New Dune Firmware 120531_2200_beta - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 06-03-2012, 10:15 PM - Thread Starter
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
Big update to the Dune Player line...
Changes since 120329_2012:
NOTE: This firmware version has a lot of changes, is not well tested, and
some things may be broken. If something does not work for you, please
rollback to 120329_2012 version.
* Added a set of preinstalled applications.
- Facebook.
- Twitter.
- AccuWeather.
- YouTube.
- RuTube (Russian language only).
- Videomore (Russian language only).
- TV Rain (Russian language only).
- Horoscope (Russian language only).
- RIA news (Russian language only).
- Poverhnost TV (Russian language only).
- Megogo (for Russia, Ukraine and other ex-USSR countries only).
- Videoprobki.ua (for Ukraine only).
- video.bigmir.net (for Ukraine only).
- Games: chess, four, sudoku, memory, tetris (Russian language only),
snake (Russian language only).
* Web browser improvements.
- A new version of web browser engine is used.
- Browser performance slightly improved.
- Dune HD TV-101 and TV-301: Spatial navigation support is added:
navigate through the elements of the web page using LEFT/RIGHT/UP/DOWN
RC buttons.
- Some other improvements and fixes.
* DVB-T improvements.
- TV OSD is now used during DVB-T playback.
- Added EPG showing.
- Added support for DVB-T channels icons.
- DVB-T buffering and channel switching improvements.
* UI improvements.
- Text fields in the main menu do not require any more to press ENTER to
edit the text: text fields are now always "active" and the text can be
edited immediately.
- RC button "D" in text fields in the main menu can be used to show the
on-screen virtual keyboard. Currently, only English and Russian
languages are supported.
- Animation added in some places where it was missed previously.
- TV OSD improvements:
- ENTER on TV channel which is already played just closes the OSD and
does not restart the playback.
- Navigating to a different TV channel resets the EPG panel to today.
* Playback improvements.
- Added support for HLS protocol for streaming media content. Adaptive
bitrate is supported. VOD and Live TV/radio modes are supported. AES
encryption is supported.
- media_url syntax: http://{host}[:{port}][/{path}].m3u8[?{args}]
- More details: http://dune-hd.com/support/misc/media_url.txt
- Added support for RTSP protocol for streaming media content. Only MPEG-TS
streams are supported. RTSP+RTP and RTSP-over-TCP modes are supported.
- media_url syntax: rtsp://{host}[:{port}][/{path}]
- Improved multicast IPTV playback support.
- Faster playback startup and faster switch between multicast IPTV
channels.
- Fixed problems which took place sometimes when the user attempted
to switch between IPTV channels two quickly.
- Improved errors detection and handling.
- Added possibility to pause/resume the playback (with picture
freezing).
- Added support for DVB subtitles.
- Added support for teletext passthrough (works with some TV models).
- Improved support for playback of MP4 files via HTTP protocol.
- Autoframerate enabled also for MP4 files played via HTTP protocol
using "http://mp4://" media_url syntax.
- Optimized playback of MP4 files via HTTP protocols w/o the use of
- Improved support for playback of HTTP/TS streams.
- Performance of playback from SMB shares improved on SMP8670 platform
(Dune HD TV-101 and TV-301 models). Now the SMB performance with Dune
HD TV-101 should be approximately the same as with Dune HD Smart and
Max/Duo models.
* Various new features for application development.
- dune_folder.txt extensions and improvements:
- New parameters:
- paint_details_box_background = yes|no
- help_line_text_color = N
- item_detailed_info_title_color = N
- item_detailed_info_text_color = N
- item_caption_color = N
- item_sandwich_icon_scale_factor = N.N
- More details: http://dune-hd.com/support/misc/dune_folder_howto.txt
- Added a possibility to specify various playback options in media_url
using "|||dune_params|||" syntax.
- Supported options:
- rtsp_tcp:0|1
- rtsp_seek_via_reopen:0|1
- protocol:hls
- hls_initial_bandwidth:low|high
- hls_key_url_add_query:{string}
- enable_seek:0|1
- buffering_ms:1..60000
- Added a possibility to launch web browser using a special media_url
syntax.
- media_url syntax: www://{HTTP-or-file-URL}[:::{parameters}]
- Supported parameters:
- fullscreen=0|1
- webapp_keys=0|1
- zoom_level={N}
- overscan={N}
- user_agent={string}
- background_color={color}
- Dune IP Control API extensions and improvements:
- New IP Control commands:
- start_playlist_playback
- launch_media_url
- get_text
- set_text
- More details: http://dune-hd.com/support/ip_control
- Dune FlashLite API extensions and improvements:
- Added support for HTTPS.
- Improved support for USB keyboards.
- New API operations:
- requestPlaylistPlaybackOnExit
- requestPlaylistPlaybackOnExitWithReturn
- requestDVDPlayerOnExit
- requestDVDPlayerOnExitWithReturn
- requestBlurayPlayerOnExit
- requestBlurayPlayerOnExitWithReturn
- More details: http://dune-hd.com/support/flash
- Dune PHP Plugins API extensions and improvements:
- New GUI actions:
- file_play
- dvd_play
- bluray_play
- playlist_play
- launch_media_url
- change_behavior
- show_black_screen
- show_main_screen
- New GUI events:
- timer
- playback_stop
- New properties in existing data structures:
- GuiAction:arams
- PluginInvalidateFoldersActionData::details
- PluginInvalidateFoldersActionData::rate_details
- PluginMovieFolderView::left_button_caption
- PluginMovieFolderView::left_button_action
- PluginMovieFolderView:arams
- PluginRegularFolderView::timer
- PluginTvInfo::epg_mode
- PluginVodInfo::initial_position_ms
- PluginVodInfo::advert_mode
- PluginVodInfo::actions
- PluginVodInfo::timer
- ShowDialogActionData::actions
- ShowDialogActionData::timer
- ShowDialogActionData::max_height
- ShowDialogActionData::initial_sel_ndx
- ViewItemParams::item_caption_color
- ViewItemParams::item_sandwich_icon_scale_factor
- ViewParams:aint_details_box_background
- ViewParams::help_line_text_color
- ViewParams::item_detailed_info_title_color
- ViewParams::item_detailed_info_text_color
- New data structures and their properties:
- BlurayPlayActionData::url
- ChangeBehaviourActionData::actions
- ChangeBehaviourActionData::timer
- ChangeBehaviourActionData:ost_action
- DvdPlayActionData::url
- FilePlayActionData::url
- GuiTimerDef::delay_ms
- LaunchMediaUrlActionData::url
- LaunchMediaUrlActionData:ost_action
- PlaylistPlayActionData::url
- PlaylistPlayActionData::start_index
- PluginFolderViewParams:aint_path_box
- PluginFolderViewParams:aint_content_box_background
- PluginFolderViewParams::background_url
- PluginVodPlayActionData::vod_info
- ShowBlackScreenActionData:ost_action
- ShowMainScreenActionData:ost_action
- New features related to plugin file structure:
- {plugin_install_dir}/bin/
- The player automatically sets executable permissions on all
files in this directory during plugin installation.
- {plugin_install_dir}/www/{path}
- The player automatically makes these files accessible via
HTTP (locally inside the player, and from the local network):
- http://localhost-or-dune-ip-address/plugins/{plugin_name}/{path}
- {plugin_install_dir}/www/cgi-bin/{path}
- The player automatically makes these CGI applications
accessible via HTTP (locally inside the player, and from the
local network):
- http://localhost-or-dune-ip-address/cgi-bin/plugins/{plugin_name}/{path}
- Other new features:
- Ability to package FlashLite application into plugin and launch
it when the user enters plugin entry point, or when PHP plugin
code decides to call it. Supported via the new "launch_media_url"
action.
- Ability to package HTML page/application into plugin and launch
it in web browser when the user enters plugin entry point, or
when PHP plugin decides to call it. Supported via the new
"launch_media_url" action.
- If the plugin is pure FlashLite or HTML application and does not
need to execute any PHP code, "plain" plugin type can be
specified in plugin manifest instead of "php"; in this case,
there is no need to include PHP program into the plugin and
specify "program" parameter in plugin manifest.
- More details: http://dune-hd.com/support/plugins
* Other minor changes.
- The set of preinstalled UI skins slightly reduced to free some flash
memory for new firmware functions and applications.
- DHCP client sends the information about player model and firmware
version to DHCP server using DHCP vendor specific options.
- Various other minor fixes and improvements.
mlknez is offline
post #2 of 14 Old 06-03-2012, 11:08 PM
Opentoe's Avatar
Quoted: 87 Post(s)
I have a Dune Prime 3.0. Does the Smart series have a similar firmware of the Prime? Are they almost identical and do they perform similar or is one better then the other? I'm asking because my room mate wants to buy a media player and for some reason is stuck on DUNE only. So i'm trying to help him with which player to get. If they Smart series has a stable firmware like the Prime, then I guess I would suggest those models.
Opentoe is offline
post #3 of 14 Old 06-04-2012, 07:35 AM - Thread Starter
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
No audio or photo improvements yet again. No h.264 over rtsp. New apps cannot be hidden. New weather app does not have configurable units and will not use the players units.
Hey! Deaf people at Dune! Improve the basic media playing features of the product before adding Unnecessary social and web stuff!!
mlknez is offline
post #4 of 14 Old 06-04-2012, 07:37 AM - Thread Starter
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
They are the same
mlknez is offline
post #5 of 14 Old 06-07-2012, 02:36 PM
jmirabil's Avatar
Dune players are the best hybrid players, and they hold up well; I write from experience. I've owned many NMT's and media streamers, 3 popcorn hours/syabas players, 4 or 5 KiSS/Linksys boxes, and the HDi Dunes are by far the best. I own SEVEN of them now - all major models except the Duo and Max models (I prefer the lower cost smaller SMART models) : Two V2 HD Centers with gigabit ethernet, one BD prime v1.0 with native wireless (rare) (had two of these, but one died last year after almost 4 years of use), and one HD Base V3 and one BD Prime V3, and two smart players (B1 and D1) . Oddly enough, I have the greatest affinity for the older models - the two HD Center units, as they have solid dedicated gigabit ethernet and have the nicest looking "hi Fi" cases. The newest firmware is pretty nice, I highly recommend it. I also figured out that the Memorex MVBD2511 Bluray player is the exact same power supply as in the BD prime V1 player, and it has allowed my oldest players to have two replacement power supplies. I even still have a spare.... Dunes are great--highly recommended.
jmirabil is offline
post #6 of 14 Old 06-07-2012, 02:39 PM
LVS
LVS's Avatar
^ which jukebox are you using or do you prefer?
LVS is offline
post #7 of 14 Old 06-07-2012, 05:09 PM
lsarver's Avatar
Accuweather? Web Browser? BFD
lsarver is offline
post #8 of 14 Old 06-08-2012, 09:11 PM
mr b's Avatar
Quoted: 74 Post(s)
Liked: 37
Strange, my HD DUO had an upgrade to this firmware when I fired up the home theater, then right after updating, got a message saying that 120608_1420_beta was available. Haven't been able to find a changelog, but I went ahead and updated. Main thing I'm looking for is improved MP4 playback. (specifically better FF and Rew)
__________________________________________________ ________________
LG 75UH8500, 55UH7700 x 2 | Sharp 70TQ15 | Onkyo TX-NR656 | Polk Satellites | CS200 Center | Infinity BU-1|
24TB Server 2012 R2E | ReadyNas RN104 | Nvidia SATV | Amazon FTV2 | Mede8er 800X3D |
Dune HD Duo | XBone-S | Samsung UBD-K8500 |
mr b is offline
post #9 of 14 Old 06-09-2012, 07:23 AM
drcos's Avatar
Can't hide, don't want FACEBOOK, YOUTUBE, etc.
Back to 120202 for me.
Hello, Dune, thanks for adding useless crap, and not adding useful stuff.
Where is "AUTO" for audio channels decoded instead of 'Stereo, 5.1, 7.1' ???
I'll stop ripping my BDs when I can put them in and watch the movie without trailers, warnings, cutesy menus...
drcos is offline
post #10 of 14 Old 06-09-2012, 05:20 PM
lsarver's Avatar
Since you mention "useful stuff," I vote again for native frame-rate resolution. . . . which even my ancient TViX M-6500A has.
But Dune has long since stopped listening. (So did DViCo.)
Edited to correct "frame-rate" to "resolution." (D'oh!)
lsarver is offline
post #11 of 14 Old 06-11-2012, 06:19 AM
streamerlover's Avatar
nice find/post about the memorex power supply. that will come in handy eventually..
streamerlover is offline
post #12 of 14 Old 06-11-2012, 09:50 AM
jmirabil's Avatar
I dont use a jukebox app, I just use raw directories with well-named files, but people comment well on Yandis, and Zappiti to name a couple....
jmirabil is offline
post #13 of 14 Old 06-11-2012, 11:58 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Zappiti is pretty simple and easy to use. That's what I am using right now.
GusGus748s is online now
post #14 of 14 Old 06-11-2012, 12:06 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
If you own an iPad then 10Muse is by far the best Jukebox there is. I have given up on all others since I own an iPad.
Killroy is offline
