Computer to Receiver (buzz) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-28-2002, 04:51 PM - Thread Starter
tm1221's Avatar
I am getting a terrible buzzing noise, when I connect my computer audio out to my receiver. My computer has 3.5 mm mini plug output. I am converting to RCA and connecting to the tape input of my receiver. I can hear the audio content, but there is a significant buzzing in the signal. I have gone over the settings of the computer, and can surmise, it must be a grounding issue or something like that. Any ideas how to remedy this?
tm1221 is offline
post #2 of 7 Old 05-28-2002, 05:17 PM
smhughes's Avatar
Try another cord?
smhughes is offline
post #3 of 7 Old 05-28-2002, 06:07 PM
masicycle's Avatar
Try a 3 to 2 "cheater" plug if you think it's a ground loop. I had a similar problem on some active speakers and $2.11 later it's fixed!
masicycle is offline
post #4 of 7 Old 06-03-2002, 10:07 AM
Staind's Avatar
Is the cheater used on the PCs elec outlet or the receivers?
UTVing since 10/6/01
Staind is offline
post #5 of 7 Old 06-15-2002, 08:09 PM
virtuamike's Avatar
Yup, ground loop. You could go digital on your connection, that'll get rid of all the noise.
virtuamike is offline
post #6 of 7 Old 06-16-2002, 02:52 PM
masicycle's Avatar
Staind -
Sorry for the late reply...
You should probably use the cheater on the receiver's outlet. That should kill the buzz.
Kevin.
post #7 of 7 Old 06-23-2002, 07:14 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
Do yourself a favor and don't use a cheater plug. Grounded appliances are grounded for a reason, and groundloops can carry a rather significant current. Your best options are to use an optical link (no electrical path) or plug the computer and receiver into the same line conditioner/UPS/power strip/etc. Other options are to electrically connect the computer's and receiver's chassis with heavy gauge wire and add a 100ohm resistor to the signal connection path.
EricN is offline
Closed Thread Networking, Media Servers & Content Streaming
