PS3 Media Server Setup Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-24-2012, 11:24 PM - Thread Starter
erick15's Avatar
I'm looking to set up a media server in my dorm this coming year. Just trying to figure out how to do it at the moment. I am wondering would this setup work and be able to stream 1080p and 5.1?
Ps3 wired to airport express, this can be done correct? If not would it work if I wired the ps3 into the outlet on the wall (the university network) or should I just run the ps3 on wireless.
Airport express wired into university network
Macbook Pro on airport express wireless network
Macbook Pro running PS3 Media Server for Mac
External Harddrive file holding movie files connect to Macbook pro
Just so that you know I want to use an airport express for the airplay ability so that I can easily stream music from my mac to my sound system. Also the university does not allow you to have wireless routers, still not sure if they will find out about it if I use one. I know I can hide the network but I'm not sure how strict they are on it. I know that they require you to register your mac address of computer to your ethernet port, will this be a problem using a wireless router?
Pretty confused as to how to do this, after searching a bit this is what I have come up with. Any suggestions are appreciated.
erick15 is offline
post #2 of 5 Old 07-25-2012, 08:28 PM
Scarpad's Avatar
Quoted: 71 Post(s)
Liked: 40
Run Plex Media Server Instead of PS3 Media Server, on the Macbook, the PS3 will detect it and stream flawlessly, i've been using this setup for a good while now.
Scarpad is offline
post #3 of 5 Old 07-28-2012, 02:11 PM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
Do they have plex for windows too? Is it free and more stable than tvetsity and ps3 media player
zoro is offline
post #4 of 5 Old 07-28-2012, 03:59 PM
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
Yes, Plex works with windows too.
GusGus748s is offline
post #5 of 5 Old 07-29-2012, 12:17 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
whats the diff between media center and media server?
zoro is offline
