hdd for dune hd smart d1 - AVS Forum | Home Theater Discussions And Reviews
Old 12-07-2012, 09:23 AM - Thread Starter
babyslave's Avatar
hi all, im looking for some help...
i just purchased a dune hd d1 player and i would like to get a hdd for it. i plan on doing a nas later next year but my budget wont allow that right now.
so here are my questions
1. should i get an internal drive or external? why?
2. what is the max size hard drive that will work? internal/external?
3. what hard drive are you using in your dune player?
babyslave is offline
Old 12-09-2012, 06:30 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
1. Doesn't matter, chose the one you prefer.
2. 4TB internal, 3TB external USB (might work with 4TB but I think no one tested it)
3. Any 5400rpm hdd with low heat emission (so avoid 7200rpm at any cost). WD green or red drives are ok.
Mr Eric is offline
Old 12-09-2012, 10:38 AM
Nimblor's Avatar
I am in the same position as the OP. My thoughts are that a 3 or 4TB drive in the Dune will last me quite a while. Shopping for an appropriate HD has been very confusing. There are lots of complaints about WD Green drives formatting and other problems but I have not found much related specifically to the Dune.
Nimblor is offline
