Need help choosing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-21-2012, 03:06 PM - Thread Starter
anam8tr's Avatar
Hey everyone.
So I'm looking for a media CENTER more than a server. Like a stand alone box that I can plug a HD into and play my BD backups (some are cinavia protected), dvd backups and some avi files. So far I've backed up the entire BD disk on HD, but unsure if the media players will play the folder or I need to extract to ISO. Been reading about full menus and ISO's but I'm getting pretty confused on which player did what.
Don' t really need the server side, not streaming from a computer. Just would like to plug an external HD and go. Netflix is done on the PS3.
I've been playing with backing up Bd's lately and of course run into the cinavia problem with the PS3. Thought about going with a stand alone BD player (sony 550) which is cinavia free right now, but at some point Sony will update there firmware to enable cinavia.
Read on the WD Live forums that someone posted WD's firmware just incorporated cinavia, not sure if this is true or not.
I do like WD, only because it's cheap at $70. Not looking to spend a fortune if possible. However, I would like a quality picture with HD audio.
Right now I'm Ps3 > DVDO Duo > Denon 887
Any suggestions,
Thanks very much !!!!
anam8tr is offline
post #2 of 9 Old 08-21-2012, 09:35 PM
streamerlover's Avatar
Originally Posted by anam8tr View Post
Hey everyone.
Any suggestions,
a dune or popcorn hour will do what you want...
streamerlover is offline
post #3 of 9 Old 08-22-2012, 06:28 AM
stepmback's Avatar
Hey everyone.
Any suggestions,
I believe the WD has issues with HD audio, someone correct me if I am wrong. Also the WD will not play BD ISO.
Based on what you described as your needs, I would go with a PCH or Dune box. I have a PCH A-210 and really liked it. Took some time to get setup correctly but once done, very solid and played everything. One thing of note is I belive the PCH box do not support full BD menues. I have read the Dune boxes do.
stepmback is offline
post #4 of 9 Old 08-22-2012, 07:52 AM - Thread Starter
anam8tr's Avatar
Thanks guys, appreciate it.....
anam8tr is offline
post #5 of 9 Old 08-22-2012, 08:41 AM
The pch a210 and c200 as well as the a300 support full Blu ray menus..:
post #6 of 9 Old 08-22-2012, 09:22 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1146
Untrue
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #7 of 9 Old 08-23-2012, 07:39 AM - Thread Starter
anam8tr's Avatar
Guys, have a newbie question again.
The A series and C series of PCH have there differences, one is confusing to me, BD licenses. The C has it while the A does not. What exactly does that mean when playing backups? Or is this because the C can add a bd drive and the A can not? Also, if DTS or True HD audio sometimes has problem with the A series (dropouts or not playing), can the A (or C for that matter) downmix for you (5.1 or 2 ch) or you have to mux on a pc? Thanks guys......
Not sure if the A is the way to go, been reading up on it. Seems like the C is way more stable and has the usb expansion ports. Both are the same price, used.
anam8tr is offline
post #8 of 9 Old 08-23-2012, 09:57 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
With the C, you can add a BD/DVD drive, but they can both play ripped BD full menus. However, the 300 series does have audio drop outs. I used to own a PCH-A300, and I returned it due to the audio drops. I never have had any audio drops with my A210 though. Furthermore, they can downmix the audio as well.
GusGus748s is online now
post #9 of 9 Old 08-23-2012, 01:04 PM - Thread Starter
anam8tr's Avatar
Thanks !!!
anam8tr is offline
