Popcornhour A300 help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 06-21-2012, 11:26 AM - Thread Starter
Whiplash989's Avatar
First, I'm very sorry if this has been asked already, I tried searching and I'm overwhelmed by information that I can't use.
I hooked up my popcornhour A300 a little bit earlier today and so far its not bad. I got the 32GB USB to work. 3.5 HDD is a no go because its not a SATA so I will get some HDD later on when I have some money.
Right now my issue is that I cant stream media from my PC to the A300. I am able to detect the PC with the A300, but I cant access anything. I put in my username and password (I am admin) and it says invalid ID/PASS.
What do I do?
I looked through the manual thats online and its no help to me. Just says this is where you enter your username and password...
PS - Im wired through ethernet.
Anyone out there that can help me?
Whiplash989 is offline
post #2 of 15 Old 06-21-2012, 01:15 PM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
Did you followed this wiki? I followed this wiki when I used to own a PCH-A300 and it worked for me. Try uninstalling Windows Live Essential I believe first!
http://www.networkedmediatank.com/wiki/index.php/Network_Share
If that doesn't work, you can try this after:
http://www.networkedmediatank.com/wiki/index.php/Networking_with_Windows7
GusGus748s is offline
post #3 of 15 Old 06-21-2012, 01:19 PM
halfelite's Avatar
Quoted: 464 Post(s)
Liked: 242
halfelite is offline
post #4 of 15 Old 06-21-2012, 01:38 PM - Thread Starter
post #5 of 15 Old 06-21-2012, 07:44 PM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
No problem. I hope you get it working!
post #6 of 15 Old 06-23-2012, 09:57 AM - Thread Starter
I still can't get it to work.
Any possibility that someone can PM me their phone number and I will call (magicjack, free for both parties) and if it works I will paypal you $15?
post #7 of 15 Old 06-23-2012, 10:49 AM
canton160's Avatar
Quoted: 24 Post(s)
Liked: 50
try to disable windows firewall....
regards
canton
Anthem MRX310 | XTZ 93.23 DIY 5.1 (Seas Jantzen Mundorf) | DXD808 | Oppo 103D | LG OLED 55EC930V | Mitsubishi HC5 | Lusoscreen 100"
canton160 is offline
post #8 of 15 Old 06-23-2012, 11:45 AM - Thread Starter
Send me your paypal sir, its working.
post #9 of 15 Old 09-29-2012, 10:01 AM - Thread Starter
So I had to reset my router and now everything is not working again.
When I click to browse network it says :"Unable access to server, please check your server setup"
And when I try setup wizard. It says "Network error. Unable to connect to the internet.
Help?
post #10 of 15 Old 09-30-2012, 09:21 AM - Thread Starter
Turns out it needed a firmware update. Even though I checked that earlier. I had to unplug everything from the unit then check again. Working fine again.
post #11 of 15 Old 01-05-2013, 09:02 PM
pwfletcher's Avatar
Is there an app the get popcornhour to work with the Indigo Home Automation software so that I can control everything from my tv? I found this discussion of the software but I can't find anything regarding a popcorn hour app, only an app for XBMC ...Indigo Home Automation Software
Thanks in advance.
I like shiny stuff.
pwfletcher is offline
post #12 of 15 Old 01-05-2013, 10:43 PM
halfelite's Avatar
Quoted: 464 Post(s)
Liked: 242
Originally Posted by pwfletcher View Post
Is there an app the get popcornhour to work with the Indigo Home Automation software so that I can control everything from my tv? I found this discussion of the software but I can't find anything regarding a popcorn hour app, only an app for XBMC ...http://www.humanovation.com/2011/11/19/114/
Thanks in advance.
I dont know anything about that home Automation apps, but everything on the A300 can be controlled over IP, there is a raw port on 30000 that can accept remote control commands then there is the API interface that will take http requests and output xml responses that can invoke playback as well as other things.
pwfletcher likes this.
post #13 of 15 Old 01-07-2013, 12:55 PM
pwfletcher's Avatar
Thanks ... I'll see if I can incorporate the automation into applescripts that can be sent via IP.
I like shiny stuff.
post #14 of 15 Old 02-12-2013, 01:24 PM
pwfletcher's Avatar
Got it working ... mostly ... using applescripts ;-)
I like shiny stuff.
post #15 of 15 Old 02-23-2013, 09:39 PM
pwfletcher's Avatar
OK ... that problem solved. Now I am trying to be able to control everything using my Pebble Smartwatch and am stumped. I am trying to configure an applescript to send a command to the A300 over IP when it receives an email with a specific subject header from the Pebble watch, but am have problems with the script. Will try Automator next ...
I like shiny stuff.
