yaDis 2.2 Won't Reinstall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-01-2012, 08:17 PM - Thread Starter
time2jet's Avatar
I deleted yaDis 2.2 by mistake from my WIn7 64 bit laptop and when I try to run the new install I get this error:
Impossible to load settings!
This Application will Close.
I had it running smoothly on the exact same machine an hour ago.
Thanks for any help!
Jet
time2jet is offline
post #2 of 4 Old 12-03-2012, 09:12 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
check C:\Users\Username\AppData\Local\yaDIS and delete the folder. then re-install. It should be OK.
It could be also a problem with a template. Did you try to install one recently ?
Mr Eric is offline
post #3 of 4 Old 12-04-2012, 06:38 AM - Thread Starter
time2jet's Avatar
It worked! Thank you so much!
Awesome...
Props to you kind sir!
time2jet is offline
post #4 of 4 Old 12-04-2012, 06:55 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
Mr Eric is offline
