POPCORN HOUR A-400 is coming soon - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #541 of 2382 Old 11-29-2012, 07:17 AM
tboggie's Avatar
Originally Posted by cadett View Post
The local hard drive in the media player is installed with the apps on it, however after configuring the workgroup to my network & trying to view the media player in my local network on my pc, it asked for user/pass.
Did you try Username : NMT Password:1234
You could also try using FileZilla to transfer your files
Host: IP Address of your device
Port: 21
Username: nmt
Password: 1234
tboggie is offline
post #542 of 2382 Old 11-29-2012, 07:31 AM
cadett's Avatar
Quoted: 45 Post(s)
Liked: 102
Thanks guys. That will do the trick,
cadett is offline
post #543 of 2382 Old 11-29-2012, 07:34 AM
robnix's Avatar
Quoted: 768 Post(s)
Liked: 563
Originally Posted by Rui Pedro View Post
What kind of subs? pgs? srt? are they a forced sub track or the default one? It's important to specify. The issue is when subs are turned off, forced pgs subs in mkv, m2ts, and iso files don't appear like they should.
Originally Posted by Ph8te View Post
I would guess mkv, since that is the file type he mentioned right before he made that statement.....
Bitrate and codec information would be helpful, I should post these as well which I will later today. Right now all the files I've tested have been either 1:1 iso files, the m2ts file from the main movie, or MKV files with the main movie, the default audio tracks, and the english sub tracks. No remuxing has been done to compress and save space. All the files I've seen posted here are as much as the third the size and bitrate of the originals. For example, here's an MKV of "The Avengers" should look like;
Code:
General
UniqueID/String                          : 120435530299511773810744472871221522249 (0x5A9B0A173EDADFA7E1B656F87C9AEF49)
CompleteName                             : V:\Movies\Movies\The Avengers\The Avengers.mkv
Format                                   : Matroska
Format_Version                           : Version 2
FileSize/String                          : 30.3 GiB
Duration/String                          : 2h 22mn
OverallBitRate_Mode/String               : Variable
OverallBitRate/String                    : 30.4 Mbps
Movie                                    : Marvel's The Avengers
Encoded_Date                             : UTC 2012-10-09 02:08:19
Encoded_Application                      : MakeMKV v1.7.7 win(x64-release)
Encoded_Library/String                   : libmakemkv v1.7.7 (1.2.0/1.1.0) win(x64-release)
Video
ID/String                                : 1
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format_Profile                           : High@L4.1
Format_Settings_CABAC/String             : Yes
Format_Settings_RefFrames/String         : 4 frames
CodecID                                  : V_MPEG4/ISO/AVC
BitRate_Maximum/String                   : 32.0 Mbps
Width/String                             : 1 920 pixels
Height/String                            : 1 080 pixels
DisplayAspectRatio/String                : 16:9
FrameRate_Mode/String                    : Constant
FrameRate/String                         : 23.976 fps
ColorSpace                               : YUV
ChromaSubsampling                        : 4:2:0
BitDepth/String                          : 8 bits
ScanType/String                          : Progressive
Language/String                          : English
Default/String                           : No
Forced/String                            : No
Audio #1
ID/String                                : 2
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format_Profile                           : MA / Core
Format_Settings_Mode                     : 16
Format_Settings_Endianness               : Big
CodecID                                  : A_DTS
BitRate/String                           : Unknown / 1 509 Kbps
Channel(s)/String                        : 8 channels / 6 channels
ChannelPositions                         : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
SamplingRate/String                      : 48.0 KHz
BitDepth/String                          : 24 bits
Compression_Mode/String                  : Lossless / Lossy
Title                                    : Lossless
Default/String                           : Yes
Forced/String                            : No
Audio #2
ID/String                                : 3
Format                                   : DTS
CodecID                                  : A_DTS
BitRate_Mode/String                      : Constant
BitRate/String                           : 1 509 Kbps
Channel(s)/String                        : 6 channels
ChannelPositions                         : Front: L C R, Side: L R, LFE
Compression_Mode/String                  : Lossy
StreamSize/String                        : 1.51 GiB (5%)
Title                                    : 3/2+1
Default/String                           : No
Forced/String                            : No
Text #1
ID/String                                : 4
Format                                   : PGS
CodecID                                  : S_HDMV/PGS
CodecID/Info                             : The same subtitle format used on BDs/HD-DVDs
Forced/String                            : No
Text #2
ID/String                                : 6
Format                                   : PGS
Default/String                           : No
Forced/String                            : No
Text #3
ID/String                                : 8
Format                                   : PGS
Default/String                           : No
Forced/String                            : No
Menu
00:00:00.000                             : en:Chapter 00
00:08:02.315                             : en:Chapter 01
00:11:49.166                             : en:Chapter 02
00:15:18.751                             : en:Chapter 03
00:20:33.482                             : en:Chapter 04
00:23:04.257                             : en:Chapter 05
00:29:39.444                             : en:Chapter 06
00:37:23.991                             : en:Chapter 07
00:42:47.982                             : en:Chapter 08
00:50:22.269                             : en:Chapter 09
01:01:04.661                             : en:Chapter 10
01:14:05.107                             : en:Chapter 11
01:28:01.234                             : en:Chapter 12
01:38:20.561                             : en:Chapter 13
01:45:40.167                             : en:Chapter 14
01:51:15.085                             : en:Chapter 15
01:57:47.769                             : en:Chapter 16
02:04:38.679                             : en:Chapter 17
02:09:39.396                             : en:Chapter 18
02:13:10.691                             : en:Chapter 19
Looky here!
robnix is offline
post #544 of 2382 Old 11-29-2012, 07:34 AM
jac601's Avatar
Agreed from a quick look at it, the video may be compressed not to mention no HD audio (looks like a 1.5k DTS track.....
Thanks I figured you guys must have been dealing with better quality files....although I definitely can't complain about the quality of the compressed video.
jac601 is offline
post #545 of 2382 Old 11-29-2012, 07:46 AM
Rui Pedro's Avatar
Code:
General
Format                                   : Matroska
Video
ID/String                                : 1
Format                                   : AVC
ColorSpace                               : YUV
Default/String                           : No
Forced/String                            : No
Audio #1
ID/String                                : 2
Format                                   : DTS
CodecID                                  : A_DTS
Title                                    : Lossless
Forced/String                            : No
Audio #2
ID/String                                : 3
Format                                   : DTS
CodecID                                  : A_DTS
Title                                    : 3/2+1
Default/String                           : No
Forced/String                            : No
Text #1
ID/String                                : 4
Format                                   : PGS
Forced/String                            : No
Text #2
ID/String                                : 6
Format                                   : PGS
Default/String                           : No
Forced/String                            : No
Text #3
ID/String                                : 8
Format                                   : PGS
Default/String                           : No
Forced/String                            : No
Menu
Hi mate,the subtitles are SRT files alltimes,now ive tested two diferent MKVS,2012 movie and IRONMAN 1/2 both 1080p+DTS,i can make a movie of it also.
Cheers
Rui Pedro is offline
post #546 of 2382 Old 11-29-2012, 07:48 AM
robnix's Avatar
Quoted: 768 Post(s)
Liked: 563
So the main movie for Rango is split into several files which makes remuxing super fast. Already found some interesting things. Have to go but will do some more testing later this afternoon and post the results.
Looky here!
robnix is offline
post #547 of 2382 Old 11-29-2012, 08:15 AM
UHD Addict
aaronwt's Avatar
Quoted: 6416 Post(s)
Liked: 3965
Is there a way to acess my popcorn hour a-400 from my pc ? i mean browse hdd content and organize it?
Yes you can access the internal storage of the A-400 over the network. I was using a Win8 PC to accesss mine.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #548 of 2382 Old 11-29-2012, 08:19 AM
UHD Addict
aaronwt's Avatar
Liked: 3965
I played around 30 minutes of my Avengers BD ISO last night, the big battle during the last part of the movie. It played the full BD ISO fine.
I had tried the Avengers 3D BD ISO in 2D and it seemed to play that ok, but I only tried a couple of minutes. My C200 and my Boxee Boxes can't play the 3D BD ISO in 2D mode without issues.
aaronwt is offline
post #549 of 2382 Old 11-29-2012, 08:40 AM
Rui Pedro's Avatar
So i have a USB HDD conected to my popcorn,how can i acess it in my win7 pc?
post #550 of 2382 Old 11-29-2012, 08:59 AM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
This is how it works, Is the usb drive formated NTFS? or did the popcorn hour format it. If its NTFS you need to use an sd card or usb stick or internal drive, I suggest unplugging the usb drive so you dont mix it up, Once plugged in go under setup then maintenance you will see an option the says install NMT apps click that, let it format your usb/sd/internal whatever you picked and it will install apps, When its done plug in your usb drive and reboot. After that you can access the usb from a PC by using ftp using the ip address of the pch or by using samba it will display in your windows network,
halfelite is offline
post #551 of 2382 Old 11-29-2012, 09:00 AM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
Code:
General
Format                                   : Matroska
Video
ID/String                                : 1
Format                                   : AVC
ColorSpace                               : YUV
Default/String                           : No
Forced/String                            : No
Audio #1
ID/String                                : 2
Format                                   : DTS
CodecID                                  : A_DTS
Title                                    : Lossless
Forced/String                            : No
Audio #2
ID/String                                : 3
Format                                   : DTS
CodecID                                  : A_DTS
Title                                    : 3/2+1
Default/String                           : No
Forced/String                            : No
Text #1
ID/String                                : 4
Format                                   : PGS
Forced/String                            : No
Text #2
ID/String                                : 6
Format                                   : PGS
Default/String                           : No
Forced/String                            : No
Text #3
ID/String                                : 8
Format                                   : PGS
Default/String                           : No
Forced/String                            : No
Menu
In your sample you posted None of the tracks are tagged as forced. For a forced track to work from MKV it has to specifically contain the forced track flag. Think that was just your bit rate example, MKV forced should work for sure. as for single m2ts if you use clownbd make sure forced subtitle box is ticked at all times. If you set clownbd to to recognize forced it creates a new subtitle track while keeping the old and does not work if my memory serves me. As for ISO That one I dont know I dont run ISO files
post #552 of 2382 Old 11-29-2012, 09:16 AM
Rui Pedro's Avatar
My HDD is formated in win7 NTFS so i guess it wont work then..
post #553 of 2382 Old 11-29-2012, 09:18 AM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
It will still work you just need to use an SD card, or USB stock to install NMT apps to the sdcard or usb stick. Think of it like a PC, the sd card or usb stick will be the OS drive, and the usb drive is just a plain usb drive. You have to install the OS to one of the drives since your USB is NTFS and full of information we dont want to use that drive so you need another option, a 4+gb usb stick or 4+gb sd card will work fine. once you install the apps "os" to the usb/card you can access the ntfs usb over the network then.
post #554 of 2382 Old 11-29-2012, 09:50 AM
robnix's Avatar
Quoted: 768 Post(s)
Liked: 563
Correct, that was to show that people posting remuxed and compressed mkvs that run at a third the bitrate of the original doesn't help anyone. When I get home later I'll post what I've found by messing around with my rango test file. What i saw this morning was interesting. I just ran out of time
Makemkv doesn't mark any forced sub tracks with the forced flag, so i fix that manually. Avatar and district 9 are good examples where this needs to be done.
Any m2ts files I've tested have been copied straight off the bluray. No remuxing with clownbd, and the ISOs i have are 1:1 copies, no remuxing there either. Forced subs do not work in either.
Looky here!
robnix is offline
post #555 of 2382 Old 11-29-2012, 10:18 AM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
makemkv has some issues and not fault of the player, You can read about it in this thread http://www.makemkv.com/forum2/viewtopic.php?f=8&t=4969&start=60 each movie has a different work around it seems, But has you noticed using mkvmerge to manually set force flag for the track works,
As for your m2ts file that is correct behavior i think, m2ts by default has no header information saying subtitles need to be forced if they are present, again correct me if im wrong, But if you want them to be you have to use clowndb to rip out the single m2ts and it will add the header information for the forced subtitle track, again correct me if im wrong but this is my understanding of the m2ts file. As for the 1:1 iso file I think it will depend on the movie, There is 3+ different ways for a bluray to select a forced track and one of them is when you pop in a disc and choose a language right when it starts is what flags the forced track, But since the A400 only has bdlite that menu is now skipped so 1:1 might take some work to get forced tracks working and again might not always work. then to top it off there is multiple ways to do a forced subtitle track it can be its own track it can be a inside the language track with the lines flagged as forced.
post #556 of 2382 Old 11-29-2012, 01:42 PM
robnix's Avatar
Quoted: 768 Post(s)
Liked: 563
Movies with forced subs thread:
http://www.avsforum.com/t/1176923/movies-with-forced-subtitles
Spreadsheet:
https://spreadsheets.google.com/pub?key=t8Xb85eyNFtZ3vaNK8gqkbQ&single=true&gid=0&output=html
I use the Header Editor after I rip my discs to do one of the following:
a) If an English language film has forced subs I figure out what track it is by either the spreadsheet, the thread, or just watching the part of the movie where they appear until I get the right track.
b) for convenience, I set the main sub track on ALL foreign language films to forced.
This let's me completely turn subs off and have the right sub track appear regardless of the movie. Adds to the WAF as well. It works peaches with XBMC, our Boxee, and it worked with the A300.
This is interesting and explains a lot, especially how Bluray players know which sub track to play. I have a friend that used to master DVD's and Blurays for a living, I'm going to follow up with him on this.
Looky here!
robnix is offline
post #557 of 2382 Old 11-29-2012, 01:50 PM
Wryker's Avatar
Quoted: 136 Post(s)
Liked: 62
Once you have the apps installed on either an SD card or, as I did since i have a class 10SD card that won't work with it yet, use a usb thumbdrive in the side USB port to install them and then go to your PC: and add a network drive. OR, if you're using Win7 simply open up your computer and in the right hand side you'll see the A400: click the 'carrot/arrow' and it'll auto show you the drives connected to your A400.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #558 of 2382 Old 11-29-2012, 02:20 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
@dvzzz (and all others):
Any of you guys with dedicated Video Processors (or a good ones in your AV Receivers) are doing comparisons between A-400 VXP and their video procs.
I have actively in my setup: a CII (VXP), Radiance XE (VXP), Optoma HD3000 (VXP) and a DVDO VP50Pro. So I definitely know how VXP processing is supposed to look like. All of these are connected to a HDMI matrix, so I can easily switch every source to every processor and even chain them up. When I first posted my review for the A-400 (about 10 days ago, before you guys got yours) I did a cross check with every one of those processors. Eventually I only compared the A-400 to my Dune (Smart), because the Dune on it's own is weaker than any of the VPs above (with an Oppo as a player) and still the A-400 can't even reach the Dune's quality.
I know that for most people 1080p playback, maybe even in 3D, is the only important point, but then again, what do you need a VXP processor for if you don't need any scaling or deinterlacing ? I updated the two recent firmwares, but in terms of PQ nothing changed. I returned the A-400 for a refund this week.
What I wrote earlier stands: the Dune Smart has better PQ whenever scaling is involved. The VXP's (video-only) deinterlacing for 480i and 1080i isn't bad, but paired with the blurry scaling, it's not worth using it. A good DVD rip played on the Oppo and processed by one of the "real" VXP machines looks tremendously good, no matter if it's video or film. A good movie DVD image played on a Dune Smart still looks good (while video-based DVDs look very sub-par), but any SD material played on the A-400 looks just mediocre, much like played on a $50 DVD player from 7 years back.
If they can work out the issues and deliver real unleashed VXP video quality on the A-400, I'll go straight out and rebuy one....
Fudoh is offline
post #559 of 2382 Old 11-29-2012, 02:26 PM
UHD Addict
aaronwt's Avatar
Liked: 3965
One of the first things I did was turn off any VXP processing. It's extremely rare that I will watch a DVD ISO. Most of what I watch is from BD ISOs and is in 1080P24. Plus I'm using a DVDO DUO and a Darbee Darblet in the mix.
aaronwt is offline
post #560 of 2382 Old 11-29-2012, 02:43 PM
robnix's Avatar
Quoted: 768 Post(s)
Liked: 563
I used 01012.m2ts off my Rango bluray. This is the track that has the opening title and the first few minutes of the movie. My stuttering always started as soon as the main "R A N G O" title turns toward the viewer and the owls start singing the theme. I remuxed the orginal m2ts so I had the original and a copy that defaulted the the DD track instead of the DTS-HD I then remuxed both files into MKV files without changing any of the defaults.
01012.m2ts - Video plays fine, audio starts dropping then normalizing as soon as the owls sing.
01012-ac3.m2ts - Video and audio play fine.
01012.mkv - Video plays fine, audio starts dropping then normalizing as soon as the owls sing.
01012-ac3.mkv - Video and audio play fine.
Later I'll remux Batman Begins so the TRUE-HD track is the default track, the DD track is #1 which the A400 defaults to. I'll test The Avengers for both forced pgs subs and audio.
I'll post the relevant info from Mediainfo later.
MKV with pgs forced subs - fixed this one. Changed the settings I had for the sub track so Default, Track Enabled, and Forced display were all set to YES. The forced subs show with the proper font and position. Didn't try Avatar yet.
Looky here!
robnix is offline
post #561 of 2382 Old 11-29-2012, 02:50 PM
robnix's Avatar
Quoted: 768 Post(s)
Liked: 563
Spreadsheet:
So I found out it's pretty simple how it works with bluray players. There's a discrete sub track that contains the forced subs. It defaults to ON based on the default language set in the player. The flag to show the sub is in the timecode of the sub stream. Java and the BR menu have nothing to do with this, it's all based on the player defaults.
Looky here!
robnix is offline
post #562 of 2382 Old 11-29-2012, 03:03 PM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
That is one way. Movies like kill bill do it that way. a lot of the Regions that cross in EU do it by the BDJ prompt in the front of the movie trying to think of the most recent I saw it on And not all tracks are the same, if its one track its easy, but some movies the full english track is there but bits are marked as forced .trying to think of the movie titles to see if you have any so you can see it, drawing a blank at work right now though
The Star Wars Blu-rays Except for Episode V have the forced subs mixed inside the English track and just flagged its not a full discreet track of its own.
post #563 of 2382 Old 11-29-2012, 03:48 PM
martig's Avatar
Quoted: 23 Post(s)
How do you think this docking station by Startech would work connected to the Popcorn Hour's slave 3.0 or esata port. Perhaps two coud be connected, one to the 3.0 slave and one to the esata port.
http://www.amazon.com/StarTech-com-eSATA-Drive-Docking-Station/dp/B004I6OCRO/ref=sr_1_4?ie=UTF8&qid=1354230260&sr=8-4&keywords=esata+hub
Ray
martig is offline
post #564 of 2382 Old 11-29-2012, 03:53 PM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
The slave port cannot be used how you are thinking. it can only be connected to a PC and the A400 functions as a mass storage device it does not flow backwards. you could use the USB 2.0 port fine with it. the esata port is a maybe. I dont know if it supports port multipliers which is what that enclosure is doing. I would look around to see if someone else has one to confirm it would work.
post #565 of 2382 Old 11-29-2012, 04:30 PM
robnix's Avatar
Quoted: 768 Post(s)
Liked: 563
That would make sense for regions with as many languages as the EU.
Looky here!
robnix is offline
post #566 of 2382 Old 11-29-2012, 05:01 PM
martig's Avatar
Quoted: 23 Post(s)
So the computer can access files from the Popcorn Hour but the Pocorn Hour cannot obtain files from the computer over the slave port. I never understood the consept of slave as it relates to computer access.
Ray
martig is offline
post #567 of 2382 Old 11-29-2012, 05:18 PM
theaxledentaldj's Avatar
Can some people test my DVDfab remux:
I've remuxed Ice Age 4 3D ISO of the first 3 chapters (9 minutes) with two audio tracks and two subtitle tracks. Its a 2.98Gb ISO, broken into 6 500MB rar parts.
Part 1:
http://www.4shared.com/rar/UtVAGbLQ/ICE_AGE_CONTINENTAL_DRIFT_3Dis.html
Part 2:
http://www.4shared.com/rar/w5DCgtfe/ICE_AGE_CONTINENTAL_DRIFT_3Dis.html
Part 3: http://www.4shared.com/rar/2-GzUwe-/ICE_AGE_CONTINENTAL_DRIFT_3Dis.html
Part 4:
http://www.4shared.com/rar/tbH865mX/ICE_AGE_CONTINENTAL_DRIFT_3Dis.html
Part 5:
http://www.4shared.com/rar/ZHL8SSSD/ICE_AGE_CONTINENTAL_DRIFT_3Dis.html
Part 6:
http://www.4shared.com/rar/g4FxOrJS/ICE_AGE_CONTINENTAL_DRIFT_3Dis.html
Let me know if it plays off a local HDD and how it plays via Samba. I already know it will probably have issues via NFS.
It plays fine on my A-300 in 2D though.
theaxledentaldj is offline
post #568 of 2382 Old 11-29-2012, 05:40 PM
btizzle's Avatar
Quoted: 40 Post(s)
Alright guys and gals,
I just got my a-400 today and i plugged it in via HDMI and it shows the popcorn hour logo in black and white and says loading, after that the screen goes black and nothing. Am I missing something?? is it suppose to have a hd installed? I think I got a bad unit.. crap.
btizzle is offline
post #569 of 2382 Old 11-29-2012, 05:50 PM
btizzle's Avatar
Quoted: 40 Post(s)
ok, getting somewhere. I hooked up via component and now it is going through the steps of updating firmware. man.. I was freaking out.
btizzle is offline
post #570 of 2382 Old 11-29-2012, 06:14 PM
cadett's Avatar
Quoted: 45 Post(s)
Liked: 102
So I'm in file browsing mode & I have thumbnail view mode set, however there is no album art displayed. If I hit info it shows all metadata, fan art, & poster/thumbnail. What up wit dat?
cadett is offline
Popcorn Hour A 400 Network Media Jukebox
