPod touch as a controler. There is also a remote app for android devices that will do the same. Depending on the format of the media you plan to play, iTunes works just fine for mp3, aac, and apple lossless. hope this helps you.
pdr1979 is offline
post #8 of 10 Old 05-27-2012, 07:40 PM - Thread Starter
orologio's Avatar
Quoted: 31 Post(s)
Yes, thank you for your input.
orologio is offline
post #9 of 10 Old 05-27-2012, 10:57 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Good lord, I don't know whether LOL or cry Where are you getting all these stuff.
U probly would like one of those alien brain dump to Data, sending him a lifetime of experiences in just seconds... but that's not going to happen. The only way to learn is read - read - read.
Take one item at a time, google, use the search button here, read.
MrBobb is offline
post #10 of 10 Old 05-30-2012, 10:44 PM - Thread Starter
orologio's Avatar
Quoted: 31 Post(s)
I was wondering why it took two long days to get a troll over here...
Please re-read my post and maybe you'll understand it ...or maybe not.
orologio is offline
