complex networking setup please help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-09-2012, 03:37 PM - Thread Starter
vorlen's Avatar
I am moving into a new 2 story house I am having built in a few weeks that has cat 6 installed in every room and I need some guidance. I would like to have my Comcast cable modem share internet with all 5 rooms plus have those rooms be able to talk to one another. What is the best way to do this?
So reading other threads it looks like I would plug the cable modem into a router and then plug the router in to a switch. Then I can buy additional switches for the rooms with multiple devices? The layout is shown below.
Room 1 apple tv, directv box, Xbox 360 and PS3 5 port gigabit switch (1 for wall 4 for devices)
Room 2 apple tv and directv box 5 port gigabit switch (1 for wall 2 for devices)
Room 3 apple tv and directv box 5 port gigabit switch (1 for wall 2 for devices)
Room 4 apple tv and directv box 5 port gigabit switch (1 for wall 2 for devices)
Room 5 Computer (this is where all the files are held)
Junction box has all 5 rooms leading to it and is where I would hook up the modem into the router and then the router into a gigabit switch.
Does that sound about right?
vorlen is offline
post #2 of 4 Old 08-09-2012, 11:50 PM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
Sounds about right.
GusGus748s is offline
post #3 of 4 Old 08-12-2012, 12:33 PM
bgavin's Avatar
I assume you have a LAN wiring closet defined, where all rooms pull their cables to a common location.
This is the location for the top level switch. Power is required here.
The modem and router can be located together at the cable MPOE which can be elsewhere.
A single drop from the MPOE location to the wiring closet is required for the router private side connection.
A switch in every room will not violate the Ethernet 3-2-1 rule. No worries there.
I doubt the house is large enough to violate the 185 meter end-to-end length rule, either.
Traffic between rooms will switch across the backplane of the top level switch (in the closet).
Traffic bound for the Internet will hop to the router, modem and beyond.
With CAT6 wiring, you can run GB Ethernet at full duplex.
Are you pulling phone cables to the rooms also?
bgavin is offline
post #4 of 4 Old 08-14-2012, 12:40 PM - Thread Starter
vorlen's Avatar
I wont be running phone just ethernet. Thanks for the detailed response.
vorlen is offline
