Creative Jukebox 3 - AVS Forum | Home Theater Discussions And Reviews
Old 06-01-2002, 09:25 AM - Thread Starter
Joel Schnur's Avatar
I a m now loading this up and would liek to sync with my XP computer. When I try I find that XP think I do not own the CDs I own. How do I tell it I do (or disable) the seeting without ripping twice-once to my Jukebox and then to the computer. I want ot use the audio sync function in the player .
Joel
Joel Schnur is offline
Old 06-02-2002, 07:17 AM - Thread Starter
I am now loading the Jukebox 3 up and would like to sync it with my XP computer. When I try , I find that XP thinks I do not own the CDs I own. How do I tell it I do , (or disable) the setting without ripping twice-once to my Jukebox and then to the computer. I want to use the audio sync function in the player .
Joel
Old 06-02-2002, 10:35 AM
smhughes's Avatar
I don't use creative jukbox but have used media player and currently use REAL ONE. When you rip your cd's with these you need to make sure that licensing is TURNED OFF before you rip. Once a cd is ripped with licensing on there is no way to turn it off.
Hope that helps.
Jerz
smhughes is offline
Old 06-07-2002, 04:56 PM
KenL's Avatar
The firewire dump is so fast and PC storage is so cheap why not keep a local copy of the archive? Then when you upgrade jukebox 3 you won't have to re-rip. In otherwords rip everything into an XP folder then send it in?
KenL is offline
