Help me pick a new router, please !! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-17-2012, 09:18 PM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
It appears our D-Link DIR-655 router just bit the dust, and I need a new one ASAP. It only lasted 1.5 years, which is ridiculous, so I'd like to avoid D-Link. I need a router that will work excellent with Netflix HD streaming(wired connection). The only wireless uses are for 2 laptops in the house. What models do you guys recommend? I was told Linksys are very good. About $80 max would be nice. Thanks.
Jim McC is offline
post #2 of 11 Old 07-17-2012, 09:49 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Netgear, ASUS, Linksys.
I used to use a Netgear WNDR3700, which lasted 2 years. Then I stopped using it because it interfered with my U-Verse RG box.
GusGus748s is offline
post #3 of 11 Old 07-18-2012, 12:31 AM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Thanks Gus. Based on our usage(wired HD streaming) and wireless to 1 or 2 laptops, what features/speed do I need? I don't want to overspend, but I don't want a piece of junk either.
Jim McC is offline
post #4 of 11 Old 07-18-2012, 01:13 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
The ATT RG box that I am using is rated 100 MB/s wired, and the wireless is G rated one. I use the wireless for my laptop, tables and smart phones. The G rated speed works fine with my set up. I also stream movies from my UnRaid server, but everything is connected to a gigabit switch. The RG box is connected to my 8 port gigabit switch to provide internet to my devices that need it.
That being said, I would recommend pretty much any gigabit router. All of them should support a/g/n wireless connection. You can give the on from www.monoprice.com. I believe it cost about $30 dollars, and it works just as well as the ones that cost 3 times as much. I've seen the Netgear WNDR3700 as low as $80 dollars.
One router I was thinking of buying to replace my WNDR3700 was the Asus ASRTN56U. However, this one cost a little over $100 dollars.
post #5 of 11 Old 07-18-2012, 02:34 AM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Thanks. So I should get a gigabit router, since I'm streaming HD movies? I'm thinking of the Netgear 3700. Is it easy to set up? I know very little about computers.
Jim McC is offline
post #6 of 11 Old 07-18-2012, 02:40 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Its pretty simple. If you've got questions just call their support department. As long as your router is under warranty the will help you out. The only thing you will need to do is to secure your wireless network, which is pretty simple to do.
post #7 of 11 Old 07-18-2012, 02:49 AM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Sounds good. I just read something on Netgear's website that has me confused. Under "System Requirements" it says "Wireless Adapter or Ethernet Adapter and cable for each computer". It also says to use a wireless dual band wireless adapter. Are these extra things I have to buy?
Jim McC is offline
post #8 of 11 Old 07-18-2012, 05:37 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
That just means that every device you want to connect must be wireless capable.
Netgear is a great router, I own two of them and neither has ever failed me, or given me problems.
Denon X3100W
Klipsch RB-61 II (Fronts), Klipsch RC-52 II (Center)
Deftech StudioMonitor 350 (surrounds)
Klipsch SW-115 (sub)
LG 50LB5900
TiVo Roamio
jpcamaro70 is offline
post #9 of 11 Old 07-18-2012, 11:15 AM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Thanks. And what about where they say "Use with an N600 wireless dual band USB adapter"? Is that something I might have to buy? I just want to make sure before I buy the 3700.
Jim McC is offline
post #10 of 11 Old 07-18-2012, 02:14 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
You don't need to buy anything. Your devices will either have a 2.4hz or 5.0hz (spelling) capabilities. So, you can set up the dual band option. If non of your devices have the 5.0 capabilities, I wouldn't bother setting it up, and just use the 2.4.
post #11 of 11 Old 07-18-2012, 03:26 PM - Thread Starter
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Thanks guys. I picked up the Netgear 3700 today and it's working great. Luckily my daughter was around to set it up.
Jim McC is offline
