Netgear 550 Replacement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-28-2012, 03:10 PM - Thread Starter
Av8tr's Avatar
I've been using it for almost a year and its worked flawlessly for streaming BD iso's. That's all all I need, but lately I've been having to unplug and replug along with other annoying fixes.
I'd like something that works a little better overall. any suggestions?
Av8tr is offline
post #2 of 10 Old 07-28-2012, 03:46 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Dune, PCH, Micca with realtek 1186 chip. 1185 chip cant do full bd iso menus.
GusGus748s is offline
post #3 of 10 Old 07-28-2012, 09:39 PM
Opentoe's Avatar
Quoted: 87 Post(s)
Just buy another one or re-flash the firmware maybe? There is no reason at all to buy a new players these days, except if you want 3D. If you don't want 3d, you can buy 4 year old technology and it would work fine. I still use a 3-4 year old Dune Prime 3.0. And to this day there still isn't much out there that is better then that. The media player "boom" we had a few years ago just died out. Everyone thinks Netflix is the best and could care less about accessing their own content anymore. Us die hards out there that want to access our servers still want such products, but there just isn't any good stuff out there anymore.
Opentoe is offline
post #4 of 10 Old 08-05-2012, 03:08 PM - Thread Starter
Av8tr's Avatar
Great answer. Thanks. I haven't been paying much attention to since my system has been running so well this long. Usually in the world of elecronics there would be something much better by now.
I do have a lot of 3d BDs that would be fun to stream, but I can still make discs and play then on my ps3 unless they Cinavia protection.
Av8tr is offline
post #5 of 10 Old 03-23-2013, 11:52 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Does this has been updated to do netflix
zoro is offline
post #6 of 10 Old 03-23-2013, 12:25 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Netgear NeoTV550 has been discontinued and will never have netflix since it isn't supported by netgear anymore. They had one last FW update.
post #7 of 10 Old 03-23-2013, 12:50 PM
comicguy's Avatar
as has been stated in the past...NO MORE UPDATE EVER FOR THE NEOTV 550. It is EOL and that is that...
comicguy is offline
post #8 of 10 Old 03-23-2013, 06:45 PM
thetoad's Avatar
what we need to do is lobby netgear to enable us to unlock the firmware and replace bits from their last firmware.
i.e. if we would replace the kernel, we would be able to easily get GPT support. For the case of the device wedging itself, we could easily install a watchdog process that could reboot it regularly (or even simply overnight).
I don't see much reason why netgear would not want us to be able to do that at this point.
thetoad is offline
post #9 of 10 Old 01-08-2015, 12:33 AM
IanD's Avatar
Quoted: 82 Post(s)
Liked: 50
Originally Posted by thetoad View Post
what we need to do is lobby netgear to enable us to unlock the firmware and replace bits from their last firmware.<br><br>
i.e. if we would replace the kernel, we would be able to easily get GPT support. For the case of the device wedging itself, we could easily install a watchdog process that could reboot it regularly (or even simply overnight).<br><br>
Not sure if it has been mentioned elsewhere in NTV550 related threads but up until this point I believed the NTV550 would only play Bluray with menus if the Bluray is in ISO form. However, recently I discovered that the NTV550 will also play Bluray with menus if you launch the index.bdmv file from a Bluray folder structure (on an attached external HDD).
I don't stream files (which is probably the main use of an ISO) but I needed a backup to my Oppo 93 which can't handle ISO: both the Oppo 93 and NTV550 will play Bluray with menus from Bluray folder structure on HDD.
IanD is offline
post #10 of 10 Old 01-08-2015, 09:52 AM
thetoad's Avatar
yes, the ntv550 actually mounts the iso internally in linux and then plays it it as if it was a bdmv file system. This is opposed to the dune whose player itself understand the udf/iso file system but sometimes has problems (i.e. the same movie sometimes has problems for me if in ISO but works fine if i mount it on my linux file server and play it as a file system)
thetoad is offline
Netgear Ntv550
