any media player yet that supports blu ray menu playback? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 47 Old 07-15-2012, 01:40 AM - Thread Starter
smackjack22's Avatar
I have the wdtv live and patriot box office and both do not support blu ray menu play back from a bdmv folder.I haven't read anything where any player supports for blu ray playback with menu.Is there any player out there to play full blu ray rips flawlessly with the menus?
smackjack22 is offline
post #2 of 47 Old 07-15-2012, 03:17 AM
cosma3's Avatar
Dune HD Smart B1/D1/H1 will play menu's from the BDMV folder. You can either stream them or play them from a hard disk fitted to the Dune.
cosma3 is offline
post #3 of 47 Old 07-15-2012, 03:42 AM - Thread Starter
Are there any other choices? $320 is a lot to spend for what i want to do.However it does say it does high quality up scaling which can make it worth it.Also what is the best version the B1,D1 or H1?
post #4 of 47 Old 07-15-2012, 03:56 AM
cosma3's Avatar
I believe the Popcorn Hour A200/A300 can also do the same as the Dune.
You can play physical discs with the B1, the D1 has a display on the front and the H1 has a hard disk fitted inside. They are the same player apart from those differences.
cosma3 is offline
post #5 of 47 Old 07-15-2012, 04:13 AM - Thread Starter
Reading posts on popcorn a200 and a300 having playback issues and dune not having a problem it's the only safe choice.
post #6 of 47 Old 07-15-2012, 04:19 AM
cosma3's Avatar
Yeah, it's a solid choice if you buy one. I've got a D1 and it's excellent at streaming full blu-ray's using smb shares, either as an iso or folder structure. Firmware updates are also pretty reliable too.
cosma3 is offline
post #7 of 47 Old 07-15-2012, 05:16 AM
Scott Greczkowski's Avatar
Quoted: 58 Post(s)
Liked: 101
How about ISO Bluray playback?
All my early Bluray Rips are in ISO. Wasn't until a few months ago I moved over to ripping them to MKV's.
Scott
SatelliteGuys.US / MultiChannel News
Scott Greczkowski is offline
post #8 of 47 Old 07-15-2012, 06:27 AM
klbcolt's Avatar
I use the following site to research different media players:
http://www.iboum.com/net-media-players.php
klbcolt is offline
post #9 of 47 Old 07-15-2012, 11:45 AM
streamerlover's Avatar
Netgear NeoTV 550 is also a solid playback device for blu ray iso and bdmv folder structure with MENUS.. It has other issues not related to that but for the current street price of $80 you really can't complain...
Disclosure...I buy and try media players all the time. Have had about 16 this year....The Dune is by far the single most reliable followed by the a200 and c200 series from popcorn hour. the newer a300 has some work to do on it..
streamerlover is offline
post #10 of 47 Old 07-15-2012, 02:57 PM - Thread Starter
The only thing that bothers me about getting the dune hd is that im read a review that it came out in jan 2011 with a mrsp of $256.I can only find it for $320 now.Doesn't make sense to me
post #11 of 47 Old 07-15-2012, 03:07 PM
djc11369's Avatar
Quoted: 243 Post(s)
Liked: 141
That's because they a raised their prices a short time ago.
djc11369 is online now
post #12 of 47 Old 07-15-2012, 03:26 PM
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
RT1185 based boxes (e.g. Pivos AIOS $75 after $20 MIR at most retailers) supports non-java menus for both ISO and BDMV (pre BD 2.0).
RT1186 boxes is claimed to support Java Menus too (but haven't personally verified that).
There will be sure more capable option as you raise the budget (though I would say $250 should be the where the bar is set as at that point you can build a capable net-top).
aasoror is offline
post #13 of 47 Old 07-15-2012, 06:48 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Do not buy a 1185 base unit. It only support java 1.0 BD menus, and it will not support any of the new java 2.0, which is pretty much every new movie nowaday. If you do not want to spend too much money on a media player with Full BD menu, I would recommend the Netgear NeoTV550. I believe the Micca EP600 G2 and EP950 supports full BD Menus.
GusGus748s is offline
post #14 of 47 Old 07-16-2012, 12:46 AM
If you want the absolute BEST playback for bdmv folders AND ISO files via attached USB, get an oppo 93 with the older firmware. It also plays back 3D blu ray discs FLAWLESSLY, There is no equal. Kicker is that it has to be attached to usb...and not cheap..
post #15 of 47 Old 07-16-2012, 07:11 AM
trondmm's Avatar
Dune HD Smart B1/D1/H1 plays menus from blu-ray isos as well. From BDMV folders you get the choice between BD-lite or full playback with menus. BD-lite is not available for isos.
trondmm is offline
post #16 of 47 Old 07-18-2012, 08:47 PM
Jon Spackman's Avatar
What are you talking about that bd-lite doesnt work from ISO?
You are very incorrect. I have all my movis as bd iso and use bd lite daily.
Its nice because with bd-lite you can zoom the image if you are worried about burn in on the little guys 2.35:1 movie viewing. smile.gif
Just enjoy HD in whatever form you can (Sat, Cable, D-VHS, OTA, HD DVD, or BD).
Jon Spackman is offline
post #17 of 47 Old 07-19-2012, 04:06 PM
trondmm's Avatar
That's weird. Here's how my Dune behaves:
As you can see, here are two BD folders and one BD iso image
If I hit Pop-up menu on the image, I get this menu:
On a Blu-ray folder, I get this menu:
I've got a HD Base 3, with the latest beta firmware.
trondmm is offline
post #18 of 47 Old 07-19-2012, 04:50 PM
trondmm's Avatar
Oh. Hang on...
If I change the option in Setup > Miscellaneous > File Browser to "Play (lite)" or "Ask user", it applies to both folders and images. So, it's just the pop-up menu in the file browser that's broken for images.
trondmm is offline
post #19 of 47 Old 07-19-2012, 06:20 PM
That makes sense. I play all mine thru my movies and only get a popup thats asks for play or play bd lite
Jon
post #20 of 47 Old 07-19-2012, 09:11 PM
rdgrimes's Avatar
Quoted: 1993 Post(s)
Liked: 1321
Can't say for sure about the Base 3, but if I hit "play" on an ISO it plays like a disc. If I hit "enter" it offers the drop down which includes "play" and "play lite". And yes that behavior is set up in options.
rdgrimes is online now
post #21 of 47 Old 07-20-2012, 12:40 AM
pmcd's Avatar
Quoted: 13 Post(s)
Even if you find one then it will probably have a Blu-ray license. If that's the case you will have to deal with issues other than the menu.
philip
pmcd is offline
post #22 of 47 Old 07-20-2012, 05:14 AM
trondmm's Avatar
Yes. Play button will always play it like it was a disc. Enter depends on the config, if it's set to "play", "play lite" or "ask user". I had mine set to "play", since that's what I generally want, and I thought I could select "play lite" from the popup-menu.
trondmm is offline
post #23 of 47 Old 07-20-2012, 06:22 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
I guess that you can't select "play lite" with iso from the popup menu, simply because ISO is not a BR extension (it can be a dvd or whatever, that's just a container). To know that your iso is a BR, the dune needs to "mount" it, and this is done only when play is pressed on your remote wink.gif
Mr Eric is offline
post #24 of 47 Old 08-01-2012, 02:10 AM - Thread Starter
hey guys something is worrying me .I purchased the dune player but i'm afraid its gonna have the same problem with wdtv live.That is when playing video files its gonna not have the right picture adjustment.On wdtv live when playing a video file for mkv the video would over lap the screen and when you zoom into 0.9 the full picture would come on but the screen would not be filled.is that gonna be the same with this?
post #25 of 47 Old 08-01-2012, 04:35 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
I don't think that zooming impacts the dune's autoframerate. I don't think as well that a mkv should overlap your screen unless you have a huge overscan which can be corrected most of the time by using your tv 1:1 or truepixel (naming depends on the brand) mode. If the mkv is overlapping it's not a problem from the player but from your tv.
Mr Eric is offline
post #26 of 47 Old 08-01-2012, 11:22 AM - Thread Starter
Does the dune auto detect the correct resolution and aspect ratio of the files if they are mkv?I'm assuming it does for dvd-iso and blu ray but what about mkv
post #27 of 47 Old 08-01-2012, 12:44 PM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
There's no need for that. Once you setup the dune to output 1080p and 16:9 screen you can throw everything you want and it will be correctly displayed. But there won't be any miracle an if your mkv are badly encoded (4:3 picture in a 720p resolution for example) it won't turn magically in a beautiful widescreen movie...
Mr Eric is offline
post #28 of 47 Old 08-07-2012, 11:02 PM - Thread Starter
quite frustrated guys.got the dune player today and every single full blu ray i play i get an playback due to i/o error and i cannot play them.I only bought the dune player for this reason only and i cannot play back files.I;m downloading latest firmware to hope it solves it but have no idea.this is very frustrating this was more than i wanted oto pay and cant even get it work for blu ray files
post #29 of 47 Old 08-08-2012, 01:01 AM
Tiddles88's Avatar
Liked: 24
Post a mediainfo snip of the .iso in question.
Tiddles88 is offline
post #30 of 47 Old 08-08-2012, 01:12 AM - Thread Starter
Ok so the problem appears to be any hard drive over 2 tb. My samsung 2 tb hard drive played all the blu ray rips fine but my seagate and wd drives 3 tb hard drives would not play the blu ray rips.I would get playback aborted due to i/o error on seagate and some would say disc cannot be read and freeze on the wd or the same i/o error.. Is this a known issue with the dune player for playback of blu ray files on a 2.5 or 3 tb hd?
http://www.mpcclub.com/forum/archive/index.php/t-26239.html talks about the error in there.Looks like I would have to only use 2 tb hard drives for blu ray files and to a F ton of re organizing between my external hard drives how frustrating.Anything i can do other than this?
