WiFI Tv's Streaming with a smart phone ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-03-2012, 06:39 AM - Thread Starter
panzer's Avatar
Quoted: 24 Post(s)
I am looking for a way to stream netflix, blockbuster etc to a led tv with built in wifi without the internet and computer or router, I was told by a salesman that this is possible by using certain smartphones with a hot spot, could anyone elaborate on ths as I am a novice in this area, my goal is to eliminate my home computer and internet and use a smart phone instead, thanks
panzer is offline
post #2 of 4 Old 08-03-2012, 06:46 AM
gregzoll's Avatar
Liked: 33
I wouldn't do it. Your data speeds are too slow for a decent picture to a large screen device.
gregzoll is offline
post #3 of 4 Old 08-03-2012, 08:12 AM
Beerstalker's Avatar
Liked: 24
Certain cell phones have a WiFi hotspot feature, where they can act as a wireless router to allow other WiFi devices to use their cellular connection to the internet.
What cell phone do you have?
The big problem is going to be the speed of the network, and data caps. If you have a LTE phone with good LTE service in your home you might be able to do this and get a decent picture. That is where the bigger issue comes into play though. You most likely have a data cap for how much data your phone can use in a month, and streaming movies to your TV is going to take up a huge amount of data. You will likely go over your cap and cause huge overage charges on your cell phone bill, or if you have an older unlimited plan you will probably end up getting the speed throttled down to near dial up speeds.
If you really want to stream Netflix, BLockbuster, etc you most likely are much better off keeping your home internet service.
Beerstalker is offline
post #4 of 4 Old 08-03-2012, 12:20 PM - Thread Starter
panzer's Avatar
Quoted: 24 Post(s)
thanks for info
panzer is offline
