Bricked Micca EP600 G2 is back to life - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-14-2012, 02:46 PM - Thread Starter
HNaga's Avatar
I bricked my Micca EP600 G2 by installing Fantec firmware.
Fantec firmware contains bootloader, replaced Micca one.
I tried to install Micca Bootloader again but no luck.
All Micca or Himedia firmware I found don't contain boot loader.
Searched the net and found different ways , but none of them worked.
Micca support replied , "Unrecoverable device" we have nothing do. frown.gif
Here is my final exercise to have alive again:
  • Download Squashfs4_Diy_Win.
    Used for Packing/Unpacking Install.img
  • Download and install Measy X5 firmware (Measy_X5_v210_20120803).
    It will replace -finally - Fantec boot loader.
  • Use Packing/Unpacking Squahfs4 to unpack Measy Install.img
    Unpacking will create Install Folder contains the packed firmware.
  • Rename "Install" folder to "Measy_Install"
  • Unpack Micca firmware (micca-ep950-ep600-g2-1.0.4.22)
  • Rename "Install" folder ("Micca_Install".
  • Unpack Micca Boot loader (EP950-EP600-G2-Bootloader-5505)
  • Rename "Install" folder to "Bootloader_Install".
  • Copy and replace all files from Micca_Install\package5 to Measy_Install/Package5
  • Copy and replace Bootloader_Install\Package5\Micca bootloader.tar to Measy_Install/package5
  • Rename "Measy_Install" to "Install".
  • Use Pack_Squashfs4 to uack all files,
    It will generate new "Install.img"
  • Install "Install.img" into Micca EP600 G2
    but it will not work.
Code:
[time] t=011.653
Image type: bootloader
Image name: package5/bootloader.tar
command: mkdir -p /tmp/tar_file_tmp
In my system...
command: tar -O -xf /mnt/usbmounts/sda1/install.img package5/bootloader.tar | tar -xf - -C /tmp/tar_file_tmp
In my system...
[time] t=000.122
flash type: nand
Begin:[H27UBG8T2A][20202020 20 20]
[20202020 20 20]
[20202020 20 20]
blk_state_len =0x19
get original param in block b, size 0x3a0
....././................................/...........................................................................................................................................do_exit_n
blk_state:
d0 bb bb 23 23 23 23 79 79 79 79 80 80 80 80 81
ff ff ff ff ff ff ff ff ff
Finish
write bootcode success
#######[jh-debug] update_nand_xml(8375) install bootcode;
command: rm -rf /tmp/tar_file_tmp
  • Finally install Orignal Micca firmware (micca-ep950-ep600-g2-1.0.4.22) again.
Congratulations.
If you have dead Micca or Himedia, please try we may reduce the number of steps.
HNaga is offline
post #2 of 2 Old 10-15-2015, 12:52 AM
hasans's Avatar
Originally Posted by HNaga View Post
I bricked my Micca EP600 G2 by installing Fantec firmware.<br>
Fantec firmware contains bootloader, replaced Micca one.<br>
I tried to install Micca Bootloader again but no luck.<br>
All Micca or Himedia firmware I found don't contain boot loader.<br>
Searched the net and found different ways , but none of them worked.<br>
Micca support replied , "Unrecoverable device" we have nothing do. <img alt="frown.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/frown.gif"><br><br>
Here is my final exercise to have alive again:<br><br><ul class="bbcode_list"><li>Download Squashfs4_Diy_Win.<br>
Used for Packing/Unpacking Install.img<br></li>
<li>Download and install Measy X5 firmware (Measy_X5_v210_20120803).<br>
It will replace -finally - Fantec boot loader.<br>
Micca will work but remote control will not <img alt="frown.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/frown.gif"><br></li>
<li>Use Packing/Unpacking Squahfs4 to unpack Measy Install.img<br>
Unpacking will create Install Folder contains the packed firmware.<br></li>
<li>Rename "Install" folder to "Measy_Install"<br></li>
<li>Unpack Micca firmware (micca-ep950-ep600-g2-1.0.4.22)<br>
<li>Rename "Install" folder ("Micca_Install".<br></li>
<li>Unpack Micca Boot loader (EP950-EP600-G2-Bootloader-5505)<br>
<li>Rename "Install" folder to "Bootloader_Install".<br></li>
<li>Copy and replace all files from Micca_Install\package5 to Measy_Install/Package5<br></li>
<li>Copy and replace Bootloader_Install\Package5\Micca bootloader.tar to Measy_Install/package5<br></li>
<li>Rename "Measy_Install" to "Install".<br></li>
<li>Use Pack_Squashfs4 to uack all files,<br>
It will generate new "Install.img"<br><br><br></li>
<li>Install "Install.img" into Micca EP600 G2<br>
Bootcode will be installed successfully. Micca Logo appears again <img alt="smile.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/smile.gif"><br>
but it will not work.<br></li>
</ul><div class="bbcode_code">
<div class="bbcode_code_head">Code:</div>
<pre>
<code>[time] t=011.653
In my system...
In my system...
[time] t=000.122
flash type: nand
[20202020 20 20]
[20202020 20 20]
blk_state_len =0x19
....././................................/.................................................. .................................................. .......................................do_exit_n
blk_state:
Finish
</code>
</pre></div>
<br><ul class="bbcode_list"><li>Finally install Orignal Micca firmware (micca-ep950-ep600-g2-1.0.4.22) again.</li>
</ul><br>
Congratulations.<br><br>
When I try a new firmware for himedia q12 player, himedia device dead. no picture from himedia to tv only black screan. when Himedia device power on its only blue led lighting. How to boot flashing himedia device.Please help me ?
hasans is offline
