Alternative to Slingbox? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-17-2012, 02:27 PM - Thread Starter
mrbarker's Avatar
Hey all,
I have a slingbox and it is simple and easy but it became to simple and easy and my wife routinely connects to it now. Is there a product on the market that would allow to users to connect to the same device and watch two different live channels or am I wanting to much?
MacTruck likes this.
mrbarker is offline
post #2 of 8 Old 10-18-2012, 05:31 AM
mlknez's Avatar
Quoted: 220 Post(s)
Liked: 60
Originally Posted by mrbarker View Post
Hey all,
Get a second cable/satellite box just for the sling. It does not need to be hooked up to any display device to work.
mlknez is offline
post #3 of 8 Old 10-18-2012, 09:00 AM - Thread Starter
mrbarker's Avatar
I have that, but now that my wife is using it as well we find that we both want to use it to often, or it could be that are breaks just happen to fall at the same time. Only one of us can be connected at a time so I was hoping to find a competing product with dual tuners possibly but that may be asking to much.. I was just curious if anyone knew a definitive answer..
mrbarker is offline
post #4 of 8 Old 10-19-2012, 06:32 AM
UHD Addict
aaronwt's Avatar
Quoted: 5953 Post(s)
Liked: 3659
Get a second Slingbox.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #5 of 8 Old 10-19-2012, 07:09 AM
DanPackMan's Avatar
Quoted: 270 Post(s)
Liked: 504
There is no 2 tuner version of a slingbox, AFAIK. 2 slingboxes is the simplest solution. If you are both trying to access your slingbox from a remote location via the internet at the same time, you may find that two users at the same time results in a drop in quality, assuming there is some limit on your upload bandwidth.
There are tuner products like the HDHomerun with multiple TV tuners that allow multiple connections on your home LAN, but there is no easy way to connect over the internet...it would require a PC with Windows Media Center running and software called "Remote Potato". Time and $$. You would still have the same quality limitations of your upload bandwidth.
DanPackMan is offline
post #6 of 8 Old 10-19-2012, 10:51 AM - Thread Starter
mrbarker's Avatar
So the competing products from Vulkano, Belkin, Hava, etc.. all also only allow one connection at a time?
mrbarker is offline
post #7 of 8 Old 10-19-2012, 04:28 PM
theslydog's Avatar
Hava is the forerunner to Vulkano and the Belkin is an off shoot of the Vulkano. They are all made by Monsoon. They can have mulitple LAN connections but only one WAN connection. They only have one input so you would all have to watch the same content anyway.
Currently 2 separate boxes is the way to go. The Vulkanos will stream quite comfortably with about 1-2Mb so if your upload is 5MB or less you would be better with the Vulkanos.
If upload speed is not a problem then the Slingboxes have HD.
Monsoon are currently working on a HD version of their Vulkano is it is supposed to be ready some time next year.
I personally dont like the way Slingbox collect stats on you - they monitor everything you watch. The Vulkano does not do this.
theslydog is offline
post #8 of 8 Old 10-19-2012, 04:53 PM - Thread Starter
mrbarker's Avatar
Thanks.. I'll just go pick up another sling box and hook up to the receiver in my home office
mrbarker is offline
