New Boxee box revealed with DVR / builtin tuner - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 156 Old 03-28-2013, 02:01 PM
UHD Addict
aaronwt's Avatar
Quoted: 6200 Post(s)
Liked: 3847
Originally Posted by orionzdrm View Post
As of yesterday yes. Before then No. They just gave us an update.
I guess I'll need to conect my BoxeeTV back up. I unplugged it last weekend to make room for a BD player. I'll need to order another long redmere HDMi cable from Monoprice.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #152 of 156 Old 03-29-2013, 10:41 AM
scl23enn4m3's Avatar
Has anyone figured how to turn the thing off? It's constantly running a TV feed until I open an app up. And it gets hot!
scl23enn4m3 is offline
post #153 of 156 Old 04-10-2013, 12:11 AM
Eprst's Avatar
Looks like the recent update is not reliable.
After it my Boxee TV fails to connect to any TV set with or without AVR/HDMI matrix available around.
Using recovery console and manual updates is useless as well as customer support.
Eprst is offline
post #154 of 156 Old 04-10-2013, 01:24 PM
UHD Addict
aaronwt's Avatar
Liked: 3847
My Boxee TV has been fine since the last update. It's actually been better. With the pevious firmware, after so many days it sometimes became unresponsive. I have not run into that issue with the new firmware. Plus playinng back content online seems to be better. And I see I can initiate a recording from the BoxeeTv. Although it is restricted to the same channels that show up online. Even though I have sub-channels with guide info on my BoxeeTV, if that sub channel is not shown on the online webpage, I can't start a recording from the Boxee Tv.
for keeping my Boxee Tv cool. I ordered this cheap laptop cooler from Amazon.
http://www.amazon.com/gp/product/B0036RH5ZM/ref=wms_ohs_product?ie=UTF8&psc=1
I say cheap because to actually use it as a laptop coller would be crazy. If I constantly moved this thing around it would break. But using it with the BoxeeTv it works fine since it is not moved. The only thing I had to do to it was remove the led that was attached to the fan. So far it's een runnning 3.5 months unde my BoxeeTV.
post #155 of 156 Old 04-11-2013, 12:18 PM
Eprst's Avatar
10x for reply.
Actually I didn't see any other reports about BoxeeTV hardware problems.
So I'm unlucky alone.
Eprst is offline
post #156 of 156 Old 04-19-2013, 05:04 PM
benchmarkman's Avatar
Thinking about buying the new boxee. I live in an area that supports cloud dvr but a little confused. I have comcast and using a basic digital converter box that outputs in coax. Can I plug the coax output from the digital converter box into the boxee and still use the cloud dvr functionality? If a told boxee to record channel 3 (the input channel that I have to select in tv) and then set digital converter box to say TNT would it record TNT show to the cloud dvr?
benchmarkman is offline
The Boxee Box By D Link Hd Streaming Media Player
