Issues with Netflix Streaming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-08-2012, 04:56 PM - Thread Starter
Cocophone's Avatar
I'm having issues with netflix streaming. The netflix stream gets dropped about 3 or 4 times per TV show.
I have comcast internet with voice service. The comcast modem is a RCA Thompson Model DHG535-2. It is DOCSIS 2.0 modem which also handles the voice service.
I have a D-link DIR 601 router and a Sony BX18 bluray player.
If I plug the bluray player directly into the Comcast modem netflix plays straight through the TV program without dropping the connection.
If I plug the bluray player into my D-link router and the router into the comcast modem, then the netflix stream is dropped several times during the TV program.
I've even tried having the D-link router put the bluray player into a DMZ zone but that did not fix the dropped streaming problem.
Could I get some recommendations for a new router?
I don't care too much about wireless since my bluray player is wired with ethernet and the only wireless I do is for iPhone and an android phone.
==Cocophone==
Cocophone is offline
post #2 of 14 Old 07-09-2012, 05:39 AM
Colton's Avatar
Upgrade to a DOCSIS 3.0 modem and all your problems will go away. I had to do this too. Too many dropped connections or severe lags.
Colton is offline
post #3 of 14 Old 07-09-2012, 07:33 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
You don't have to do that. You only need a DOSCSIS 3.0 if you are getting a faster speed that requires DOCSIS 3.0. Have you tried a different router? I had a similar issue, but with ATT UVerse internet. UVerse provides their own moden/router. I had my own router WNDR3700. However, the uverser RG / router / modem would fight with my WNDR3700 because both wanted to provide IP addresses for my devices. I attempted to make the Uverser router/modem act as a bridge, which didn't work. Then I tried to set up my WNDR3700 router to DMZ, which didn't work.
I ended up taking my WNDR3700 router out, and only use the UVerse router / modem, and I have no issues with anything now. I even get faster and longer range with wireless connection with the UVerse router.
GusGus748s is offline
post #4 of 14 Old 07-09-2012, 12:33 PM - Thread Starter
Cocophone's Avatar
The RCA Thompson Model DHG535-2 doesn't function as a router.
I'm going to try using a different router because there was no problem streaming when I plugged the bluray player directly into the RCA Thompson modem.
So either my router is not able to steadily stream video or there is an incompatiblity between the RCA Thompson modem and the D-link 601 router.
==Cocophone==
post #5 of 14 Old 07-15-2012, 10:11 AM - Thread Starter
Cocophone's Avatar
I bought a netgear 3500 router and my problems were solve. My old Dlink router must have been failing.
==Cocophone==
post #6 of 14 Old 07-16-2012, 12:06 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
which media players do 5.1 netflix, and 1080p hd
zoro is offline
post #7 of 14 Old 07-16-2012, 05:07 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
There isn't many media players that can play Netflix. The only one I know are WDTV's and Boxee Box. It would suggest using either a gaming console (PS3, XBOX) or a Roku Box.
post #8 of 14 Old 07-16-2012, 11:02 PM
mtallent's Avatar
I have a WD Live Hub and A WD Live Streaming and they both stream Netflix with 5.1 sound and 1080P when available, also my PS3 works the same with Netflix.
Mike T
mtallent is offline
post #9 of 14 Old 07-17-2012, 11:02 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
Netflix doesn't do 1080p. It might be able to do 5.1 though.
post #10 of 14 Old 07-17-2012, 05:55 PM
dstew100's Avatar
This is not true. Streaming 1080p and Dolby Digital + right now. Your device may not support it though.
EDIT: And it is only certain titles. Plus some titles will be HD but not the hi rez audio
dstew100 is offline
post #11 of 14 Old 07-17-2012, 08:09 PM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
I am sorry. It is true Netflix support compressed 1080p since it is base on your bandwith. If your internet connection is too slow the resolution / audio will be compressed / lower thus not making it a true 1080p.
post #12 of 14 Old 07-17-2012, 08:30 PM
dstew100's Avatar
Roger that, agreed. Mine can go through 4 levels of SD and 4 levels of HD but does spend the vast majority of its time at the highest level on my cable modem connection. I do not pay for the ultra fast speed or anything though.
dstew100 is offline
post #13 of 14 Old 07-19-2012, 08:55 PM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
Hi Gus,
Would you mind identifying what devices are capable of handling high def?
zoro is offline
post #14 of 14 Old 07-20-2012, 07:28 AM
GusGus748s's Avatar
Quoted: 428 Post(s)
Liked: 705
Hi Gus,
Again, it doesn't matter if your device can handle high definition with Netflix since the quality of video / audio is dependent on your internet speed. The better your internet connection the better the video / audio quality.
