Oppo BDP-93 vs computer-based music server - AVS Forum | Home Theater Discussions And Reviews
Old 07-06-2012, 04:44 PM - Thread Starter
bkeeler10's Avatar
Quoted: 296 Post(s)
Liked: 175
Hi everyone,
I'm beginning the process of revamping my audio system, and it will include the ability to play music from a hard drive. I intend to buy an Oppo BDP-93 as part of my new system. I know it will stream all the file formats I wish to be able to play. However, I have read about a lot of people that are setting up dedicated computers to handle this task. I'm trying to decide if streaming my audio files via the Oppo is sufficient, or if I need to look into building a music server.
My primary concern is the quality of the sound. Of course a friendly user interface is nice, but I'm not willing to pay a whole bunch extra for that. However, I am willing to invest more if it means a significant increase in sound quality. The Oppo player or server would be sending digital signal to an Anthem MRX receiver via HDMI , optical or SPDIF.
So the question is this: Does anyone out there have experience with both the Oppo and a high-quality music server that would indicate that there is a significant sound quality advantage to either option? Thank you.
bkeeler10 is offline
Old 07-06-2012, 04:58 PM
rdgrimes's Avatar
Quoted: 2008 Post(s)
Liked: 1341
Digital files are the same played from any device, it all sounds the same. Caveat: if your player is setup to decode and output by analog connects, it can make a difference.
As long as the Oppo supports a particular file format, there's no difference in "quality" compared to a PC.
rdgrimes is online now
Old 07-07-2012, 09:30 AM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
I've been using my Oppo 93 to play flac from a 2TB HD, the only problem is the slow interface to browse through all those files, it works great though. Something like Squeezebox would make browsing much easier, but won't change the sound in any way.
saeyedoc is offline
Old 07-07-2012, 09:50 AM
Denny123's Avatar
I own an Oppo-93 connected via HDMI to a Marantz AV7005. I use it to play SACD's, but for CD playback I use my home computer. I ripped my CD collection to FLAC files and stored them on the home computer. I have a wired connection from the PC to the Marantz. Marantz offers DLNA to allow playback of the computer files. For DLNA to work server software is required on the PC. I initially chose Twonky. It worked well. I used it for several months until I read about jRiver Media Center. jRiver offers a 30 day free trial so I installed it on the PC, following jRiver's setup guidlines. The improvement in sound quality over the Oppo-93 playing the CD to the Marantz and Twonky streaming via DLNA to the Marantz was pretty astonishing. My entire CD library became much more listenable, so much so that I have spent the last several weeks listening to it again. The improvement in sound qualities that i perceive are: higher resolution sound (a lot more detail), wider sound stage, and a deeper, almost three dimensional, sound stage.
If your Anthem does not have DLNA, jRiver recommends connecting an HTPC running jRiver to a receiver/prepro using HDMI. They suggest the quality of sound will be better than DLNA.
Hope this helps in your decision.
Denny123 is offline
Old 07-09-2012, 10:52 AM - Thread Starter
bkeeler10's Avatar
Quoted: 296 Post(s)
Liked: 175
Thanks for the feedback. I'm surprised no one chimed in saying that they thought there would be a sound quality difference. Whether there is or not, usually both opinions are represented when it comes to sound quality.
Saeyedoc: Although I haven't used the Oppo, I suspected that its interface would be cumbersome for music files. Does the Oppo have an on-screen (TV) interface and do you use it? Is it difficult in terms of layout, organization, ease of use, etc., or is it just a little slow and unresponsive? I will have a projector, and I most certainly would not want it to be on for music listening.
Seems to me that it would be nice if Oppo had an app for tablets and/or smartphones, and part of it could include a nice interface for browsing your music file collection.
Old 07-09-2012, 12:28 PM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
The on screen interface just shows the files however you have them organized. It will show cover art on one of the screens that shows what's playing currently.
It works fine, it's just cumbersome to use with large numbers of files and no search feature. You would have to use a screen to see what you're doing, you'd have to hook up a monitor to one of the Oppo outputs if you don't want to use your projector.
saeyedoc is offline
Oppo Bdp 93 Blu Ray Player
