how to Recovering a failed firmware and iconbit xds1003d stoped - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-06-2012, 10:38 AM - Thread Starter
hossamezz's Avatar
I want you to help me iconbit xds1003d when upgrade the last firmware then freez AND STOPED AND FLASHING IN FRONT PANEL UPGRADIN PLEZZZZZZZZZZZZ HELP SORY FOR MY Language
hossamezz is offline
post #2 of 5 Old 01-11-2013, 02:30 PM
Urkos's Avatar
Hello, my name is Pedro and I just bought a media player iconBITn XDS1003DT2. Did you solve the problem? I have the same problem?
Can you help me?
Thanks in advance.
Urkos is offline
post #3 of 5 Old 01-14-2013, 04:28 AM
erbjacob's Avatar
There is small button on the rear panel of the media player (U button). You'll have to search it.
Before using it, you have to switch off your player.
Insert your firmware on a USB stick (install.img), put it on your player.
Disconnect your media player, press the U button, don't release it, reconnect your media player.
Switch on with the remote control, without releasing your U button.
When you'll see your firmware upgrading beginning on your screen, then release your U button.
erbjacob is offline
post #4 of 5 Old 01-18-2013, 02:30 PM
Killerbeenl's Avatar
Sometimes you are 1 click away from pulling your hair out and bang your head against the wall
Killerbeenl is offline
post #5 of 5 Old 01-29-2013, 08:44 AM
erbjacob's Avatar
Don't forget, you must unplug your XDS1003D before !!
erbjacob is offline
